Question about Canon IXUS V2 Digital Camera
Ixus 70 dropped in sand, lens error & won't close
Some sand got into the camera while it was still on and when i tried to turn it off, the lens and shutter won't retreat. it was pretty much stuck. there is a grinding sound whenever i try to turn it off and ultimately, i can't view nor take any pictures.. the screen just keeps coming up with "lens error, restart camera"
  • jasperke Dec 22, 2008
    I have the same with my canon ixus 70
  • desireechong Jan 18, 2009
    ok... well, i've dismantled it and removed most of the sand. the thing is, now the camera won't even turn on anymore :( i've surrendered to saving up and buying a new one. any suggestions what camera i should buy which won't cause me any sand problems in the future?
  • 45 Answers
Hi jasperke,
try the following:
make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
there is a guide to dismantle it with pictures: try it:
http://www.fixya.com/support/t102982-e_18_problem
good luck!
Posted on Jan 18, 2009
My canon IXUS 70 digital camera keeps coming up with message "Lens error, restart camera" when I turn it on, then it just turns itself off
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jun 14, 2010 | Canon Cameras
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Jan 31, 2010 | Canon Digital SD900 / IXUS 900 Ti Digital...
Camera lens dont close
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 01, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
After a drop lens is not closing properly, photos are dim
Jun 09, 2009 | Canon IXUS 80 IS Digital Camera
E18 appears on the camera and the lens won't close
Mar 27, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Error on lens
Jan 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens Error, Restart Camera
Jan 02, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera lens will not open
Oct 12, 2008 | Canon IXUS V2 Digital Camera
Lens wont close
tryig to force it closed if sand is in it will do further damage. Can you gently extend the lens and jiggle it to see if any sand comes out. Most likely this fault needs repairing to open it up and remove the sand.
Feb 27, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Lens error
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Oct 09, 2007 | Canon IXUS V2 Digital Camera
Canon IXUS V2 Digital Camera Logo
269 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
