Question about Epson C64 InkJet Printer
Printer not printing
The black ink ran out and I replaced it. It will not print now..... did the trouble shooting and still nothing. Is it dead?
  • 2 more comments
  • teresa silly Mar 19, 2007
    thank you for all the help and advice. I felt like I was kinda lost...:) I could relate to the other question specifically this one:
    "My Epson Stylus C64 was working fine, but when I tried to print yesterday it went thru the motions of printing but the paper always came out blank. I installed all new cartridges and also cleaned the heads many times but nothing works. It acts as if it lost its brain. I also notice that it used a lot of black ink during the cleaning. I also ran all the tests and nothing was printed out at all after cleaning the heads"
    I feel that this is my problem and probably will just go out and get a new printer due to the fact that it is about 2 years old. I just will not get this brand again:)
  • simonbayes Nov 28, 2007
    i bought a new cartrige for my 4255 and now it only prints the test page, and i have 3000,€ worth of invoices to print, what can i do
  • Anonymous Jul 31, 2008
    Replaced black cartridge, black will not print other colours do. Tried head, nozzle cleaning still not working
  • Anonymous Aug 27, 2008
    will not print in blue heads cleaned
  • Epson Master
  • 705 Answers
It's probably not dead. Are you using compatible cartridges? If so have you removed any tape that covers the vent hole if required. Many compatibles need to have a piece of tape removed. If you forget the ink cant get out as the air can't get in. If it not a piece of tape and there are no flashing lights it could be that the nozzles are blocked or the wick has dried out. You can do a manual cleaning using some kitchen paper and a little solvent and a small plastic bag. The first thing we need to do is get the head away from its parking position. Switch on the machine and when the head has moved away from its park position, remove the power lead. With the top of the machine open, you should be able to move the print head carriage by hand. Look to the right where the head carriage is normally parked and you should see the pump cap area. It will be a black looking spongy pad covered in ink. Now take a piece of kitchen paper and fold it over a couple times to make a pad approx 3"x1". Now lay this pad over the top of the pump cap and fold the left edge down toward the base of the machine as in image one (the tissue is the yellow bit in the image) Now take a syringe or similar and put some solvent into it. The solvent I use is JR Ink Jet Cartridge flush as seen on ebay and the like. If you have any ammoniated window cleaner like Windex you can use this. Put the solvent onto the tissue making it quite damp, but not totally soaked. Manually move the print head GENTLY back to its park position. The pump cap will try to raise up to meet the bottom of the print head as you move it back. Be careful no to force it or you may break something. What we are trying to do is bring the solvent dampened pad into contact with the print head. Once located, leave the pad for 5 or 10 minutes whilst the solvent does its trick. Now move the head away from park - again being gentle. You should now see the pad is a horrible black lump of mush. Pick it out and put it in the plastic bag ? where a glove or use tweezers or pliers. Repeat the process again but this time let it to soak for just about 1 minute. You should now see the individual ink colours soaking into the pad. If the pad is still black, repeat the process a couple more times. Once you have some evidence of the individual colours you can run a head clean via the driver or printer control panel. Then print a nozzle check sheet and if all has gone according to plan you should have a full complement of lines. This method is applicable ONLY for loss of a few lines on the nozzle check sheet. If you have loss of all the lines in a single or multiple colours, you need to investigate further. It is possible that the pump has failed, the pipes are clogged or something else is causing the problem. If that does not sort it out, tru using a syringe to put a couple of drops of solvent onto the wick. Its the black plastic spike that stick up and goes into the bottom of the ink cart when it is installed. Put a cupole of drops in, put the cart back in and leave it fpr about 10 minutes. The re-try a head clean using the driver/status monitor. There is another possibilty after thsi which relates to a hardware problem but this generaly causes a loss of all ink. Let me know how you get on
Posted on Mar 18, 2007
Hello Inky;
I'm having the same problem with my C88 printer. But it used to print and suddenly, it started printing blank pages but it's going through the motions like it's printing, but it's just a blank page. I've tried taking the printer apart, looking at the waste pad (but figuring it couldnt be this because it didnt give the blinking lights) and figured it must be something under the print head where the cartridges are put in like you said. But i was wanting to know is there a diagram or a drawing that shows where that pump is located at. I know when you turn the printer on, it moves back and forth and then goes back toward the right-like it's resting place or parked. Do i need to turn the printer on and have it move toward the left and stop it and then put the paper and go through the process you mentioned to see if that helps.
thanks and would appreciate your help very much.
PC detail!
Posted on Oct 30, 2008
  • 2,071 Answers
Take out the nozzles and take out blockage and take it back..
Posted on Jun 29, 2008
Color cartridge won't print
sounds like when your in the print page, go to layout to either print in black or in color. i'm sure you've done this already but thought i would mention
also try this, take out the color cartridge and put back in. turn off all systems and turn on again to see if it reconfigures.
lastly, HP has an awesome web site for trouble shooting, check this out.
hope this helps and good luck
Apr 29, 2010 | HP PSC 1610 All-In-One InkJet Printer
Janky printer
Please click here and follow the steps to resolve the issue. Though it shows different product the trouble shooting steps remains same.
May 21, 2009 | Office Equipment & Supplies
Problem with One Color (Yellow) not printing on Epson R280
Hello sir; Why don't try to press "resume" key before you print.
Apr 17, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Won't print black ink.
Called kodak support and they sent me new printer heads.
Jan 27, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer dont print black
You might not have cleared the clog out enough, you might not be able to fix that issue. Have you tried a Clean and wick?
Jul 29, 2008 | Lexmark X1240 All-In-One InkJet Printer
Can't I print with only one black ink
I have a similar machine ip5000. Currently have a problem getting the big one to print and have posted for a solution elsewhere. If I print withjust the small tank it does some black work i.e. type but it needs the other big tank to give full photo pictures.
If you are just looking to print typing try changing your font collour to a dark blue or other. This gets round the black problem but you will need the 2nd black cartridge for full colour work.
Hope this helps.
Mike
Mar 07, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Ran out of black ink
The manuals,online guide and trouble shooting sections could help you resolve your problem. Contact support has a chat facility on some pages that may help.
Click this Link
Under Select a Product Range
Choose Stylus C45 on the webpage
Under Select an OS
Choose the operating system1.gif on the machine where you will install the printer on the webpage
Click Confirm Selection
The manuals and documentation link will allow you to download manuals that were on your CD ROM
you may want to bookmark the online guide, if present, to help with future problems -- that probably was not on the CD
Click the back button on the browser
click the Drivers and Software Link
This allows you to download software files that were probably on your installation CD
Click the back button on the browser again
Trouble Shooting and Contact Support could be an interesting link in the future too when and if you have problems.
I hope this helps
Dec 13, 2007 | Epson Stylus C46 InkJet Printer
Printing problems
Are you using remanufactured cartridges? If so, I would strongly recommend that you replace with factory HP cartridges.
Apr 17, 2007 | HP DeskJet 920c InkJet Printer
Epson C64 InkJet Printer Logo
3,280 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
