Question about Fujitsu Siemens LifeBook S-6000 Notebook
Operating system not found
Laptop siemens fujitsu says operating system not found i have inserted recovery dvd the it ask me to insert drivers dvd which i did then i asks me to select a file what file do i select
    Habit-Forming:
  • 62 Answers
Open the laptop you find the reservoir from the Hard Disk / hdd pull outward and return again to you as the hard drive is logged
Posted on Jul 21, 2009
How to format hard drive Pi2515
No need as when you boot from the disc there will be the option for a clean rebuild which formats the drive.
Follow the prompts.
Dec 04, 2017 | Fujitsu Siemens Computers & Internet
My son put a fujitsu siemens recovery disc into his emachines d620 laptop now when i log on it asks for a fujitsu siemens activation key which i dont have or want so i have to use laptop with reduced...
Do you have the eMachines recovery disc? If so, then you need to enter the bios of the laptop by pressing a speciffic key at the start of the boot process. It should tell you what key to press in the POST. Most likely across the bottom of the screen somewhere. The F2 and F10 keys are popular as well as the Delete key. Once you get into the BIOS, Locate the menu containing the boot sequence. Make sure to set the CD/DVD drive as the first boot device. Save the changes and exit the BIOS. Put the Recovery or Windows CD/DVD in the drive and follow the on-screen instructions.
Mar 17, 2011 | Computers & Internet
must be virus' job. insert ur operating system cd/dvd in the cd/dvd rom and restart ur pc. press a key to boot from cd when asked. then repair os using recovery console. if the problem still persist then re install windows
Jan 12, 2010 | Computers & Internet
OPERATION SYSTEM NOT FOUND
You must of handled to motherboard incorrectly and possibly fried the SATA/PATA controller, usually found on the North or south bridge. My friend had the same problem, leaving the motherboard useless. IF this is a laptop your screwed (I.E. motherboard is junk). If this is a desktop you can either replace the motherboard OR you can buy a SATA/PATA card that inserts into the PCI/PCI-E slot to create a place to plug your hard drive in. Hope that helps.
Jun 04, 2009 | Fujitsu Siemens Computers & Internet
The Problem is when i turn on the laptop system operation not found is written on the screen.
More than likely, your hard disc is gone, or a virus has corrupted your Operating System.
Try inserting your Recovery CD into your drive, and then boot from that disk for a restore. You'll probably lose your files.
May 28, 2009 | Fujitsu LIFEBOOK E351 (FPC030171) PC...
Screen is black saying no operating systems
You may have a corrupted master boot record on your hard drive. If you have your original operating system CD insert it into the disk drive and see if it will start. If so let it run and eventually it will ask you if you want to install your operating system or fix it. Choose the "fix" option. This may get your master boot record fixed.
Dec 21, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Restore factory settings on a fujitsu siemens amillo pro
You should be able to fix this simply by inserting the original Cd that came with the computer and following the onscreen instructions.
Or the startup disks (if created) when you first used your laptop.
Alternatively If you do not have the one that came with your computer then you should be able to purchase one from ebay quite easily, and then insert it and follow the onscreen instructions.
I hope this helps you, Chris
Nov 03, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Delete everything off
See the instructions below from the support website - you need the discs that came with your laptop. If you do not have them, find an OEM copy of your systems operating system and install. Be sure to download and install all driver software from the Fujitsu Website.
http://support.fujitsu-siemens.com/
Restoring operating system
Using the ”Windows Recovery CD" and the ”Drivers & Utilities CD", you can restore the operating
system of your notebook.
All hard disk contents are deleted during operating system restoration. After this, operating system,
drivers and software utilities will be reinstalled. For this reason you should try to save important data
to a backup medium before you restore the hard disk contents.
► Insert the "Windows Recovery CD" into the optical drive.
► Switch the notebook on.
► Follow the instructions on the screen.
i
Detailed PC knowledge is required for manual partitioning.
You must then reinstall all the drivers. Use the "Drivers & Utilities" CD provided.
Jun 12, 2008 | Fujitsu Siemens AMILO Pro V1000 Notebook
On my Windows 7 laptop, I have got "Operating System not found" error. to fix problem, Windows Boot Genius helped me finally!
Mar 15, 2008 | Gateway M305CRV Notebook
Fujitsu Siemens LifeBook S-6000 Notebook Logo
509 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
