Question about Zanussi TD4212W Electric Dryer
Unsure how to access drier to put on new drive belt
The drive belt on my Zanussi 4212W has broken after much use. Before I attempt to get a replacement drive belt, I need to find out how to access the drum and motor. I've taken the top of the unit off, but obviously need to access the motor and disconnect (presumably) the rear drum mount to get the belt over the drum. I cannot access the underside of the drier to see the motor.
Any suggestions?
Here is my own solution...
Disconnect from mains (of course) remove top (2 screws at back near top) Unplug electric connectors (on back panel, top RHS). Make sure note what goes where! Lie unit down on front remove screws (2) holding the drum spindle cover (centre of back) and remove cover pop off the circlip holding drum spindle, and washer unscrew back panel - hex headed screws round outside of back Remove screws at bottom of back panel which screw into the plastic vent housing (3 I think) Lift whole back off. (there's a plastic lip at bottom - need to pull away from this a bit) The drum spindle will be unsupported now, so don't move unit Full access now to drum and motor beneath Get and put on new belt reassemble.
Actually, having got into unit, found could not get belt from local spares shop (it had closed down), so bought new drier!
Posted on Dec 18, 2008
  • Kevin Jan 14, 2012
    This was really useful, except being a novice I didn't know what the circlip was, and was trying to remove the wrong part. The circlip is the washer like metal ring, but it is about 1/4 open, and can be prised off (I used a couple of flat screwdrivers.
I think the drive belt has gone as the motor sounds as if it is spinning but the drum isnt moving. How easy is it to fit a new drive belt?
I haven't worked on a Zanussi yet but usually once the top has been removed replacing the belt is a fairly straightforward and intuitive process - it is removing the top that tends to be the difficult part.
I expect washer-driers would be more difficult but so far I have managed to avoid those.
Mar 15, 2016 | Zanussi FJS1225W Front Load Washer
Zanussi TD 4112 W....drier turns on and the heat comes put but the drum doesn't turn?
belt is broken drive pullt is off tension pully is broke
Nov 10, 2012 | Dryers
How easy is it to replace the rear bearing on a Zanussi TC7102W Tumble Drier, do I take the whole drier apart to do it? Thank you
you first remove the top cover,then the front cover then the drum belt and drum come out the front,and the bearing can then be accessed
Oct 14, 2010 | Dryers
Ai need a new motor for zanussi dryer model no td
You'll need to contact Zanussi Service center in case you want to buy new motor, Visit this Link and put your postcode to locate nearby service center.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 21, 2010 | Zanussi TC7114W Electric Dryer
How do i replace a drum belt to tumble dryer Zanussi TD 4212W
remove lid then take screws out from inside front cover/lid and slide drum out
Jan 13, 2010 | Electrolux Dryers
Replaced my zanussi tc-481w drier belt but it still won't work
Success! I found a clear explanation of the problem I was having and a diagram when someone recommended typing the model number into the Wiki how web site .
Result! Thanks for your help.
David
Nov 18, 2008 | Zanussi TC7114W Electric Dryer
I Have A Kenwood KTV1W Tumble drier on which the drive belt has snapped. I have ordered a new one but don't know how to access the drum to fit the new belt and how to put it on the drive motor pulley.
There are 4 posidrive screws in the middle of the back plate of the unit, once these are undone the backplate can be removed leaving the drum and motor pulley open to fit the belt
Sep 20, 2008 | Dryers
Zanussi TC7114W condenser Drier
belts do not figure 8
they look something like this
f6516ed.jpg the front panel comes off, to access the drum without removing bearings etc, and the belt can be placed easily, around the drum and motor pulley.
then pull the tensioner hard against its spring, loop the belt around the tensioner and allow the spring to tension the belt.
Feb 14, 2008 | Zanussi TC7114W Electric Dryer
Changing the Drive belt
How do I replace the drive belt on a zanussi TD265? any help
Oct 28, 2007 | Dryers
Zanussi TD4212W Electric Dryer Logo
246 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Marvin
Marvin
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
