Question about Marantz PMD660 Digital Voice Recorder
I have a Marantz 660 - when I tried to download a recording the icon didn't come up on the computer- it did the first time and I was able to download but it didn't work the second time.
  • SaraBenI Dec 16, 2008
    Many thanks for trying. However still the same problem - no icon appears, no matter what I do! It 'pings' as if it's going to come up, then nothing happens. It was fine the first time I used it and I could download successfully.Don't know what to do!
Hi. I use mine with a Mac. The instructions say it's the same for PC. From the 'off' position, plug in the usb cable to the computer, hold down the 'copy/ usb' button and switch it on. The display will read 'usb' and the icon -"should" appear on the desktop. Open the folder and look for files with machine ID. Failing that, try new usb cable? or the techies favourite: "switch everything off and start again" LOL
Posted on Dec 16, 2008
I agree with the previous solution, but make sure that the 660 is plugged in, mine will only work when its powered!
Posted on Mar 02, 2009
Hi I would like a little help to update the firware dvd blu ray bd 8002 Marantz tell me how should I do? thanks you.
Hello
Enter these sites for fudate your Maranz.
www.buyblurayplayers.com/firmware-updates/how-to-update-your-firmware
www.avforums.com/.../765663-marantz-firmware-updates-sr7002.html - United Kingdom
softwaretopic.informer.com/firmware-update-tool/
I'll ge you some hints also
Open the Internet browser and navigate to the Marantz.com website. Select "Products," then choose "DVD Players."
Select the DVD player you are currently using, then select "Manuals and Downloads." This lists all of the available updates for the Marantz DVD player.
Click the software update to download to your computer system
Plug the USB flash drive into a USB port on the computer, then click "Start," "(My) Computer," then double-click the removable device icon. A window loads with all of the files stored on the flash drive.
Click-and-drag the software update into the open window, then close the window, right-click the removable device icon and select "Eject."
Disconnect the flash drive from the computer once the icon disappears.
Plug the USB flash drive into the USB port on the rear of the Marantz DVD player, then power on the device. The software update will upload onto the DVD player. A prompt on the television screen appears once the update has finished.
Mar 20, 2011 | Marantz BD8002 Blu-Ray Player
PMD660 Handheld Digital Voice Recorder: I have a Marantz PMD 660 digital audio recorder. T...
This implies that there is not enough current going to the device when running on battery (only back-light but no data) whereas running fine on AC means that the device board is most likely in a good operational condition.
I think maybe once a leaked worn battery which left forgotten inside battery compartment damaged the battery terminals or at least the wires connecting these terminals to the main board, i would recommend you to open and check on that.
Sep 23, 2017 | Marantz PMD660 Digital Voice Recorder
Cant get mp3 files from my marantz pmd620 to play on my mac
Well, try copying them to a folder on your computer. Also, make sure that the files are not proteced with DRM. If these fail, open iTunes. Select all of the MP3 files and drag them into your library. That should fix it.
Feb 04, 2009 | Marantz PMD620 MP3 Player
Marantz PMD 660 won't power up from batteries
I would suspect the battery tray connections are defective most likely due to a broken wire.
May 01, 2017 | Marantz PMD660 Digital Voice Recorder
Unformat
Just solved this very problem with the same machine.
1. Carefully remove the flash card and take a look to see if any of the connecting holes look visibly damaged.
2. If so with a birght light look inside the card port and see if any of the contact pins are bent.
3. With a thin scew driver carefully try to bring the pin back up straight and carefully ( not forcing ) replace the flash card.
Power up and see what happens. It worked for me.
I think our problem was caused by the purchaser either inserting the card the wrong way round or forcing it into te card port.
Once in, leave it there and just record and erase as required.
Good luck.
Oct 28, 2008 | Marantz PMD660 Digital Voice Recorder
Marantz PMD671 recorder - download problem
I need to know what model mac you have. This would help. Also what operating system you are using. Older macs may not be compatible unless you update the system. The latest macs with the intel chip work fine with this. Once quick solution is to update your software to the latest versions by going to your apple with your mouse in the upper left corner of your screen and then clicking it. Scroll down to the title software update. click that and then click update now. Check the boxes of all you want to update and then hit enter. *Note: you must be connected to the internet in order to make these updates. I would suggest being connected something faster than dial up.
After you have done your updates, try to reconnect the Marantz. Remeber to connect it first then turn it on.
Another solution is to format the card on your mac first by using a card reader and the program Disk Utilities located in your utilities folder. It is important to choose the Fat 32 format (You will see this in your pull down menu). Note: This will erase everything on your card.
If you have a card reader, you can always take the card out of the recorder and try to read it that way as there may be a communication issue with the mac and the recorder, but if it can be read on the PC and not the mac, I doubt that is the issue.
Aug 29, 2008 | Marantz PMD660 Digital Voice Recorder
Unformat
I have a PMD660 as well and from time to time a memory card will become "corrupted". During a recording last evening the battery ran out "prematurely" and when replaced, the 660 had the unformat error. Fortunately the card was readable in my Hummingbird card reader.
Normally when I have had UNFORMAT problems in the past I would just FORMAT the card with the computer and the 660 would then be happy with it. Not this time! The 660 still stubbornly displayed UNFORMAT! This time I ended up having to use Partition Commander to wipe out the partition on the card and then DISK MANAGEMENT in the XP's Computer Management program to re-create the partition and format FAT32. Normally when you FORMAT all data is lost so this would end all hope of recovering data from the card.
In the case of hoping to recover lost recordings I would have tried QUICK FORMAT and then tried to "recover" the data with a program like Partition Magic or Partition Commander or some other program that could re-link the blocks and create directory entries.
Jul 04, 2008 | Marantz PMD660 Digital Voice Recorder
Marantz 660 digital recorder
You might solve your problem by going to this site and uploading the recorder's firmware.
http://www.d-mpro.com/users/folder.asp?FolderID=3629&Tab=Accessories
Would like to know if this helps. Good luck.
Nov 20, 2007 | Marantz PMD660 Digital Voice Recorder
Marantz pmd670 4 Gig Card formatting problem
No solutions, Marantz it´s a very old technology
Apr 12, 2007 | Marantz PMD670 Desktop Digital Voice...
Marantz PMD660 Digital Voice Recorder Logo
569 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
