Question about Adobe PageMaker 7.0 Classroom in a Book (201756250)
Error 8009:20540 cannot open file Internal error: Tried to lock 0 legth block 8009:20540 filesize 1.90mb
Memory overflow
try printing a different file format. is teh printer connmected via network or USB? connect either way and see
Apr 09, 2013 | Oki Brand Oki 62435103 C330dn Laser...
Unable to read massage 0 for update in tally ERP 9
Step 1
open drive where data is save
after it open your company data folder
than you have find a file (TMESSAGE.TSF)
it's error code 0
select this file and deleted its
after above process 100% your problem solve out
Dec 09, 2010 | Office Equipment & Supplies
Message on attempt to record: 'input blocked'
I got this same message on my VN7000PC that I got in LIDL. The message appeared when I tried to record. I could not get it to go away. At the time I just happened to have 5 files in Folder A with lock on. I tried to remove the file locks. I got the same message "Input Blocked". That was a clue. Maybe it had something to do with the internal 1GB drive. I formatted the drive. The message disappeared and now I can record again.
HTH
Brian.
Jul 07, 2010 | Olympus DS-40 Digital Voice Recorder
MadDog MD-16XDVD9 could not perform end of disc-at-once
Have you tried checking your basics ?
Firmware ?
ASPI ?
Disk Defrag ?
IDE location ?
Jumper settings ?
What type of media are you using ?
What programs are you using ?
Exactly where are you and what are you doing when your error occurs.
What are your PC's specs ?
Do you have any Roxio products installed on your PC ?
Please answer ALL of the above - if you don't know, say so, don't make something
Oct 20, 2009 | Computers & Internet
Cannot compress a PDF
I assume you have tried the "reduce filesize" command. Try opening the file in Preview and print it - in the print dialog box select the pdf button, type a name and print. You get a file in the location you selected. This can reduce the size considerably.
Jun 26, 2009 | Adobe Acrobat 7.0 Professional for Mac
Use vb.net and access
Imports System
Imports System.IO
Imports System.Data
Public Class SaveImage
Shared Sub main()
Dim o As System.IO.FileStream
Dim r As StreamReader
Dim gifFile As String
Console.Write("Enter a Valid .Gif file path")
gifFile = Console.ReadLine
If Dir(gifFile) = "" Then
Console.Write("Invalid File Path")
Exit Sub
End If
o = New FileStream(gifFile, FileMode.Open, FileAccess.Read, FileShare.Read)
r = New StreamReader(o)
Try
Dim FileByteArray(o.Length - 1) As Byte
o.Read(FileByteArray, 0, o.Length)
Dim Con As New _ System.Data.OleDb.OleDbConnection("Provider=Microsoft.Jet.OLEDB.3.51;Persist Security Info=False;Data
Source=Test.mdb")
Dim Sql As String = "INSERT INTO images (Pic,FileSize) VALUES (?,?)"
Dim Cmd As New System.Data.OleDb.OleDbCommand(Sql, Con)
Cmd.Parameters.Add("@Pic", System.Data.OleDb.OleDbType.Binary, o.Length).Value = FileByteArray
Cmd.Parameters.Add("@FileSize", System.Data.OleDb.OleDbType.VarChar, 100).Value = o.Length
Con.Open()
Cmd.ExecuteNonQuery()
Con.Close()
Catch ex As Exception
Console.Write(ex.ToString)
End Try
End Sub
End Class
Jul 08, 2008 | Microsoft Computers & Internet
Not opening excel file in network
what is the filesize..sometimes large excel file open slow
Feb 12, 2008 | Computers & Internet
Ringtone Size
the file must be less than 300kbs
Dec 04, 2007 | LG Shine KE970 Cellular Phone
Tape drive does not recognize or eject tape
Yeah the Ultrium 4 tape drives only r/w to ULT3 and ULT4 tapes.
We put a Ultrium 2 tape in our 4 drive and it seems to be locked permanently.
Oct 26, 2007 | HP C7438A (Refurbished) DAT Tape Drive
YAMAHA CRW8424 gives Track following error..
PROBLEM DEFINITION: Basically, it is a hardware error that occurs when a drive is not capable of following a data track on a CD-R or CDRW or on the other hand, poor power flow may cause the problem SOLUTION: 1. Try use another disc, a disc with a different band. 2. If one doesn't work, you may have to open your system and use a different power connector, making sure no other devices are using the power connector in the same strand. 3. Lastly, if neither the above doesn't work, you may have to send your drive in for servicing as the head may be dirty or misaligned.
Aug 05, 2007 | Yamaha CRW 8424 Burner
Adobe PageMaker 7.0 Classroom in a Book (201756250) Logo
95 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
