My nephew downgraded vista to xp he has 3 harddrives but it only recognised c drive. he cannot access the other 2 unless he goes through command prompt.
    President:
  • 1,073 Answers
Hi M8!
Well, you have to make the drives aktivate by handle them.
Right click on "my computer"
Select "Handle" its almost at the end on that dialog window
You will now see a new window, at the left, almost at the bottom you will see a promt saying "Disk Handle" press that one
Now you will see all the disks on your pc, C is aktivated coz you have your OS on that one, under C you will see the other two disks
Format them one by one and give them a letter, like F or H or K or whatever you want as long as the letter isent taken by another divice.
For your notice, everything on those disks well be lost, so if you have important things on the disk i suggest you take them out, connect them to another vista pc, and save and store the info you want to keep.
Restart you PC and VIOLA....there they are!
Good luck to you
If you find my answer helpfull, dont forget to vote
Posted on Dec 15, 2008
    Problem Solver:
  • 16 Answers
HI,
Sounds like the drives need to be assigned letters. Right click my computer and click manage. Then click disk management. Then right click on the volumes that aren't showing up and click "change drive letters or paths". Then in that dialog, click add and change the drive letters. Good luck!
When i am installing windows xp on Hp pavlion dv3 laptop following error occurs "A PROBLEM HAS BEEN DETECTED AND WINDOWS HAS BEEN SUT DOWN TO PREVENT DAMAGE TO YOUR COMPUTER IF THIS IS THE FIRST TIME...
Since, for your laptop you are downgrading the operating system from Vista to XP then with HP notebook.
You need to disable Native SATA support in BIOS utility and go ahead with the installation. To disable the SATA support you need to follow the below steps:
== Disable SATA native support:
1. Turn on or restart the notebook.
2. Press the F10 key when the "HP Invent / Compaq" logo appears on the screen. This will open the BIOS menu.
3. Select the "System Configuration" tab.
4. Select "Disabled" for the "SATA Native Support" item.
5. Press F10 to Save and Exit. Choose Yes for "Save configuration changes and exit now".
For more information on this visit the below link from HP.
Problems with SATA Drivers When Downgrading From Vista to XP
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01675438&cc=us&lc=en&dlc=en
if you get any problem while doing this then plz get back. Actually you need to do lot of things to downgrade from Vista to XP on HP preloaded vista operating system.
Let me know if you find any difficulties doing this..
I hope this will help you to get it work. Plz vote for me..Dreamkam
May 24, 2010 | HP Pavilion Dv3-1075us Notebook
I have purchased an hp550 computer with the Vista operating system. i wish to downgrade to the win XP operating system. how is this done ?
Greetings.
There is no direct path to downgrade Vista to XP. You can’t simply insert the XP installation CD media into the CD-ROM drive and hope to ‘upgrade’ and replace the Vista with Windows XP usual install routine because Vista won’t allow it to be overwritten. XP will treat Vista as ’superior’ operating system and refuse to install over it. There’re actually few options available instead of completely uninstall Vista as listed below. But if you decide to downgrade from Vista to install XP, there is also a simple guideline that you can observe to ensure that the migration goes smoothly.
Option 1 – Dual Boot:
It’s by far the easier and best method to run XP instead of Vista if you have another partition or hard disk. Simply boot up any XP setup media and install XP into different partition or hard drive than the Vista installation. Once completed, you can choose to boot up either XP or Vista, and has the best of both world.
Option 2 – Virtual Machine:
Install VMware Server or Virtual PC 2007 (both free) or any other virtualization software, and then install Windows XP into the virtual machine
environment. You will get XP which runs inside Vista, with minor compromise on speed, performance and have to go through Vista first on every bootup.
Option 3 – Format the Hard Drive, Wipe Off Vista and Install XP:
For those who totally fed up with Vista and just want XP, or prefer a clean installation of OS has only this option to rely on. To downgrade to XP from Vista, you have to basically delete the whole hard disk that installed with Vista, and start anew with XP. Here’s a simple guide and procedures that you can try to follow to switch to XP. However, each system configuration is different, so you may have to adapt the steps to suit your own need.
1. Download all drivers for your system for Windows XP from the manufacturer’s website(in case if you don't have the CD/DVD installers). Copy the drivers files to a USB flash driver or external hard drive or burn them to CD/DVD.
2. Find a Windows XP installation CD (should be pretty easy to find or else you can search in torrent sites such as Demonoid to download via BT network such as uTorrent and BitComet or search and download via ED2K network client such as eMule. You can also use Volume Licensing (VL) CD, retail (FPP) disc, or system builder hologram CD provided by Microsoft.
3. You will also need a XP product key even if you legally can downgrade from Vista Ultimate or Business edition. The Vista serial number won’t works with XP. (try to search for XP product key on web).
4. Backup to USB flash disk, external portable hard disk or CD/DVD every data files and any other things such as documents, downloads, pictures, movies, programs and etc that you need and want to keep. You can also create a second partition with disk management utilities such as Acronis Director or Partition Magic, and then move the data files to the new partition.
5. Ensure that also you have CD or DVD setup media for the software applications that you want to install and use after wiping off your system from Vista.
6. If your OEM doesn’t provide you with recovery CD/DVD discs and Windows setup media discs (it’s because they’re stored in the hard disk in hidden location), you may want to burn a copy of recovery CD to CD/DVD first before you proceed, just in case the hidden partition is lost and you want to recover your computer to original state. (How-to Guide: IBM/Lenovo ThinkPad recovery CD)
7. If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first. If you have PATA (normal IDE) hard disk, simply go to BIOS CMOS to disable SATA or Native SATA mode if you don’t want to install XP on SATA hard drive. Else, you can also create an XP install disc with the SATA drivers integrated by using tool such as nLite.
8. In the BIOS, also set the CD or DVD optical drive as the first boot device in the boot sequence.
9. Put in the Windows XP installation CD into CDROM drive and boot up the computer by using the CD. You probably need to press a key when prompted with “Press Any Key to Boot from CD…”.
10. If you’re using SATA hard disk with driver on external media (not integrated into XP setup disk), remember to press F6 when you see the message at the status base: “Press F6 if you need to install a third party SCSI or RAID driver…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized.
11. Run through the setup wizard at per normal. However, when prompting for where to install Windows Vista, delete (by pressing D and then confirmation), create and format the Vista disk drive or partition (if you have multiple partition). And then choose to install on that just formatted partition or hard drive.
IMPORTANT: If you choose the wrong hard disk or partition with data to delete, you will lose your essential data.
Note: If the setup does not allow you to delete or format the Vista partition or drive, you will need to find a third party software that can recognize and read NTFS filesystem to clear the drive or partition first.
12. Enter any product key for XP. Vista product key will not work.
13. If you own a legitimate Windows Vista edition that allows for downgrade (See Vista downgrade rights), call Microsoft after performing the clean install of Windows XP Pro to activate the XP installation. Notify Microsoft that you’re downgrading from Vista and require to activate XP Professional or other version allowed newly installed. You won’t get a new Windows XP product key though. You will have to read out the long Installation ID plus your original Vista serial key, and Microsoft will provide an activation ID that will make the XP usable.
14. Install the drivers for your system devices.
15. Reinstall any software programs that you want to use.
16. Move back the data files and documents.
Thanks
Nov 03, 2009 | HP Business Notebook 550
I want to have xp on my vista gateway laptop
Hello, Its really hard to downgrade from vista to XP on dell laptops. vista and XP use completely different drivers and dell has stopped writing drivers for XP. But still you can downgrade. You need to setup external SATA harddrive from where your XP CD should boot as it wont boot from your current harddrive that has vista. Even if you set these up and downgrade, Since dell has stopped writing drivers your new XP will not work with many new softwares and applications as you wont have drivers for them. I would advice you to use Vista. Good luck, Please rate the solution. ~regards, Jegan
Jun 03, 2009 | Gateway MX6710 Mobile Entertainment...
Installing windows xp
You cannot install Windows XP over WIndows Vista. Microsoft has put a lock on the Vista software and will not allow you to downgrade to a lower software. The only way you can do it is to wipe your hard drive completely clean first with a disk deleting software or with the command "fdisk" at the DOS prompt. However, this is dangerous and I do not recommend it unless you have someone professionally trained to do it. It will wipe everything off of your disk and then you can load Windows XP.
Don't forget to rate his solution with 4 stars before you log out.
Jan 27, 2009 | Compaq Presario C700T Notebook
Vista - xp downgrade slave harddrive recognition problems
there are 2 solutions:
1-format your h.d.(if you don't need any file inside)
2-upgrade to vista, copy your important files then downgrade to xp and format the drives.
Dec 15, 2008 | Microsoft Windows XP Professional
How to install XP over Vista (BIOS can't disable SATA native mode)
make new xp with nlite software and inbuilt achi and ICH9 driver. then try to install xp.
Nov 05, 2008 | Intel Gigabyte GA-8IDX 845 AGPset P4...
Swaping hdd
You have half a dozen reasons why this will not work. The Operating system (XP) does not recognise the different hardware, the Bios doesn't recognise the MBR (the file structure of the harddrive) and you have all the wrong hardware drivers installed.
There is a way to do this if you have the original XP installation disk, install the harddrive, put the XP installation disk in the CD/DVD drive and set the machine to boot from the CD/DVD first. When the machine boots up and goes to install XP follow the instructions as if you are doing a fresh install, when SetUp attempts to format the harddrive it will discover you already have a version of XP installed and will give you the option to repair it, go ahead with the repair and MAYBE SetUp will be able to see and install the correct hardware drivers. If not you are looking at Slaving the harddrive, saving your personal files and then formatting the harddrive and reinstalling XP fresh.
Oct 31, 2008 | Dell OptiPlex GX110 PC Desktop
Vista downgrade to xp
First, why are you downgrading? Unless you have a particular piece of software that you HAVE to have that doesn't work on Vista, you shouldn't downgrade. Windows XP is outdated, and very soon won't be supported by Microsoft. So unless you have some overwhelming need to have outdated software stick with Vista.
Having said that... If you still want to go ahead with a downgrade to XP, first you'll need a copy of Windows XP and a serial number for XP.
(Note, everything on your computer WILL be erased so make sure you do your backups before you continue!!!)
1) Put the Windows XP CD in your computer and restart it. If your computer is set up to boot from CD, it should start automatically.
2) "To setup windows XP now press enter"
3) Agree to the licensing agreement
4) Choose whichever drive you want to install Windows on and press enter
5) Choose "Format the partition (Quick) and press enter
6) Press "f" to format the drive
7) It'll do the install then after a reboot it should show Regional Option, click next
8) Put your name in and click "Next"
9) Enter your 25 digit product key (Windows XP Key) and click next
10) Enter whatever you want for your computer name. It could be "Desktop" or "Laptop" or "Family System" whatever you like. If you're installing XP Professional, you'll also see a spot to type in a password to get into windows. You can leave it blank if you're the only one using it, or password protect it so no one can get in. (Then Press Next)
11) Make sure your Date/Time and Timezone is correct then press Next
12) "Typical Settings" next.
13) (IF XP PRO) Choose "No" then type in WORKGROUP
14) It should start windows after you've done those steps and you can register with Microsoft and create additional users at this point (All self-explainitory).
You might want to print this out if you're going to go ahead with the install.
Oct 24, 2008 | HP Pavilion dv4000 Notebook
How to make Vista to recognize my old Hard drive
There are normally only two ways to get vista to recognise large drives and that is to format it within windows by way of right click my computer then click manage and then highlight your harddrive right click and select format. The other way is if your drive isnt being recognised because of the bios and needs updating, as most bios chips did when upgrading to vista.
Jun 18, 2007 | Microsoft Windows Vista Business DVD...
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
