Question about Bose Acoustimass 15 System
Woofer cuts out intermittently
My AM15 woofer has started cutting out intermittently. I recently moved, so it probably took some abuse. This started immediately after hooking the system up.
I managed to get the cover off and checked the fuse. Although it seemed and checked out good, I replaced it anyway. That is probably the extent of my abilities to diagnose the problem. It does one thing of note, when you move it around slowly (like stand it up on it's face (the horn) it comes on. Set it back down into it's natural position, and it cuts out again. Slight shaking seems to have no effect.
All of the speakers work fine, so it seems as if perhaps a component (in the power system) has a short of some sort. I can replace components (like a resistor, etc.), just unsure of what to test or even how. Any suggestions on what I should test or replace?
Thanks for any suggestions!
    Scholar:
  • 51 Answers
Buy a soldering iron and go over all solder connections on the circuit board. Sounds like you have a cold or intermittent solder connection. Also make sure the problem isn't in the subwoofer cable. Don't be afraid to do a little soldering, and just make sure you don't create "bridges" between existing solder connection. Only heat the connections long enough to melt them and add a little solder, as excessive heat can destroy sensitive components. Before doing all this, remove and reinsert all related cables into their jacks several times, as these connections can become oxidized and make poor contact over time.
Posted on Dec 27, 2008
Erratic starting circular saw
Sounds to me like you have a bad cord. Clamp the saw to a workbench so that it can start and run safely without you having to hold it. Put tape or a wire tie around the trigger to hold it in. THEN plug it in. Then move the cord around, especially near where it enters the saw. If the saw starts and stops intermittently you have confirmed the bad cord. Good luck.
Mar 06, 2013 | Saws
Hello I have a 2005 Nissian Sentra S it has recently started cutting off while I'm driving . I took the car to Auto Zone where I was given a code of P0335 which was a crank shaft sensor. I replac
Unfortunately, replacing a sensor only fixes the problem about half the time. The code means the computer is not getting a signal from the sensor, not that the sensor has failed.
The problem could be in the wiring, or the part that the sensor gets the signal from.
Feb 25, 2013 | 2005 Nissan Sentra
Isuzu Bighorn engine intermittent loss of power and cutting out while moving, white smoke
-Mostly burning water. Water is enter into the cylinder.
Good luck
Mai
Oct 25, 2017 | Isuzu Trooper Cars & Trucks
Buzzing noice in speaker i think it is the woofer
I had the same problem, check the pine connexion it's probably the problem, mine was cut in half and do short-cut that produce that noice.
Jun 27, 2011 | Creative Technology Kwong Quest Benwin S...
Saw runs great, however when cutting;the kerf goes to the left.Replaced the chain recently and it cut fine for a few cuts then started the same problem. Could it be the bar grove is worn and needs...
You probably have a warped bar. Remove side cover and chain, then remove and reverse bar ( move the top to the bottom ) . Pour bar and chain oil on the tip of your bar and spin gear inside with a flat screwdriver to allow oil total penetration. re - install chain and side cover, adjust chain and tighten cover.Make sure you keep the oil reservoir full - refill everytime you add fuel. When it starts cutting crooked just reverse the bar again.
Nov 09, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My Subwoofer cut in and out intermittently how do I stop this?
Take out the actual cone and check the connections to the terminals.
Check earth connection!
Apr 04, 2009 | Jl Audio Slash v2 250/1v2 Car Audio...
2004 civic ex speaker install problem
you won't have to do any cutting the brackets should help fine
Feb 17, 2009 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
Intermittent sound with Panasonic SC-HT900 home theater system
I will get back with you on this tommorow with more information when I can get the technical data I need from where I work.
These units are know for the problem you are describing.
If you have to connect all of your speakers to the subwoofer, then yes, you can replace the subwoofer and it will fix your problem. I just don't remember right now if this unit is the one with the amplifier built into the sub woofer, but I think it is.
Since you paid another repair center you really should take it back to them to fix it right. They probably did not test it long enough to verify if they fixed your problem.
I know it is a real pain to have to take it back, more so if it is far away, but the problem you are having is nothing you will be able to fix yourself unless you have some decent electronic troubleshooting and soldering skills.
Get back with you soon,
Dave
Jun 19, 2008 | Panasonic Home Theater System System
Power quick when in use
cord may be fractured at point where it enters machine. cut 6in off and remake
Apr 23, 2007 | Dirt Devil CE6000 Featherlite Wet/Dry...
Bose Acoustimass 15 System Logo
403 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
