Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Where is the rear brake light switch located on a 97 Fatboy ?
    Scholar:
  • 29 Answers
Follow the actuating rod from the bottom of the brake pedal to the master cylinder. The switch is threaded into the inboard side of the master cylinder and is a pressure switch. If you disconnect the 2 wires and short them together, the brake light should turn on when the ignition switch is on. If it doesn't the problem is in the rear end wiring, not the switch. A couple hints if you replace the switch: Put some pipe dope on the new one and have it ready to go. Unscrew the old one and quickly apply the new one before all the brake fluid escapes. That way you won't need to bleed the brake. Also, see if they have an Accell brand switch. This one of the few aftermarket products that is better than original. Cheaper, too.
Posted on Dec 28, 2008
Why wont the brake lights not work on my 1993 fatboy
Check the wiring under the rear fender for damage. Check the bulb by replacement. Check for 12 volts at the rear brake light switch. Check for blown fuses.
Sep 27, 2014 | 1993 Harley Davidson FLSTF Fat boy
Why wont my brake lights not work
Check the wiring underneath the rear fender for damage especially if you are running a wider than stock rear tyre. The rear tyre comes in contact with the loom and wears through it. Also check for 12 volts at the rear brake light switch. I will assume that you have checked the bulb by replacement and also checked all fuses.
1994 fatboy brake light staying on
Hi Anonymous, your front brake lite switch button is probably not getting pushed back into the off position. Remove your right handelbar switch housing and push the plastic button in and out with your finger to see if the light goes off and on. If not disconnect the wires to your rear brake lite switch and check the front switch button again. If the button works then reinstall the switch housing and push it towards the master cylinder hard and hold it with one hand and retighten the screws with the other. If you hook up rear brake lite switch wires and the brake lite comes on replace the switch. For a wiring diagram for your turn signals go to: http://officialharleyparts.com/wiring_diagrams.php Good luck
Apr 13, 2014 | 1993 Harley Davidson FLSTF Fat boy
How to change the 2002 fatboy rear brake switch
Hi Glenngrigsby, Good luck and enjoy the videos:
Feb 25, 2014 | 2000 Harley Davidson FLSTF Fat boy
How do you change rear brake light switch on 04 fatboy
Hi Anonymous, for more information on your question please visit the websites below and good luck:
Testing and replacing Harley Rear Brake Light Switches
Aug 16, 2012 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Tail light and foot pedal brake light does not work but hand lever brake light works.
Probably a bulb/ rear brake switch combination. If your front brake switch is working, then half of the bulb is working. No taillight issue, probably a bulb. No rear brake light, probably the rear brake switch. Located on the lower right rear of the frame, behind the exhaust. Check for power on the orange/white wire at switch. If you have that then check for power on the other terminal of the switch while pushing on the pedal. The rear brake switch is hydraulically operated so you must have adequate pressure to activate it.
May 04, 2012 | Harley Davidson Harley-Davidson Motorcycle...
2007 brake light switch fatboy does pressure switch handle both front and rear
Hi Anonymous, no it does not, there is a front brake light switch in the right handlebar switch housing and one in the rear brake line tee and for a free wiring diagram please visit the website below and good luck. Harley Davidson Wiring Diagrams and Schematics
Mar 30, 2012 | Harley Davidson Boulevard C109RT...
Brake light quit working on my 97 R 1100 RT. Fuse is good and neither front brake or rear brake action will allow the rear brake lights to come on. Does the brake light route through the flasher relay?...
I thought the brake light has its own feed from the battery as the brake light works with or without ignition on mine. Maybe a blown fuse or poor earth. Check for 12 volts on the switches.
Feb 17, 2011 | 2007 BMW R 1200 RT
The brake lights on my 97 540 have gone out. The
check the brake pedal switch 1st. they're notorious for needing replacement.
google: key words: bmw brake pedal switch 1997 528i
then the fuse.
Oct 31, 2009 | Pro-Fit Pro.Fit Bm 51 97 Bmw...
97 Altima dashboard brake light stays on
Check your brake fluid level in the engine compartment. Its located on the rear RH side of the engine compartment, its a white/clear resevoir connecting to a large black circular object. If the fluid is low, fill to proper level, also I would recommend having your brake system checked as there may be a leak. If the fluid is fine and at the proper level, you may have a damaged/broken brake fluid level sensor or damaged/broken Emergency brake switch. Hopefully this helps....please rate thanks!!
Aug 09, 2009 | 1997 Nissan.5 Altima
Lands Phones Logo
123 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
