Question about Dell Pentium 3, 500 MHz Pentium III Processor Upgrade
How can I do to connect pentium 3 ID board with sata hard disk?
I have a computer and i like to change the hard disk but the hard disk that i bought is sata so what can i do?
  • 107 Answers
Return it and buy and IDE or buy a PCI sata controller card
Posted on Dec 15, 2008
How do you traqnsfer files and programs from an old computer to a new computer?
How old is your machine?
You can use this method Hard disk to hard disk copying by IED board connect ,
If your new computer has both SATA & IED connector connect your ol hard disk to the to new PC HD connector .
Todays computers have SATA type connectors for hard disk/dvd roms .
2) Flash disk
Dec 11, 2017 | Computers & Internet
I have a pavilion 7110Z and want to relace my hard drve.First I have to remove the old one. How do I get to it??
Its a easy thing you can do it.
1.Open your PC cashing.
2.Remove power and SATA /ID cable from your old Hard Disk.
3.Then remove it from your pc.
4.Add new Hard disk.
5.Connect the power and SATA/ID cable to your new Hard Disk.
Work done.
Thanks for using FixYa.
May 25, 2011 | HP Computers & Internet
The asus p4bg-vm mother board is not recognising the hard disk at times - think I need to update the BIOS
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 16, 2011 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Why do the board doesn`t detect the hard disk?
check your sata cable or IDE cable for your hard disk and double check your power supply if its connected properly
Oct 06, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have a k8upgrade vm800 motherboard. I want to install a sata hdd for storage only but the bios is not seeing the sata connection. Is there any soloution to make this possible or are the sata connections...
Is the drive initialised ... if not it will not exist on your system.
1.1 Serial ATA (SATA) Hard Disks Installation
This motherboard adopts VIA VT8237 southbridge chipset that
supports Serial ATA (SATA) hard disks. You may install SATA hard
disks on this motherboard for internal storage devices. This
section will guide you to install the SATA hard disks.
STEP 1: Install the SATA hard disks into the drive bays of your
STEP 2: Connect the SATA power cable to the SATA hard disk.
STEP 3: Connect one end of the SATA data cable to the
STEP 4: Connect the other end of the SATA data cable to the
chassis.
motherboard's SATA connector.
SATA hard disk.
Nov 25, 2017 | Asrock K8Upgrade-VM800 Motherboard
Motherboard : ASUS P5GV-TMX Which hard disks does this motherboard support? It came with sata-I hard disk. Recently i bought a sata-II hard disk bt it is giving some problems..to be specific on windows it...
Yes, it can be causing a problem. You have 2 hard drives that are working at 2 very different speeds. The computer is having to do a translation and adjust rates of transfer between them on top of having to do the read and writes between them. Will SATA II will be backwards compatible to SATA I it won't work the other way. If you have to keep these drives, I would make the SATA II Drive the primary and SATA I drive the secondary on a different channel if possible. The SATA II drive is teh faster drive and should be your main.
Oct 09, 2009 | ASUS P5GV-MX Motherboard
Sata support?
the easiest way to know this is opening up the computer with a philips screwdriver and verifying if you can see S-ATA ports on the system board. They look like the red and black connectors on the following picture: http://www.pcper.com/images/reviews/98/board_sata.jpg
if you can see those connectors, your system supports it. in that case, you just have to connect the disk (don't forget to connect a power connector as well, these connectors are mostly black)
Jun 22, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Computer died. Need to do data recovery of SATA hard disk.
Hey Edward,
Use a SATA external hard drive enclosure (listings for the device on ebay) to connect the disc to a USB port on your other machine and transfer any data off of it.
You can find these devices locally also but you can pick them up on ebay pretty cheap.
Apr 20, 2009 | Computers & Internet
Sata, ide
Update: SATA II drives do have jumpers to make them backwards compatible with 1.5 Gb/s (SATA II drives are 3.0 Gb/s). So if your system is older and can only handle SATA (first Gen) then you have to add a jumper (Seagate has the jumper setting on the drive but sometimes supplies no jumper i.e. you have to have your own).
Sep 30, 2007 | Computers & Internet
Dell Pentium 3, 500 MHz Pentium III Processor Upgrade Logo
611 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
