When i format the laptop the lan connection does not working the when i connect the rj45 wire to lan it does not appear on my windows and and there is no blink of ligth on my laptop! what seems to be a problem sir mam
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
hope this helps
SOURCE: toshiba laptop A25 integrated ethernet and wireless lan not working
Right, you need to click
>Start
>Computer
>Vista C
>Toshiba
>Drivers
>WLAN
>Realtek
Then find a file called Setup, there may be several. You are looking for the one which is an Application. Mine is around 450kb in size.
Double click it to correctly install the Wireless adapter.
Follow the instructions on screen. This should take no more than 90 seconds from start to finish.
Good Luck
SOURCE: Lan connection not working on Toshiba satellite laptop
Try setting up a new Broadband internet connection. Input all the appropriate Login info and you ought to be good to go via the LAN port. Everything else is aimed towards Wireless.
