1999 chevy blazer with a 4.3l v6 i replaced evaperator vaccumed sysrem when i add freon compressor clutch engaes low side pressure 65 - high side pressure 75 system seems to only take a small amount of freon not a full charge
It could be one of 2 things.
you didn't vaccum it all the way or there is b clog in the system. next time u flush it run about 1/8 cup of rubbing alcohol through it . then push clean air through it. then refill it. if that doesnt work replace the seals on the compressorlow and high side lines/manifold.
high side pressure low on ac system
vaccumed a/c system hooked gauges up put r135a back in low side 15psi high side starts out good but line gets really hot after a bit 350+ psi the more Freon put in the higher the psi goes on high side
Freon was over full, fuse and relay check good compressor cycled for about 2 seconds once. Where are the low pressure cut in switch located
