Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Error message f-01 on hotpoint ultima wt741 washing machine
Does anyone know what error message f-01 on the hotpoint ultima wt741 washing machine means and how do i fix it?
  • Anonymous Mar 25, 2014
    drum overflows
    President:
  • 373 Answers
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
Wt741 machines drum
It is possible the motor start capacitor has failed. Unless you know how to test it, call a service person.
Oct 19, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima WT741 washing machine not working flashing F-03
F03 - Wash thermistor open/short circuit need a engineer out to fix it. hope this helps.
Mar 27, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpopint Washing Machine WT741 flashing F-12
Resolved the problem.
Switched off the power to the machine. hit the on /off button and the f-12 error code disappeared .
On reappling the power to the machine the orignial programme continued to completionj
Jan 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
F03
Good morning.
Error code F03 means that the wash thermistor is open circuit, this means that the water is not getting hot.
You need to fit a new thermistor first of all, if that does not solve the prob, then you will have to fit a new heater element as well.
You will normally find the element and thermistor located at the rear of the m/c.
Access it by removing lower rear panel
To get the parts, go to-----www.hotpoint.co.uk
Plz rate my solution.
Thanks.
Jan 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Hotpoint Ultima WT741
if it wont drain check the pump for any blockages and working condition
Sep 17, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
2,588 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
