Question about Toshiba Satellite A135-S4527 Notebook
Toshiba A135 not restarting after BIOS replacement
None of the 4 USB ports of my son's Toshiba Satellite A135 2386 was working. We open the computer and found no visible hardware issue. We closed the computer and restarted OK. After searching we found that somebady fixed that by updating the Bios from Toshiba support site. We found that the exisiting version was 1.10 and that the most recent for this model was 1.40.We downloded and installed. After the installation the program automatically tryed to re-start the computer, however after shutdown the computer neve came back to live again. The screen is fully black. How can I re-load the BIOS? Is this the solution?
  • aschirmer Dec 16, 2008
    I noticed that the "on" ligt turns on but the fan does not starts. Can it be a hardware problem?
  • aschirmer Dec 19, 2008
    Recently my son took his computer to get looked into at a local computer repair shop. There the staff, at no charge, connected the lap top to an external monitor to see if possibly it was a monitor problem. The external monitor showed the boot-up screen, then the computer's own monitor showed the boot-up screen soon after. The computer began functioning normally and continued after 3 full shut-downs and reactivation. It still did not recognize any USB devices. My son brought the computer home and again successfully activated it and then shut it down. After this fourth shut-down it again does not boot-up. What it the solution?
    Novelist:
  • 115 Answers
I would recommend re-downloading (1st download may have been corrupted) and putting the BIOS update onto a floppy disk (on a second PC, of course) and trying to boot from it. On Toshiba, hold down the 'F12' key when you turn on the PC (put floppy in first) and continue holding until you see a boot screen. Choose to boot from floppy disk. If this doesn't work, I'd try doing the same procedure but using the original BIOS version, as it obviously worked. If this still doesn't work, there's a good chance the mother board is now damaged. I would have the laptop looked at professionally before giving up entirely though. If these ideas don't help, please let me know.
Posted on Dec 16, 2008
  • 837 Answers
A failed BIOS update is best repaired by replacing the motherboard.
Sorry
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
It would appear that the BIOS update has failed. One of the basic requirement in BIOS flashing is to ensure of an uninterrupted source of power to the computer. I will assume that when the BIOS was flashed, the AC adapter/charge was connected. To try and revive the laptop, pls try:
  • remove the battery and AC adapter;
  • remove the memories;
  • plug the adapter back in (without the battery, without the memory);
  • power up the unit. Pls determine if there will be beeping sounds or any other indicators such as the LEDs;
  • remove AC adapter;
  • re-install the memories;
  • again, plug the adapter back in (without the battery);
  • try powering up the unit;
  • if successful, enter CMOS/BIOS setup;
  • set everything to default, save and exit;
  • power down;
  • install battery, plug AC adapter, try again.
Should the above be not corrective, then the backup battery has to be removed or shorted and the above performed again.
incidentally, the original problem of the missing USB could very well be a surface mounted fuse for the USB's +5 volts supply.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 15, 2008
  • 104 Answers
I am totally sorry you had this problem, but with a laptop it is nearly impossible to recover a bad flash, the only chance you have is by opening the laptop again and shorting out the cmos battery leads for 60seconds and then try posting,(if system posts it will post in boot block and require a usb floppy drive to reflash the bios) if that doesnt work it may be over, i know this isnt something you want to hear, but a bad flash on a laptop can be devastating as the bios chip is soldered onto the board, if you decide to try this, try looking around the board for a small socketed chip it should have 8 pins on all four sides, if there is one you may be able to order a new bios rom for the laptop.
    President:
  • 2,110 Answers
As u described that after updating BIOS u cant boot ur Laptop...It seems that accidently u corrupt BIOS of ur motherboard..So If u have warrant left try to replace otherwise u have to purchase a new motherboard..
  • Sibananda Jena
    Sibananda Jena Dec 16, 2008
    Yes ...It is the problem of ur power supply or Mother board..
  • 734 Answers
Yes may be there is a BIOS issue in your system.
  • futureloginn
    futureloginn Dec 15, 2008
    do some steps---
    1. check Virus on your system.
    2. try to go on BIOS Setting.
    if you cant able to access BIOS than your BIOS may be Corrupted and than need update BIOS.
    Thanks
I need the defualt toshiba satellite a135-2386 bios password
I do need the hash code of the bios
You can get that be entering any wrong code three times to get the bios code. Send that to me so i can reply with the code.
You can also get that code by pressing F12, F2 or F10 when you asked that bios password.
Will be waiting
Dec 11, 2010 | Toshiba Satellite A135-S2386 Notebook...
My Laptop Toshiba satellite a135-2386
Click Start
Click Control Panel
Click Classic View
Click Add/Remove Programs
Select Windows Defender
Click to "remove" it
Restart your computer
Download from http://www.microsoft.com/antispyware
and install the latest version, and let it update.
If it still happens, you may have a computer-virus that is "disabling" Windows Defender everytime you restart.
Nov 19, 2009 | Toshiba Satellite A135-S2386 Notebook
USB ports do not work but diagnostic shows no problem
Hi there
if you are familiar with getting into bios go into bios and go to periphials and scroll down to where it says usb and make sure that it is enabled ok please let me know if this works for you
best regards mike
Feb 17, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satelite a135 s2386 USB problems...
this is the fault of your usb port, its a hardware problem, its better not to use that port, use a usb hub if you want more usb ports
Nov 11, 2008 | Toshiba Satellite A135-S2386 Notebook
Satellite a135-s2386
Resetting your USB Controllers I'm going to assume that you're running XP (home or pro). Recently I had to refresh my USB ports. This is the sequence I used.
1. Right-click My Computer and select Properties
2. Click Hardware
3. Click Device Manager
4. Expand the Universal Serial Bus Controller
5. Right-click each USB device listed and select Uninstall
6. Click OK to confirm removal of each device
Note: Repeat steps 5 and 6 until all devices under UBS Controller are removed
7. Shut down computer.
CAUTION: Ensure that the Shut Down option is selected instead of Restart.
8. Wait a few seconds and turn computer on. When it reboots you will see "Windows has detected new or added hardware"
Note: You will have to insert your Windows CD, if prompted.
These steps will refresh the USB ports.
Added Notes: 1) If your mouse is a USB you will have to use the keyboard to shut down your computer. 2) It would be wise to unplug everything from your USB ports EXCEPT your mouse and/or keyboard before you restart the computer to avoid Windows replicating any printers, scanners, digi-cams, etc. Once Windows has refreshed your USB controllers and ports, shut down again. reconnect, and restart.
Good Luck
Sep 27, 2008 | Toshiba Satellite A135-S2386 Notebook
Toshiba satellite a135-2326 usb not recognized
its a driver issue most likly down to vista (as always) have you tried the latest updates from the microsoft website yet?
Aug 11, 2008 | Toshiba Satellite A135-S2386 Notebook
I have a toshiba satellite a 135 s 2386....my all usb ports are not working and whenever i attach any of the accesories on it i get a message USB DEVICE NOT RECOGNISED...i have formatted my computer and instaled new windows through my recovery disc but i m still facing the same problem....please help me out.......thnx
Jul 05, 2008 | Toshiba Satellite A135-S2276 Notebook
USB PORTS DO NOT WORK
Turn off computer and try connecting an older mouse to the mouse port. If it works:
Right click Computer>click properties>click hardware>click Device Manager> click USB adapters. Then check to see if some of them are marked. Also you can click on each one to see if each is OK. Make sure that USB is enabled in the BIOS.
Jun 01, 2008 | Toshiba Satellite A135-S2276 Notebook
USB not working after resetting bios on toshiba a135
try using other usb port,,, .. run device manager and remove auknown device file... restart the computer...and also go to the cmos bios and find usb configuration the enable it..
Mar 14, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
47 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
