Dual 1218 turntable motor wont turn?
Hi, can you please inform me on how to correct this issue. the dual 1218 turntable motor, will not turn, I thought it might be lubrication issue
?. What can I do?. Thank you.
4 Suggested Answers
  • 4234 Answers
SOURCE: Dual 1228 turntable platter not spinning, the motor will not turn
This particular unit uses an idler wheel to drive the table. Remove the platter and check the rubber wheel. It may be dirty, or just dry and slick. This part may need to be replaced or treated.
Dan
Posted on Dec 19, 2008
  • 6 Answers
If the motor is not spinnig then it is probably seized. These motors are very robust and rarely need replacement parts. Remove both the top and bottom bearings, clean shaft and bearings with solvent and then fill bearings with light machine oil. The bearings have a sponge inside which will soak up lots of oil for years of trouble free use. Once reassembled, tap the bottom bearing while the motor is spinnig and the bearings will centre themselves. If the idler and it's mechanism is working ok as well then you should feel lots of torque from the from the platter when it is spinning.
Posted on Oct 27, 2009
  • 189 Answers
SOURCE: DUAL 1218 AND 1225 TABLES WHERE THE ARMS
HELLO
Go to AudioKarma.org on the web and I'm sure the guys on there will help you out - but you will have to register to post!
Hope this helps you!
Posted on Apr 14, 2010
DUAL 1229 service manual
U sure you are not looking for help with a turntable? If so, state the issue. Dual 1229 Manual 3 Speed Idler Drive Turntable Vinyl Engine
Apr 02, 2017 | Sewing Machines
Why does dual 1218 tonearm misses record to outside, adjustment screw doesn't help???
Well , does the adjustmentment screw really moves when you turn it, or only spins:)???? and won't move
Sep 11, 2014 | Audio Players & Recorders
Dual 1218 turntable
Does it say anywhere you can find that this turntable can run off 220V mains? Most are run directly from the AC and the motor is an induction motor meaning it needs a specific voltage and cycles per second to run properly. You may find that the manufacturer provided straps on the motor that can be unsoldered and changed to adapt to various voltage and ithat the speed can be altered via a speed control knob on the top to adapt to 50 or 60 cycles.
Apr 28, 2014 | Technics Audio Players & Recorders
How to lower a ccm
Hi, Anonymous for more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
lowering ccm r30
ccm 644 dual sport
CCM 604 Trail 2001 service manual DOWNLOAD FREE FULLMANUALS COM
CCM Spares 404 Enduro
CCM 604 DS Dual Sport
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 10, 2013 | 2002 CCM 604 DS Dual Sport
Hi, my dual 1214 turntable is only playing on one channel, can you advise how this can be fixed please?
Turn your amp off, unplug the phono connectors and reseat them, then remove the headshell and do the same. While you have the headshell off, examine the 4 little wires for crimps and breaks.
Apr 25, 2011 | Dual Audio Players & Recorders
Hard to find 50k dual linear dual center tap @10% volume control do you know where to find it because I have check everywhere for it?
I would recomend a forum called "VINYL ENGINE". It's a specialist turntable forum dealing with ALL makes and models of anything turntable related. Your question is quite specific and I feel you will only get the correct answer from there.
Jan 08, 2011 | Audio Players & Recorders
HELLO
Apr 12, 2010 | Audio Players & Recorders
Dual 1218
What happens if you lift the tonearm and slowly move it over its travel in toward the label area past the expected point at which it should cycle? There should be a mechanical click as it engages the lift / return cycle. If so, the mechanism works but might be out of adjustment due to wear and tear.
Perhaps cycling the Record Size switch a few times might have a positive effect on the function. There doesn't seem to be a user adjustment for the end of play cycle.
You can get the manual for free after you register at:
http://www.vinylengine.com/library/dual/1218.shtml
If you decide to venture into the mechanics be cautious, always protect the tonearm from damage and make sure you rotate the platter only clockwise as there are mechanical interlocks that could get damaged if you turn it the wrong way.
Mar 09, 2010 | Technics SL-1200 Turntable
615 people viewed this question
 Grubhead
Grubhead
