Question about GE Advantium 120 Convection/Microwave Oven
Microwave is on when you shut the door
We unplugged it overnight and plugged it in this am reset the clock and when you shut the door it runs light on no heat.
  • 1 more comment
  • rlatour Dec 16, 2008
    I had the same problem this morning. My wife shut the door after warming a cup of coffee and the cavity light and internal fan came on. No amount of button pushing or unplugging helped. Out of frustration I slammed the door forcefully and voila! it stopped and now works normally again. I know this isn't a permanent fix to if anyone can point me to the faulty part I sure would appreciate it
  • rlatour May 11, 2010
    Mine is a GE Advantium 120.
  • William Miller
    William Miller May 11, 2010
    You probably have a bad door switch or door switch mount, or possibly a stuck relay.
    Please reply back with your brand and model number so we can help you.
    Problem Solver:
  • 3 Answers
I tried all the things on your website. Holding the clear button , unplugging,...
So I went back to the last operation that I was doing when the problem started.
I was using "reheat" so I put a glass of water in the micro turned on reheat 1 serving.
It started and then I hit clear after a few minutes and the problem went away.
Posted on Dec 16, 2008
Samsung Over-The-Range Microwave Oven just went out, wont come on at all.
Hello Terrell,
If "wont come on at all" means no light when door is open, no clock, nothing, then assume complete loss of power to that circuit.
These are often powered by an isolated circuit with its own breaker. The first place to look is your power distribution panel and see if you can find a tripped breaker.
If yes, then reset the breaker and see if the microwave has lights, clock, etc.
If no breakers are tripped, the actual microwave plug is often in a cabinet above the microwave. Sometimes, these may get pulled out while moving items in and out of the cabinet, so check that too.
If unsuccessful, microwaves also include an internal line and/or thermal fuse which fail due to overloading. Also, the control panel can go bad or become unplugged from slamming the door, etc.
If you do have lights, clock etc., then a faulty door latch will prevent operation of the microwave generator.
Unfortunately, will need additional information to properly identify the potential.
I hope this helps.
Jan 10, 2018 | Samsung Microwave Ovens
Sharp Carousel Microwave I heated some food. It worked fine, and shut off when it was done. I took out the food. When I closed the door the light stayed on. Light will not shut off. I tried...
Sometimes the switch in the door latch sticks. Mine did that and I ust closed the door with just a slight more force and everything started working fine.
Mar 03, 2015 | Sharp Microwave Ovens
Troubleshooting
you probley need a magnatron..also check your door saftey switched
Aug 14, 2014 | Microwave Ovens
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Model # MH7149XFQ - 0. Nothing works. No light when you open the door. The control pad does not respond. The light under the microwave does not work. The clock display shows the digital clock but the clock...
1. Go check your breaker box. Find the one for this outlet, reset. Or just reset every one if U cannot figure that out. 2. if that does not do it..... The ck the Outlet w/ a proper tester (cheap @ builders supply, just a plug in tester w/ lite for volts.... too easy. 3. If neither of these work, find the fuse for the microwave & replace. If not qualified, hire or ask someone who is.... 4. none of these work..... time to buy a new one. gettocar
Aug 14, 2011 | Whirlpool MH7140XF Microwave Oven
Sunbeam microwave model SGB8901 will not stop running.....
I had the same problem, but didn't have the box anymore. The store let me exchange it for another one but that one is doing the same thing too.
May 24, 2010 | Microwave Ovens
Hi. I pressed the 'quickstart' button on my micromat 900 w microwave and used it for 10 seconds. On pressing the 'door open' button, the display panel is showing '1' rather than the cooking time or the...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
It may be a problem with a door switch or door switch mount.
Sep 28, 2008 | AEG Microwave Ovens
MICROWAVE NOT WORKING PROPERLY
Let us know if the hard reset does not fix it.
Otherwise, it sounds like a bad door switch or door switch mount.
Aug 20, 2008 | Daewoo Microwave Ovens
Trouble shoot microwave
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Also, are any other of your electrical items (light bulbs, DVDs, etc.) failing lately? This could indicate improper power line voltage.
Let us know if the hard reset doesn't fix it.
Jul 18, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Timer Shuts off after 5 seconds
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Is it 5 seconds or 5 minutes? The difference coulsd be important, but either could indicate a bad magnetron.
Let us know if the hard reset doen't fix it.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 18, 2007 | GE JES1289SK Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
140 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
