Question about Bose (321GS) System
Cd drawer on BOSE system making noise on opening and closing
It sounds like it needs to be oiled but know I cannot. Can anyone help without dismantle / workshops.
  • fredaoc Dec 17, 2008
    Kirk,thanks so much for your help.Freda
    No am currently living in Johannesburg South Africa.
  • 71 Answers
Ok this is a belt driven drawer the noise is there is a little gear made from plastic . the cause is there are teeth missing from the gear .due to /pushing drawer manually or forced shut / or kids / now this this will have to go to bose for repair i was a bose agent for repairs and yes this is the worst bit it will cost £140 TO £200 POUNDS if you send it now you will not get it back before christmas best regards kirk brown
Posted on Dec 15, 2008
  • kirk
    kirk Dec 17, 2008
    are you in the uk Freda . regards kirk
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
How to open cd drawer
Oh my God, the answers I\'ve found on the net on how to get the CD drawer on a Crosley CR247 open are all nuts. Mine wouldn\'t open yesterday and I dismantled the whole damn thing to get the tray open, but that isn\'t necessary.
First of all my unit was making noise when I hit the eject button but the drawer wouldn\'t open. I knew there was no CD in the tray. Powering down and all the other foolish answers I found didn\'t work. There is no small round hole in the front to do a manual eject. Trying to pry the door open won\'t work and you\'ll just damage the unit. Here\'s what you need to do. And do it all GENTLY. There is no need to force anything!
Take a small, pointed steak knife out of your kitchen silverware drawer. This is all you\'ll need to get the drawer open. First let\'s identify where we\'re going to put that knife blade. The CD drawer says "CD RECORDER" and there are 3 lines on each side of that label. Where you\'re going to put that knife is below the 3 lines on the left, to the left area of those lines (see picture). This is the location of the drawer lock.
If you still hear noise when you push the eject simply push in the knife gently as you push the eject button. The drawer will open if you got the right spot.
If you hear no noise, or your unit is dead and you want the CD out, or if you\'re just afraid to stick the knife in the unit, unplug the unit. Gently push in on that spot until the drawer pops out a little bit. Now you can gently open the drawer by hand.
You can see the drive belt and pulleys (see pic). Mine was still intact but needs replaced. Here is also the info I got off of the back of the CD (see pic). Might not be able to find a replacement belt but at least you can get the thing open. Good luck.
jim Maarrttiin@msn.com
Mar 04, 2014 | Crosley CR247 Shelf System
My Bose radio/cd player is making a loud siren noise when you attempt to turn on the radio or play a CD. Does anyone know what this is?
  • The amp has gone bad. You risk blowing the voice coil in the speaker until this is fixed or repaired. There is an electrolyte capacitor that has gone bad.
Regards, Tony
May 23, 2011 | Bose Wave Radio
The dvd drawer will not open on Bose 3-2-1 system. When you push the button to open the dvd, the display say ''opening'' but it does not open. There currently is a dvd inside.
That happens when you close the drawer instead of pressing the close button  you can skip gears and it would have to be taken apart and re-calibrated.   Sometimes it is just a glitch that you can over-ride using a straight pin into a small hole on the front  (assuming this uses a drawer).
Nov 09, 2009 | Audio Players & Recorders
A cd is stuck in 5 cd player. Drawer won't close. (Sony) When drawer did open/close, it just started making a noise - maybe belt wearing out.
Without knowing the model number, this is pure speculation:
There are some Sony units that can easily get "out of time" in the loading mechanism. This can be caused by a broken trace in a ribbon cable or a defective sensor. Some models can get out of alignment or timing if you push the drawer rather than pushing the close button. Please update this with the model number, and I should be able to give you more details.
Thanks,
Dan
Oct 01, 2009 | Sony Audio Players & Recorders
Cd magazine stuck in unit. you can hear the motor
There should be a tiny pinhole on the drawer. Put the end of a paper clip into the hole and push lightly. This will release the cd drawer.
Jan 12, 2009 | Bose Lifestyle 25 System
Bose 321 can't select cd/dvd source and won't eject
this is a belt driven drawer there is a little gear made from plastic . the cause is there are teeth missing from the gear .due to /pushing drawer manually or forced shut / or kids / now this this will have to go to bose for repair i was a bose agent for repairs and yes this is the worst bit it will cost £140 TO £200 POUNDSthe unit has locked out this is a common problem with this unit bose do not actually make this unit its a generic design the company should stick to speakers only .there are better built systems than this,people think they are buying the best its the name game again i have been in this trade a long time my moto is always buy sererates if your cd/dvd goes wrong you can pop a new one in rather than loose the lot . bose are not good on servicing slow and un reliable depending on where you are . uk not good /america dont know sorry to deflate you i have 6 off these units waiting for parts all with the same fault . people panic and take a knife to the drawer to get there beloved cd out this does even more harm a drawer will cost £47.00 a cd £ 10.00 ..TO Replace it can be retrieved so there it is. if you are in the uk my email is kjb01@btinternet.com we can talk if you need further assistance if you send it now you will not get it back before christmas best regards kirk brown
Dec 13, 2008 | Bose (321GS) System
CD drawer will not open or close
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
Bose 321 DVD System
I love my Bose 321 DVD system, but a few days ago, it started acting weird. I put in a DVD, and it reads - "No Disc".....and I'm not sure why. I cleaned the disc, and I also played a DVD/CD Maintenance kit - I'm not sure what is wrong. It seems like I have a problem within the system - what can I do?
Dec 10, 2007 | Bose (321GS) System
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Bose (321GS) System Logo
124 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
