Question about Zenith R40W46 40" Rear Projection HDTV-Ready Television
I have a laptop Z755110 Execituve . i also formated this laptop but usb drive notconeected
I was last my motherboard drivers cd. how can i get drivers
Posted on Jan 06, 2009
When i insert my USB flash drive called sanDisk cruzer 8GB in the laptop,am told that i need to format the disk in drive G before i can use it,when i try to format it, it says that windows was unable
If there is any Media Error not possible to format the drive otherwise use the following method on Windows 7
Open a Administrator command Prompt and type the command one by one
1.list disk
you can find the avilable disk and note your USB Drive Disk Number
2.select disk 1 (change the number)
3.clean
4.create partition primary
5.format fs=ntfs quick
6.assign
if no problem in usb it will format your USB Drive
Apr 03, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have two dead (power supply) PC laptops that I would like to recover some music and pictures from. What is the most economical way to do this now that I have a macbook pro?
When you put the hard drives into an USB hard drive adapter case you cannot boot up the laptops using the external USB hard drive unless the laptop's BIOS has the option to allow the USB device as a boot device.
You can plug the external USB hard drive into any PC/laptop to copy files from the USB hard drive to the PC/laptop.
The MAC cannot read or write to the external USB hard drive unless the hard drive had been formatted in FAT32. There is no way a MAC can read a NTFS formatted hard drive and it will want to format the hard drive.
Oct 05, 2012 | Computers & Internet
How can i format my neo laptop without a cd rom
Connect the USB storage drive and begining of the power screen go to BIOS setup and change the boot sequence to USB drive.
It will load from your USB drive now and if it has pre-loaded formating files you can format it now.
Say, if in USB has the Windows XP, then it has option to format drives/create partitions.
Or if it is in Linux follow the command.
Aug 06, 2011 | Computers & Internet
How to format compaq laptop nx6110
Hi
you could try to do this
Please try to save any files or pictures that you need before you do this either to a usb spare hard drive or a usb pen drive because you will loose it all if you format or reinstall windows
press the power on key as well as the F11 key
hopefully this will take you into the factory restore
which will format the hard drive while it restores
if you just want to format the hard drive itself then you could remove the hard drive
connect it to another computer via a usb cable and use the other computer to format the hard drive that you removed
or there are some good software out there that you can bootup with and format your drive without removing it from your laptop
a bootable spotmau would do the trick but its not cheap to buy
norton system works is another good software
pleasse let us know if this has helped you
many thanks
Jul 08, 2011 | HP Compaq nx6110 PC Laptop
How to format the USB drive?
Plug your USB drive to a PC/laptop
1. Double click on "My Computer" -> select the "USB Drive" ->Right Click and select "format" check "Quick Format" box and click OK (When formatting is done your get a popup message)
or
2. Open the Windows Explorer, -> select the "USB Drive" ->Right Click and select "format" check "Quick Format" box and click OK (When formatting is done your get a popup message)
Aug 04, 2010 | Computers & Internet
How to format without XP CD
Does this laptop have USB ports? If so you can get an USB CD drive and you can then format the hard drive and re-install Windows.
Mar 15, 2010 | Lenovo IdeaPad S10 - 42312BU Notebook
Zenith executive laptop model no:z75110 mother board cd
I am having zenith z755110 laptop. I am not having the driver cd for that, pls anyone can me
Jan 09, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Zenith R40W46 40" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
