My hard dosn't work but the led is on when i connect
My external hard drive does not work.one of my friends said that it can be repaired
    Problem Solver:
  • 8 Answers
It can be repaired not by anyone.
dont try to open the hard disk.
Once it get opened it wont work.
Try fixing with a hard disk technician.
They will fix the disk inside a dark chamber which should be
dust free and moisture free.
Posted on Dec 15, 2008
WHAT SHOULD I DO WITH MY SAMSUNG 300E5C NOTEBOOK THAT TURNS ON BUT DOES NOT BOOT?
The hard drive may be failing, or just the OS or hard drive corrupted. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive.
Then, you could try to do a Factory Restore on the computer, and if that works, copy your personal files back to your newly restored computer.
Jul 28, 2014 | Samsung 300E5C 15.6in LED Notebook - Intel...
Led screen dosn't work connected to external monitor will work as long as the led is almost closed
No reformatting will help . Unplug LED screen vga from board and see if laptop will work on external screen . Could be magnet switch .
Jun 08, 2014 | Dell Latitude E5500 Laptop
Why will my verbatim 250 gb external hard drive will not show up in the computor or on a media player connected the tv ?
Hard drive could have damaged file system which would require a repair. Hard drive may have failed. Just listen for a clicking sound. If you hear it, your drive is bad.
May 07, 2014 | Verbatim Computers & Internet
My Hard drive dosen't work again the system could not recognize it.
Good Day.
Don't know if your external hard drive has power led on it, that comes on when connected to the PC. If it has these led, does it come on when connected to the PC? If no, then I believe there's is problem in the connection within the external Hard disk. So maybe you buy a new cord or you just have to change the connection panel or buy a hard disk casing that has the panel for connection in it.
Or, if the led give light, do you feel any movement (or rolling) within the external hard disk when connected? If yes then it's still working, just try the first recommendation.
I hope this helps. Thanks for using FixYa!
Sep 10, 2012 | Western Digital Elements Computers &...
My Toshiba px1394u-3g50 external hard drive is not working, light flashing and not recognised
Try connecting the hard drive to some other laptop and see if its getting recognized. Issue could be either with the hard drive itself of it could be with the usb port which you are using to connect the hard drive to your laptop.
Jan 17, 2012 | Computers & Internet
Hello, my external harddrive (Verbatim, 500GB USB/FW800) stopped working. When connected the blue LED lights up. After 3 sec it goes into flash mode. The HHD makes a clicking sound. The MAC Hard disc...
> the HDD makes a clicking sound.
That's a very bad sign. :-(
> find a way to rescue the [files]
Search online for a professional "data recovery service". For a significant fee,
they can repair your disk-drive, just long-enough to copy your files onto a brand-new disk-drive.
Nov 03, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
LaCie External USB 2.0 500GB i worked fine for about a year. now it is not recognised on any computer. it alsoo used to humm now no noise only led. can it be repaired?
There is a chance that the internal connections have come lose...if you're feeling brave, go ahead and open up the case and make sure that all the internal connection are tight and etc. In particular, you want to pay attention to the data and power cables that plug directly into the hard drive. If this doesn't solve your problem you may want to take the drive to a local Best Buy or something like that and have them see if they can "read" the hard drive. If they can't..your hard drive has failed...If they CAN then you may just need a new enclosure...They can direct you in there.
Dec 21, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
Simpletech external hard drive 500gb
well trying to remove is not a problem if you have some experience of putting it in the hard drive but ,check the wire connections first of all ,but i must inform you if you dont have any idea then ask on some repair shop just the opening part inside the things are really simple it has a LED for power on and off and some simple connectors that connnect ur hard drive to the usb from which you connect it to your computer so check if you can open just the outer shell with some help!!!hope it works for you!!
Jan 31, 2008 | Computers & Internet
Computers & Internet Logo
297 people viewed this question
David Payne
David Payne
