Question about Dell A215 Computer Speakers
Only 1 speaker of mine works while the other doesnt make any sound. The one witht he sound dial on it doesnt make any sounds but it can still control sounds. How or what can i do to make it produce sound?
  • Anonymous Oct 12, 2008
    i have the same problem but with different speakers...the funny thing is it works when i plug in a DS or mp3 player to the speakers, but in my pc, the sound only comes out of one speaker.
    I also updated drivers and whatnot, so that cant be the problem
  • Anonymous Oct 20, 2008
    i hav d same problem go on control panel n speakers adjust em n put 1 down n both start workin
    Problem Solver:
  • 5 Answers
Have a look at the back of the speaker see if there is any dry solder of so replace it with new make sure there are no breaks in the wires cheers steve
Posted on Mar 18, 2007
Adjust the balance
Posted on Jun 04, 2007
My laptop has no sound yet I have no money to purchase a sound driver. can I get a free one
Laptop's sound can fail to work for a couple of reasons:
(1) the sound drivers are not properly installed - as far as I know, every computer manufacturer's web site will allow you to download their hardware drivers for free. Hope you've already done that.
(2) the sound hardware in the laptop are either disconnected or failed - a small number of laptops actually use separate sound cards (instead of integrating the audio hardware on the main board). Hopefully you've already checked that, too.
(3) the audio output jack (headphone) is damaged - in which case the sound hardware is functioning 100%, but there's no sound produced due to a shorted jack.
That being said, if it's neither of the above, the cheapest means of getting some basic sound to a muted laptop would be a USB sound card and a set of external laptop speakers. If it sounds elaborate and expensive, I assure you it's not. Assuming you're running Windows (hopefully XP or newer), you can buy a USB sound card on eBay for around $2 and pay about the same price for a cheap set of cheesy laptop speakers - plug the USB sound card into a working USB port, plug the speakers into the USB sound card, it's plug and play, and ... viola - you'll get $4 worth of cheap sound. It's a bit cumbersome but it's a cheap workaround that I've done before when a laptop went mute and I had only a shoestring budget to work with...
Sep 08, 2011 | Computers & Internet
Hi My speakers are acting up. Sometimes sound comes out sometimes it doesnt. Sometimes only sound comes out of the sub but theres no sound coming from the speakers. So i hear only bass. When i try...
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 03, 2011 | Altec Lansing MX5021 Computer Speakers
No sound on monitor
First off is your monitor has any speakers on it or capable off producing any sound? Not all monitors comes with speakers attached to it.
Jul 03, 2009 | ViewSonic Monitor Lcd 22in Wide Va2216w...
Output port for left speaker Z2300
I've been having the same problem actually.
In my situation, turning the volume up and down using the speaker volume control will fix the problem. I only have the faint volume problem at some positions of the dial. turning it up usually fixes it. I'm thinking that opening it up and cleaning it might fix the problem (it used to work with an older set of Creative speakers i had).
If that doesnt work im going to try to get a new remote from logitech.
Jul 02, 2009 | Logitech Z-2300 Computer Speakers
Altec Lansing BXR1121
I have same speakers, but only woffer is working, speakers doesnt work. i am really in big trouble.
Apr 24, 2009 | Audio Players & Recorders
Sound Won't Work on Dell Computer
Go to Control Panel and go to sound and audio devices. It should have the name of the speakers you are using. If it doesnt then the speakers might not work on that PC. Get a new set of speakers, and try again. It should work on the new ones. If it doesnt, get it checked at PC World or a PC repair store to get it checked, as the problem will be internal in the PC. Hope it works.
Sep 15, 2008 | Dell Computers & Internet
Speaker doesnt give sound
Based on the fact that you have put a headset in and another speaker system and it is working properly there is nothing wrong with your windows settings. I would leave them alone. The issue appears to be with the hardware. Have you attempted to plug the speakers into another source (ie. cd player, ipod, etc)? If you plug them in there and they don't work, take the speakers back and have them exchanged. If they're not under warranty you're going to have to either get them fixed or replace them. Good luck on this one! JC
Sep 30, 2006 | HP P5302M Computer Speakers
Altec Lansing ACS295 Sound Control Dial
hi first buy a conductivity spray and spray on the dial and inside it if this wont help then just solder a knob which will fit good luck
Apr 16, 2006 | Altec Lansing ACS 295 Computer Speakers
Dell A215 Computer Speakers Logo
90 people viewed this question
Top Dell Audio Players & Recorders Experts
Steve Allison
Steve Allison
ptpumpman
Marvin
Marvin
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
