By Perkins - usenet poster
I just installed a gas heater and I am concerned that it might not be big enough to heat my pool effectively. It seems to take about 5 hours to bring the temperature up about 3 degrees. is it normal?
Solution #1
posted on Aug 08, 2005
pandamama - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
The time it has taken for you to heat your pool 3 degrees is correct. The heater is working fine. We would suggest you cover your pool. This will save gas and money, as well decrease the time needed to raise your water temperature.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Reddy Heater RLP100 Portable Forced
Email this problem
Email this problem
This Problem Also Relates To:
Coleman 5075751 Utility Heater
Coleman (5035A751) Heater
Frontgate (173523) Baseboard Heater
Frontgate 18373 Heater
Honeywell HZ519 Baseboard Heater
Honeywell HZ-3220BW Compact Heater
Honeywell (CT62B1015) Baseboard Heater
Can you Help with these Heaters problems?
Reddy Heater RLP100 Portable Forced Air...
COMFORT GLOW PROPANE HEATER,...
just had the propane tank... Answer This...
Repair Service
Find Heater Repairman Near You:
