I have ceilng electric heat.The kitchen seems like it turn on but
Gets very hot seems like it doesnt shut off. i installed a new trermostat but same result. was wondering if before me someone installed the wiring wrong? i copied the wiring from one to the other. bought the house in april so its the first winter in it for me.
Change the wiring,thanks for your support.
Posted on Dec 18, 2008
Whirlpool elec. Single built in oven...lower element wont heat at all upper gets warm doesnt seem to get real hot. Metered lower element got continuity.metered wires to element nothing... Please help I'm...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 09, 2010 | GE JGBP26 Gas Kitchen Range
We ordered New World Model 444447275 had it fitted, when we light the oven on full temperature it works for approx 2 mins then the ignition kicks in and the oven goes out. We asked for replacement and we...
it sounds like a install problem . two ranges same problem . either a cooling fan is not working or it require a vent of some kind . i would ck the install very good . at two min its shutting down due to heat . just a thought and may not be the real problem .
Dec 04, 2009 | New World 60GSO Dual Fuel (Electric and...
We had a drop in stove and we replaced it with a new slide in but when we took out the old stove it was hard wired in. Soi cut the wires, there were threea black, white and a soild copper so i installed a...
Oh my! The white and black are normally both HOT wires!!! Bare copper is ALWAYS a ground wire, and also can work as neutral. Neutral is the middle prong on the plug.
Turn off the breaker before even touching your appliance, there might be 110v on the metal parts!!!
Black and white should be on the sides, and bare copper - in the middle.
Before switching the wires make sure that black and white really are the hot wires: there should be 220-240v between them.
Oct 14, 2009 | GE Profile JB968 Electric Kitchen Range
Our oven is not heating up past 150 degrees. The
The element will have to be replaced if there is no power going to it.
Jul 20, 2009 | GE Spectra JBP84 Electric Kitchen Range
Kenmore Electric Water Heater/ Economizer 6
it usaly takes a few hours to heat up depending on water size check our breaker to see if it tripped out make sure all your wire connections are good u could take the front plate off and hit reset if you dont get hot water in a few hours ull probibly have to replace the trermostats and maby the elements its not hard to do good luck
Mar 06, 2009 | General Electric GE SmartWater Household...
Oven will not shut off
Sounds like a stuck relay in the control board. The only way to repair this problem is going to be by replacing the control board. If you have anymore questions please ask. I'll be more than happy to help you further.
Thanks
Jan 10, 2009 | Maytag MER6769 Gemini Electric Kitchen...
Burner turned on by itself and cannot shut it off
if there is a fuse for that burner take it out.u might have to replace the infinit heat switch
Mar 06, 2008 | GE JBP80 Electric Kitchen Range
Electric Oven not getting hot enough
there are relays on the oven control that turn the elements on and off, sounds like you need a new control
Feb 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
