Question about Maclaren Quest Sport Stroller
Broken brakes - Maclaren Quest Sport Stroller
Sorry I dont need the assistance any more
Posted on Dec 18, 2008
The passenger rear brake makes a thumping noise when pushing the brake
Drums brakes. This could be an adjustment problem or a spring has broken. Slack adjusters do lock up from brake dust or rust.
Rotors. This could an adjustment for the E brake shoes, Or the pad has broken off the shoe. Also if a bolt broke or came out of the caliper.
Mar 03, 2016 | 2007 Mazda 3
How too release the emergency brake foot pedal when the cable is broken?
About 73,400 results (0.87 seconds) Search Results
    Parking brake release cable snaps - Chevy Avalanche Fan Club of ...
    chevyavalanchefanclub.com > ... > Problems: Brakes
    24 posts - ‎16 authors
    Went to release the parking brake on my 04 and the cable snapped. ... More like the end cap coming of the cable that attaches to the foot pedal. ..... Then I released the parking brake, pulled out the broken release cable/handle assembly, ...
    How To Install Repair Replace Parking Brake Release ...
    ? 5:54
    https://www.youtube.com/watch?v=qx0oGfV62NQ
    Jun 23, 2011 - Uploaded by 1A Auto Parts
    How To Install Repair Replace Parking Brake Release CableHandle ... or replace a broken or worn out parking brake release cable handle.
    Emergency Brake Pedal Assembly & Stuck Brake Cable ...
    ? 10:13
    https://www.youtube.com/watch?v=0jYfvthBzhU
    Apr 17, 2014 - Uploaded by corgLLC
    Emergency (Parking) Brake Pedal Assembly & Stuck Emergency (Parking) Rear Brake Cable The emergency ...
    E-Brake Cable Broken? Stuck Emergency Brake... Help Please ' Chevy ...
    www.tahoeyukonforum.com > ... > Engine & Drivetrain
Jan 25, 2016 | Cars & Trucks
2005 dodge 2500 diesel it has a new brake controller. trailer brakes work when you push the controller manualy but trailer brakes don't work when you push the brake pedal
there is likely a wire that goes from your brake pedal switch to the trailer brake controller this wire is probably broken or not hooked up. if it is hooked up and no wires are broken I would start making sure everything is hooked up right.
May 28, 2015 | Dodge Ram 2500 Cars & Trucks
My brake lights stopped working. I checked fuses and light bulbs. Still no brake lights.
Check for a switch on the brake pedal lever, the switch makes the brake lights work.
Sep 30, 2014 | 2001 Ford Expedition
My break pedal goes to the floor
There are several causes for the brake pedal going to the floor:
- Broken seals in brake`s principal pump.
- Broken seals on rear brake's cylinder. (big lieak on wheel)
- Worn rear brake shoes, making seal travel out of cylinder. (big leak on wheel)
- Leak on tubings.
- Empty brake fluid deposit.
Nov 10, 2013 | 2001 Hyundai Accent
My hyndaui Veracruz started making a scrapping,grinding metal on metal sound from the back,,,any ideas???
Lots! Could be a loose piece of metal scraping on a wheel rim. It could be a cracked or broken brake drum. It could be a broken brake shoe inside the brake drum. It could be a broken brake spring inside the brake drum. It could be a bad wheel bearing inside a rear wheel. Enough?
Jan 09, 2013 | Cars & Trucks
My saturns e-brake stoped working and wont stay up how can i fix that?
if you mean the parking brake, sounds like you have broken a cable. the cables keep tension on the handle and without that tension it won't stay up. also the broken cable would mean no parking brakes. if however the parking brakes work when you pull and hold the brake handle, then you have a broken part in the handle itself. you will need to get under it to figure out which cable is broken and replace it. the heat shielding may make this hard. I think the parking brake system is made of three separate cables, you can buy new ones at autozone, advance, ebay. stay away from dealers and used parts on this repair.
Mar 13, 2010 | Saturn SL2 Cars & Trucks
Broken Brake line at the bend
rusted or broken? if its broken thats a design flaw. you should be able to route new line without dropping fuel tank.
Oct 14, 2009 | 1999 Ford F350 Regular Cab
Maclaren Quest Sport Stroller Logo
143 people viewed this question
Top Maclaren Baby Gear Experts
Jennifer Rock
Jennifer Rock
xxxxxx xxx
vanyell
Are you a Maclaren Baby Gear Expert? Answer questions, earn points and help others
