Question about Canon Office Equipment & Supplies
Canon I560 will not turn on
Printer failed to turn on next time I used. Push power on button ...nothing. Checked power supply and fuse is OK. Instead of 24 and 27 volts on line, you have AC and DC of around 10-12 volts each.
Printer head has bad place on bottom...like tear or burnt of foil. I get a new printer head and install. Still nothing.
SOURCE: canon printer mp160 error msg 16 (e16) after replace catridge
please help about error mp145 cz my mine damage
Posted on May 26, 2008
SOURCE: Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Aug 12, 2008
SOURCE: Cannot remove the print head from canon i560
try this - open cover on printer
on the right side of the cartridges is a grey arm - lift it up
remove all ink cartridges.
then remove print head.
Posted on Mar 08, 2009
e-ware
  • 776 Answers
SOURCE: Do I need a new print head?
1. Turn off printer
Posted on Sep 13, 2009
  • 5 Answers
SOURCE: my printer power wont turn on when i press button
Try removing your printer cartridges and then the print head from the printer. If the printer powers up with the print head removed, then the print head is either shorted or clogged. If it's shorted out then you will need a new print head (usually cheaper to just buy a new printer). If you can clean the print head without damaging it, sometimes it will work again. Usaully a good 24 hour soak in alcohol or a cleaning solution will work.
Posted on Jun 06, 2010
I have a Cannon i560 printer and the light on printer flashes five times orange then flashes green, what is the problem and how can I fix it.
1. Turn off printer
May 18, 2011 | Canon BubbleJet i560 InkJet Printer
I have got Canon i560 printer but not recieving print order the software is loaded what is the solution ?
Try i560 Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Pl let me know if this works
Nov 12, 2010 | Office Equipment & Supplies
When I turn on my Canon i560 printer the light blinks orange and green and will not print anything. I've tried to turn it off and on, unplug it and nothing seems to be working. What can I do to fix it?
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Canon BubbleJet i560 InkJet Printer
The waste ink well is full
Reset Procedures for Canon i560 Printers
  1. Turn off i560 Printers
  9. Please remember at some time of other you will need to clean out the ink pads that are inside the printer.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 22, 2010 | Canon BubbleJet i560 InkJet Printer
Printer quit printer will not come on
Jan 28, 2010 | Canon BubbleJet i560 InkJet Printer
The orange error light is flashing 5 times in between the green light.
Jan 27, 2010 | Canon BubbleJet i560 InkJet Printer
Our i560 suddenly will no longer turn on
Sure it is, try removing the inks and then the printhead. If it will power up with them out, you need a new printhead. Don't put the old one back in as you could fry the logic pcb. The printhead part number is stamped on the side.
Nov 03, 2009 | Canon BubbleJet i560 InkJet Printer
1. Turn off printer
Sep 13, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560 printer will not turn on, despite power. Is there a reset bntton or combination that may make it possible or is it a short life product?
Have you checked the fuse on the power cable? Have you tried another power outlet and changed the power cable?
If you have the chances are the power supply unit in the printer is faulty. It may have an onboard fuse that has blown or maybe the PSU is fried.
Jul 16, 2008 | Canon Office Equipment & Supplies
Canon i560 printer
1. Turn off printer
May 28, 2008 | Canon BubbleJet i560 InkJet Printer
73 people viewed this question
Clive
Clive
old marine
old marine
