Question about KitchenAid Architect? II S SERIES KUDS03FT Stainless Steel Built-in Dishwasher
KitchenAid dishwasher dispenser door does not open
Model: KUDK03FTSSO / Ser: FU2103430
Sometimes the dispenser door will not open during a cycle. I have made sure nothing blockes the door. This problem seems to be happening more often. The dishwasher has been used for apout a year.
  • Anonymous Jan 11, 2009
    Same problem - approx 18months old dishwasher from Kitchenaid. This is the second issue - had a motor go at 14 months. Not very impressed with the quality
  • Anonymous Mar 14, 2009
    Same thing happened here-- we thought it might be the detergent we are using, but switching it hasn't fixed the problem.
Joe_Rex
  • 114 Answers
SOURCE: Dishwasher Tabs
THIS IS JUST A SUGGESTION: TAKE SOME WARM TO HOT WATER AND POUR IT DOWN AND AROUD THE DISPENSER.
SOAP CAN "CAKE-UP" AND MAKE THE THE DISPENSER STICK. IN THE MEAN TIME YOU CAN PUT YOUR DETERGANT IN A COFFECUP ON THE LOWER RACK AND ACHIEVE THE SAME RESULTS. ALWAYS USE THE LEAST AMOUNT OF SOAP POSSIBLE.
GOOD LUCK
Posted on Feb 08, 2008
  • 351 Answers
SOURCE: soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Posted on Mar 02, 2008
SOURCE: Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Posted on Dec 13, 2008
  • 21 Answers
SOURCE: KitchenAid dishwasher soap door won't open
I took the door apart and found the degertent door solinoid looking like it over heated and melted to the cover flap and the insulation. See picture. I can't post pic as the max is 150kb.
I applied power and it only got hot and wouldn't operate.
Next I go to Kitchenaid for a replacement - FREE it should be.
Posted on Apr 09, 2009
BIKER T
  • 909 Answers
SOURCE: whirlpool dishwasher DU840SWP. soap dispenser not
Does the washer heat the water during the hot cycle. If it does, your soap dispenser module in the door is faulty. To install, you need to pull power plug out first,then sit on a chair in front of the door and then open the door towards yourself. Once open unscrew those screws along the perimeter of the door to enable you to remove outer panel. Once off, you can view how to remove soap dispenser. If water does not get hot, check the heater element and/or the reset (over temperature switch). Note, top rotator must move freely as well to allow hot water dispersion which on some occasions activates the soap dish. On other occasions it uses a solenoid switch.
Posted on Oct 03, 2009
Kitchenaid dishwasher soap dispenser will not open during cleaning cycle
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 24, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Soap dispenser does not open during wash cycle.
There is a plastic, mechanical assembly inside the front door of the dishwasher you will have to get to. Sometimes, a lever or other piece has slipped out of position. It will either have to be serviced, or you will have to try to fix it by taking the door apart. Not a hard job, but tricky without a service manual. Good luck.
Mar 20, 2010 | KitchenAid Dishwashers
The soap dispenser door does not always open
the dispenser has to be changed. there is a spring that might not be spring back to open . its easier to replace then to get the kit and rebuild your dispenser.
Feb 24, 2010 | Dishwashers
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
Detergent door does not open, it completes cycle without using the detergent
  1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
  2. Broken Timer
  3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
  4. Malfunctioning Door Components
  5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
thank you
vijay(vote for me)
Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Nov 22, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Soap dispenser not opening during wash
Most of the time the dispenser unit fails. It has a wax motor syetem and it just fails. Since you have to takethe door apart,I would suggest calling for service.
Good Luck!
Nov 17, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
KitchenAid Architect? II S SERIES KUDS03FT Stainless Steel Built-in Dishwasher Logo
143 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
