Cant get my printer to the final stages of installation
What does the red flashing 'exclamation mark' mean that is flashing on the front left hand side of printer
  • 60 Answers
On mine it means feed paper. what is your printer's brand name? what does the computer say?
Posted on Dec 19, 2008
DSL yours did not put r4 but when I open it I see the name of r4 and with an exclamation mark
If you see any exclamation / question marks or red X's a new driver will need to be updated or installed right click select up date driver
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc If you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 i device arrows key scroll to nstalled. Hope this helps.
Jan 28, 2013 | Sigma 1.006596.V2.15 Luxembourg 1200/2200...
Printer hp lj 8100 dont view J6054
if you mean the printer wont start
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Mar 07, 2012 | HP (J6054B) 10 GB Hard Drive
I bought the Polaroid Pogo mobile printer.when I first used it, it worked well.today I tried to use it and it is just not working. My phone seems the picture but the printer gets a red flashing light how...
That depends on which red light is flashing. If the battery light is flashing, that means the battery is exhausted. Fix it by charging the battery.
If the status light is flashing red, that means the paper is jammed. Fix this by opening the paper door and pulling out the media. Full instructions are on page 3 of the manual.
The battery light is the one marked with a battery. The status light is the one marked with an exclamation point inside a triangle.
Feb 12, 2012 | Cameras
Hi dont have any sound on my acer aspire 3050
YOU NEED TO INSTALL THE DRIVER OF AUDIO
GO TO YOUR MANUFACTERER PC WEBSITE THEN DOWNLOAD IT FROM THERE AN INSTALL IT IN YOUR PC
May 11, 2011 | Computers & Internet
Eeepc webcam
Right click to My Computer
Manage
Device manager
In the right panel you will see all the drivers installed
If there is a question mark, or an exclamation mark beside of any of them, the driver is not OK
A question mark means that the driver is not installed at all, and that your machine doesn't know what device is it. Exclamation mark means that the driver has been installed, but that the driver is not good.
Sometimes, there is a red cross over the device - the device is turned off
Nov 15, 2009 | ASUS Eee PC 1000H Laptop
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Jun 11, 2009 | Saeco Odea Go
Red light is on in my car
Normally,,,the exclamation mark in car dash board defines the "Handbrake"...if you pull the hand brake lever up it lights on...sometimes there can be problems with that switch(all time it can be in on)...
(PLEASE VOTE AS "Fixya" for my help)..................................
Jul 30, 2008 | 1999 Honda Civic
Red exclaimation mark on C5280
plz try by reinstalling the drivers if the problem is not solved then your printer needs servicing
Jul 01, 2008 | HP Photosmart C5280 Printer
Photosmart d5160
I have had this issue with two D5160's, a poor cheap design i in my opinion. Symptom's were that after you had lifted and then lowered the main lid the red exclamation LED would continue to flash. The left hand front corner of the lid (near LED) did appear to be raised up but pressing it down made no difference. Sometimes if you listed the lid a couple of inches and then let it drop everything would be OK.
With the power cable disconnected I removed the left hand side off the printer, this is just clipped on but you do have to be careful with the part that wraps around under the card reader. This needs to be bent quite a lot to remove but it is possible without breaking. Start at the bottom gradually pressing the clips and separating it from the printer. Gradually work around up the front and then it lifts away from the top of the printer. Now, if you raise and lower the lid you will see two sliders moving. These are the problem, they tend to bind and not allow the mechanism to slide enough. I applied a small amount of silicone lubricant spray to each slider. After a couple of operations the difference was really obvious, the lid now does all the way down so its sits flush. Clip the side back on by reversing the above procedure and your done. Hope this helps.
May 26, 2008 | Office Equipment & Supplies
Not printing!
pls open your bakside.and
check there is no any paaper jam in fuser assembly.
Mar 26, 2008 | HP LaserJet 1320 Printer
Computers & Internet Logo
64 people viewed this question
Alun Cox
David Payne
David Payne
