Question about LG enV VX9900 Cellular Phone
Ive put my phone on the charge, but it isnt charging, whats the problem? my env cell phone isnt charging when i put it in the charger
    Problem Solver:
  • 12 Answers
Your port could be messed up or it could be the charger. Take it in to verizon and they will look at it for free.
Posted on Dec 16, 2008
My LG enV will not charge. The actual part that you put the charger in wobbles and is unstable. I do not believe that there is anything wrong with the charger. I have tried moving it around to find a...
The charging port has broken off the main circuit board.
You will need to have it repaired by your service provider.
There is no other way to charge it.
Thanks!
Aug 04, 2011 | LG enV VX9900 Cellular Phone
I have a dead battery in my lg envy and my charger wont charge my phone but that same charger will charger my sisters phone. How can i get my phone to charge?
try your sisters battery on your mobile. if it powers up and your charger isnt working on your mobile then you have an internal loop fault in the power section of the mobile that directs power to charge the battery. its a big fault and is far cheaper to replace the phone than to have it repaired.
sorry
take care.
Aug 03, 2010 | LG enV VX9900 Cellular Phone
My phone doesnt charge
Your phone doesn't charge? or does not hold a charge?
If the battery meter is not running when ur charger is plugged in, it could be a charging port problem or a battery problem. Go to a nearby shop to have someone try another battery & to determine if that is a battery or a phone problem. If it's the battery then buy a new one. if it's the phone, have a Samsung tech repair it for you
Dec 15, 2009 | Samsung S3500 Cell Phone
Wont charge
your charging port is loosely connected to *********** board. You need to go to a repair shop and get it fixed.
Apr 18, 2009 | Verizon Communications LG enV Cell Phone -...
My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
Sep 06, 2008 | LG enV VX9900 Cellular Phone
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
Broken charger port
i have the same problem with my enV my friend stripped the wires to my charger at the part where you plug it into the phone so now to charge my phone i tape the red wire to the positive on the battery and the black wire to the negitive there will be a shiny metal goldish color thing (there like 4 lil gold bars) on your battery that looks like this --> (negative) | | | | (positive) | - | | | + | tape the wires on the outside were the symbols are - and + and try not to let it toch the middle bars on the battery or it wont work and dont cover the little bars up with tape put the battery back in the phone making sure the wires dont move to much and it should charge sometimes you got tape the battery onto the phone to make sure it doesnt pop out but its what i do and it saves you money on having to go buy a whole new one or if you know someone with the same phone give them your battery to charge it :)
Apr 18, 2008 | LG enV VX9900 Cellular Phone
My enV won't hold a charge
You said the new battery worked but wont charge in the phone. You had water damage to the phone before getting the new battery correct?
First remove any Mini S/D card in the phone, power it off and remove the battery. ( only do this if its out of warranty and nothing else works. ) Your need to take the phone apart and get some alcohol wipes and wipe down the circuit board and connectors and anything that may have had water on it, if you see any crude, try to rub it off, there may be water and crude built up on contacts from the water damage that may be shorting the phone. Also check the battery contacts for greas or crud on the contacts. Once you have wiped down everything the alcohole should evaporate and take any moisture with it. Leave it out for a day dis assembled so it can air dry completely.
Put phone back together and hook up the charger and see if it charges. wait to put the memory card back in as in case you screwed anything up, you dont want it to take out your memory card with it.
I have performed this task with many of my friends cell phone that have gone through washing machines or got moisture in it because they take there phones into a steamy shower and moisture ends up shorting it out.
If nothing else works and you want to try it, go for it.
remember theres 6 screws in back and 4 around the mainscreen that are covered with triangular sticky covers, then use a thin knife or something to pry from one of the corners, one it gets started you just have to pop it apart with your fingers. Everything snaps back together easily.
Be carefull on the side with the screens, you dont wanto to pop apart the front screen from the mainscreen as its a pain to keep together when putting it back, also dont get any dust or fingerprints on the screen as they will drive you nuts if you put it all back together and theres a greasy fingerprint under the plastic that protects the screen.
Good luck
Mar 21, 2008 | LG enV VX9900 Cellular Phone
Env help plz
The reason the phone won't charge is because the internal power port pins are broken off of their solder joints to the main board inside the phone. Wiggling it helps at first because the pins can still touch their connection points but after a short time that will cease to help. Google "cell phone repair". It usually cost around $50 to get it fixed with a new power port installed. Turn-around is usually 2-3 days.
Mar 05, 2008 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
82 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
