Question about HP Computers & Internet
Opening case on HP 1905 monitor - HP Computers & Internet
    Novelist:
    Champion:
  • 233 Answers
If it is a CRT (the big one that looks like a TV set) don't do it. You could get zapped with a whole bunch of electrical voltage. I don't know if LCD monitors do this or not.
Posted on Dec 25, 2008
Toshiba Satellite 1905-S301 PC Notebook will not
Hi! You may want to toggle the function button designated for turning the monitor on or off. Press FN button together with th efunction button that has a monitor image on it. some system uses F2 of F3 button to do this. (Example: press FN+F3 or FN+F2 button together once while computer is on to turn on system display)
Jun 08, 2010 | Toshiba Satellite 1905-S301 Notebook
Emprex LM 1905 DOES NOT COME ON NOT EVEN THE LIGHT
1. Change the power cable for the monitor and see if it comes on
2. If it does not come on, do one more test and hook up this PC to another computer
3. If the Monitor works on another PC, then the problem is with ur PC - start by changing the VIDEO CARD
Mar 14, 2010 | Computers & Internet
Emprex monitor lm 1905 - blacks out after a
If this has an internal power supply (no external brick) then you probably have failure of the capacitors inside. The problems exhibited by these failures are usually summed up as "works for a short while and quits" or "will not come on". Yours is probably similar to some Gateway monitors that I have repaired, The parts required for the repair should be under $10.00 and should take under an hour. Now you need to find a shop that can and will do the work unless you have soldering skills.
Dec 05, 2009 | Emprex Computers & Internet
Osd lockout on cant do nothing with the menu or volume from the buttons on panel if you push them you get osd lockout
I had the same problem. In my case, one of the panel buttons got locked against the monitor case. I fixed it by opening the monitor case, loosing the buttons and repositioning them back to their place.
Oct 20, 2009 | HP w1907 LCD Monitor
How to open the casing of my LCD Monitor Model HP w 1907v
I have a problem of opening the casing of my LCD Monitor, I want to open it so that I can visually check inside.
Jun 19, 2008 | Hyundai ImageQuest L50A 15.1" Flat Panel...
Satellite Pro 1905-S301
if u get normal beep of ram then check your disply resolution .
when u start your pc press F8 key continus then if u get menu choos best configuration loading in menu.then change your resolution to 800x600 or 1024x768 .if u not get menu and your cpu ;s smps still work but not disply on monitor then clear your bioss . get away the cmos cell for 15 minutes from its case.then start your pc .i think your problem is solved.
Mar 21, 2008 | Toshiba Satellite 1905-S301 Notebook
Apple 30 inch monitor
No, this is not normal. This could be one of two problems. 1) internal connection to the "Y" array is somehow been compromised either through some defect in manufacturing or simply a loose connection. 2) The LCD converter board in the monitor is defective. In either case it's internal to the monitor and would have to be serviced. Have you checked with HP to see if the device is still under warranty? It just might be If not, you can try opening the unit and checking the connection on the left hand side towards the area you mentioned. But beware that the monitor does contain leatal voltages.
Nov 20, 2007 | HP vs15 15"LCD Flat Panel Monitor
Open Questions:
Computers & Internet Logo
151 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
