Question about HP LaserJet 2100 Printer
HP2100 laserjet won't print inserted pix in Word 2007 doc
When trying to print a Word 2007 doc with inserted pictures the text prints fine but the pix come out looking like bar codes!
Any suggetstions?
Rod
  • rodsalter Dec 19, 2008
    This web site is crazy!
    I ended up fixing this problem my self (posted my own solution on the web site) and I still keep getting asked if I have found a solution! I am also being asked to rate the solution. Let me tell ya, it is real good!!!!!
    The only solution I received from the web site was a dud!
    Pity the administrators of this site didn't keep a look at what was happening!
    Rod Salter
  • Anonymous May 05, 2009
    I have 2 printers and can't get Word 2007 text/picture box to print.
I ended up fixing this problem myself.
I needed to set the printing resolution in the HP printing dialog box to 1200 x 1200 dpi as the HP2100 can print at this resolution.
Select: Print/Properties/Advanced/Graphics. Then set the printquality to 1200 x 1200 dpi.
Rod Salter
Posted on Dec 16, 2008
I have a iMac G5 with 10.4.1. I try to print coupons on my hp laserjet 1320 and they stay in the que. Word docs print fine but any time i try to print any kind of coupon from any site, it messes up the...
If you are printing PDF coupons, that is probably the case, you need to upgrade the memory on the printer if you want faster printing on those types of documents.
Mar 22, 2011 | HP LaserJet 1320 Printer
Printing only every other line in Word 2007 doc
Dear pony, it could be because you might have changed your print settings.
You can press CTRL+P to change settings
You might also select the text you want to print and print selected.
You can also format the text by going into formatting options of MS word.
This can be because you've put the number of copies to 2. Thats why its printing again. Change it to default and it should fix your problem
If that has helped you please press 'fixya'
Nov 30, 2007 | Microsoft Office Professional 2007 Full...
Config page in hp2100
On the LaserJet 2100, press the Go and Stop buttons together, then let go, and the configuration page will print out. (You may have to hold them down for a couple of seconds.)
For configuration page instructions for other printers, see the How to Print Configuration Pages web site.
Sep 08, 2010 | HP LaserJet 2100 Printer
My printer is hp laserjet cp 1515n. After printing some documents it writes "printing cool down mode" and begins working very slowly. Please help me
1515n - I have the Magenta colour 'shadowing' the blue test. A mirror image of the blue text. [slightly staggered] Black is fine. Applies to all Word docs when printing in blue - can you help please?
I only use genuine cartridges.
Thanks
Jules Radstock
Jul 23, 2010 | HP LaserJet CP1518 Printer
HP2100 aaargh!
Click on "control panel"
select "printers"
Do you see (hp2100) your printer?
If NO, it is NOT installed correctly.
If you DO see it, RIGHT click on it and select PROPERTIES
The GENERAL tab will show if it is working properly
Click on the Tab labeled DRIVER, and you will see an option to UPDATE DRIVER-click that.
Another way to view your printer is go to
CONTROL PANEL
then select SYSTEM then select HARDWARE
then select DEVICE MANAGER- (this will show everything-all your hardware and peripherals)
Look for IMAGING DEVICES and click on the "+"
Do you see your (hp2100) printer?
NO-not installed
YES-(but if there is a yellow triangle here it indicates an error)
RIGHT click on printer, select PROPERTIES
select DRIVER, click on UPDATE DRIVER.
You may need to restart.
Let me know how this works.
Hope this helps.
FYI : Xp does come with drivers, but they may be outdated, hence your problems.
Jan 14, 2010 | HP LaseJet 4350dtn Laser Printer
Laserjet 4 plus not able to print graphics
try the lj4 not plus or the lj5 these have always worked fine for me if problem still persisits do a printer test print from the menu button on the printer to make sure that the issue is not a printer formatter board
Regards Al "alstech"
Jun 11, 2009 | HP LaserJet 4 plus Printer
HP OFFICEJET PRO K5400 - COMMISSIONED FRIDAY OCTOBER 17 1) TODAY OCT 21 PRINTING PDF DOCS TEXT WITH COLOUR PICS, PRINTED SEVERAL COPIES OK, PRINTER STOPPED PRINTING THE PICTURES. AFTER SEVERAL ATTEMPTS...
Try this !
in the software application you are printing from
Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
Look for a Best Mode Setting
this printer has several modes one being draft mode, another one best mode
in best mode the printer uses memory to render the photo you are trying to print.
Note that in this mode, printing takes
longer and more memory is required from your computer.
from page 17 of the hp k5400 user manual
Also you may have to increase the virtual memory of the windows pc to allow the computers hard drive to allocate more hard drive memory to the memory swap file if the computer's ram is not enough to print the photo.
It is a setting in the control panel under system - performance.
May 12, 2017 | HP Office Equipment & Supplies
Won's print pdf files
Trouble with the HP Laserjet printed output may be solved by using the following settings (or similarly named ones): "Use raster Graphics" (instead of "Use vector graphics"). This may fix the problem of "reversed" text (white on black background) not printing, as well as other problems. "Download TrueType Fonts as bitmap soft fonts" (select "bitmap" instead of "outline" or "graphics"). This may remove the overlapping of text on the printed document. "Graphics dithering" select "coarse" or "fine" (instead of "none"). This selection may improve the quality of images contained in the document. You can find all these settings in your printer properties. Go to File, Print, click Preferences, in Printing Preferences, click one by one all the top options, and change one of the top solutions, one at the time, checking your printing output. Always check if you have the latest version of Adobe Reader Program. If not download the latest version from Adobe, it's free. Is this the first time that you have the problem? or with the same printer (HP 4si), did you were able to print PDF files in the past?
Sep 10, 2007 | HP LaserJet 4si Printer
HP LaserJet 2100 Printer Logo
142 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
