Question about Kitchen Appliances - Others
Tefal Quick Cup not heating water
Hi. Only had this gadget for a month, and it has been brilliant. But, this morning, when I used it, the water came out cold. Have emptied it and turned it off then on again but still the same. Any ideas?
Press the hot button on off 5 times and on the 6th let it run a cup full. This will re set the temperature
Posted on Jun 09, 2009
  • 19,396 Answers
That is either becaus of a lose contact, or because of a faulty element.
The unit should have one year factory warranty, call Tefal and have the product replaced, see:Contact us - Consumer Service - Tefal.Com .
Posted on Dec 27, 2008
Testimonial: "Good solution, many thanks"
The steam is building up in the water tank but not going through to the iron.
I suspect that the discharge holes have become clogged by calcified deposites due to hard water. You need to de-calcify the iron. Mix one cup of white vinegar with one cup of water and pour this mixture in the iron and let it heat up. The acidic vinegar should dissolve the build up. repeat until clear. forthe final, use a little lemon in a cup of water to get rid of the vinegar smell. You can prevent this by using only distilled water in the iron, but this is not really practical, so a couple of clearing runs of the vinegar/water bath each month will put this off.
Feb 09, 2011 | Tefal UltraGlide Easycord FV4256 Iron
Tefal quick cup kettle water coming out in slow spurts,have changed filter but no improvement.
If you are in a hard water area you may need to descale the heater element. Try adding 1 cup vinegar to 3 cups water and run the machine should clear up the scale. Rinse thoroughly before use.
Sep 12, 2010 | Tefal Kitchen Appliances - Others
Hello tefal quick cup water is no longer hot only
we had to return our first one for the same problem Gavin. Tefal (surprise surprise) claimed that nobody else had EVER had that problem. 2 years down the track though, and i've discovered that mine turns itself on at random intervals, and floods the kitchen bench. My advice - get a refund while you still can...
Mar 03, 2010 | Tefal Kitchen Appliances - Others
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
NB the RED LIGHT WILL BLINK FOR THE DURATION OF THE PROGRAMMING.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
Tefal Quick Cup
ALERT :- Tefal Quick Cup can TURN IT SELF ON. Tefal know about this but it is a potential fire hazard. Mine turned itself on and dispensed the water reservoir over my kitchen. Dread to think if I had been out shopping what could have happened. Tefal know about this problem but are not doing anything to advertise the fault!!
Jan 19, 2009 | Kitchen Appliances - Others
Water is not coming out hot enough for coffe or tea from my tefal quick cup
It won't be hot it's like tap water. Did you see the drain for the furnace?
Nov 25, 2008 | Heating & Cooling
Tefal express iron cleaning
Thankfully I was able to clean the boiler compartment, by unscrewing the large bolt on the boiler, cleaned with water only, loads of brown yuck came out, It would then not allow me to use the steamer, Waited until the next morning tried again and working brilliantly again.
Jopey
Aug 19, 2008 | Tefal Irons
Tefal Quick Cup
As you are getting a light, then the fuse/ supply is ok .
Does it have water in it?
If not, it may be a safety cut out sensing this - and turning off.
Check the manual for any mention of a "thermostatic trip" This may be user-resettable by means of a rod or button underneath, or may need to cool down - you may even hear a click when it does.
If not - then it is likely to be a manufacturing fault within the heating element.
You should be able to return it to the shop you bought it from for a full refund.
May 31, 2008 | Kitchen Appliances - Others
Tefal quick cup - descaling problem
Push red and black for 5 seconds to lunch descale then unit resets light at end oy cycle
Hampshireman
Feb 25, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
1,282 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
