Question about Dell Inspiron 6400 Notebook
Right hinge coming apart
I have a dell inspiron 6400 and have recently noticed the right hingle coming aprt. the screen is not stable and flops back. Can this be fixed??
    Scholar:
  • 46 Answers
Maybe.
This is a normal wear and tear issue with Dell lappys.
You can take off the hinge cover (it's just above the keyboard) and attempt to tighten the hinges down.
If that doesn't work, then the hinges themselves are wearing out, and need to be replaced, so you'd have to contact dell in that case buddy.
To remove the hinge cover, find where there is a small notch or space to the right of it and put a VERY small screwdriver in that notch and pry it up. (MAKE SURE that your LCD panel is completely flat aka. completely open when doing this).
Once it pops out (it takes a little muscle, don't worry it's made of plastic it shouldn't break) then you can keep prying it up until it all just pops out. Now using a phillips small screwdriver (cross head) tighten the hinges (they'll be easy to see along with their screws).
Then, simply replace the hinge cover the same way it came off, put it into the laptop at an angle upwards going into the left side this time, and then just begin to press it downwards until it pops into place. Do this all along the hinge cover from left to right this time.
There! hopefully that helps, but even if it does the hinges will NEED replacing, the dell ones are cheap, and eventually do need to be replaced.
Posted on Dec 15, 2008
  • Michael Tracey
    Michael Tracey Sep 22, 2010
    these hinges are ****. the back part of the hinge is attached to the alum. bit around the screen with some extruded bits of the diecast used as rivets to attach. these pull out of the alum. or break. tightening the screws does nothing. . bad design . dell would be well aware of this design defect.. you can drill right thru the diecast and thru the alum. behind and then thru the plastic back cover. longer screws with washers and nuts will then produce a permanent repair..
    have photos etc. if you want. cost, apart from your time , is minimal and the hinge is stronger and better than any new replacement. new hinges will cost about $90.00 and still have the same defect
My dell inspiron 6400 has small horz line on screen
If you have tried this with an external monitor (and the line is not there)
then the problem is either the connection on your display cable or (more likely) a fault on your LCD panel. If it's still under warranty I would let Dell take care of it.
If you want to do it yourself, you need to get a replacement LCD panel, take the screen apart (the top half of the laptop) and switch out the LCD panel. Some small Phillips head screwdrivers are required, the screw heads on hinges etc. are tiny.
While this is not an overly difficult process, it may prove daunting to some people. Most computer repair shops like mine would charge $30-45 for labor on this plus the part, which according to ebay will run about $75. Make certain you get the correct size, as there was a 14.1" and a 15.5" model (They are not interchangeable). Screen size is measured diagonally across the actual screen and does not include the trim.
Nov 21, 2011 | Dell Inspiron 6400 Notebook
I have a dell inspiron 6400 and im getting a black screen once the dell logo comes up and windows xp loads...I see no icons or nothing..just a black screen
it sounds like your display backlight has gone bad. If your handy you can get a new display. If you are really good you can replace the back light.
Nov 07, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 battery won't charge
Remove the battery use a old toothbrush and clean the connectors on the battery as well as the connector to the motherboard.
Good luck
Aug 28, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron screen coming off at hinges
It's a common problem with Dell Inspiron 1501 / 6000 / 6400 models. So tighten all screws on the bottom, on the back (where power cable connects), then remove cover on top of the keyboard and tighten screws there, then remove screen bezel and tighten screws there - here is how:
http://support.euro.dell.com/support/edocs/systems/ins6000/en/sm/display0.htm#wp1020174
then put everything back.
Aug 05, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6400 screen is fading
Sounds like the backlight is going out. Youĺl need to replace the LCD screen. You can find them on ebay. Just make sure you purchase the correct one for your laptop. You will need to take out the screen to see who makes it and the number. Go to dell.com/support to find your manual, if you feel like you can do it yourself.
Good Luck!
Apr 04, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400, asking for HDD password
Insert OS cd in drive and start reinstalling by selecting repair mode now once all files are loaded system will reboot when you see the Installing Devices progress bar, press SHIFT + F10
this will give you access to your account also you can reset all passwords
Now restart lappy and let the system boot normally without OS cd in drive
now you will come to old screen and previously configured desktop with all intact aplication and icons on desktop and it will no more ask you for password till you set a new one
Thanks and regards
Kindly rate this solution
Gaming problem for dell inspiron 6400 i get error
The prooblem may be that you have to install the latest DirectX or you install you graphics cards NEWEST drivers. You can download the drivers off the net, its no big deal. Just google it and you'll find exactly what u need.
Mar 26, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 screen problem
I had the same problem. You need a new graphics card.
Jan 08, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6400 Notebook Logo
2,599 people viewed this question
Alun Cox
