Question about Sony VAIO VGN-SZ330P/B Notebook
Laptop locked screen black tho power on, caps lock and no. lock and third little light showing as on. can you help
  • anna_d Dec 15, 2008
    Same problem here: when the laptop starts up, it seems to be locked, with the power light turned on and black screen. I would appreciate any help...
    Scholar:
  • 46 Answers
Well guys, it sounds like motherboard trouble with your laptops.
Try this, try to press the power key and hold for about 30 seconds (after removing the battery). That'll clear the bios to regular settings.
If that doesn't work (which means bigger trouble), then you need to do the following. If your laptop is under warranty (since I don't suggest opening it up unless you know what you are doing) you are going to need to send it back to them, or contact the company you got it from. Next, you'll need some basic info. the motherboard is able to tell you stuff even if it can't boot.
Now the three lights seems and appropriate signal, but let's try pressing the Fn key (the function key which provides things like increasing the brightness and such when held and pressed with another button), and THEN while holding it, turning on your machine. It should give you some beeps, and some flashing lights. These are things you're going to need to record, feel free to turn the laptop off and on again if you can't catch it all. This is info you will need to tell the laptop company involved.
You could also try reseating the RAM chips, which simply involves using a jewelers screwdriver and flipping your laptop over and unscrewing a cover protecting the ram (it usually has vents and is somewhere in the center bottom of the laptop on newer models). If your laptop only has one slot down there we may need to check the top, tell me if it does and I'll walk you through it. Checking your Ram does NOT void your warranty, it's easy to replace. Once it's open, take the two plastic bits holding the chip in place and press outwards away from the chip on them until the chip magically pops up. Then, take the chip out, and put it back in the same way it came out (angle and everything), once in and snug, press it down until it magically snaps back into place, replace the ram cover, screw it down, and try turning the lappy on.
Hopefully this helps. Stay spicy and happy lappying!
Posted on Dec 15, 2008
Turn off caps lock
Great little utility. I think it's free. Will show in your taskbar.
Here is the link.
https://www.traystatus.com/
Oct 08, 2017 | Computers & Internet
Toshiba Sattlite, boots but black screen. Caps Lock light is on and F10& F11 key is okay.
Corrupted operating system. Start over with a restore disc and if you do not have one buy one you will need it from the factory. Re-install the whole system over again. Insert the disc in the slot and power it on select boot from DVD or CD-Rom which ever you have. Follow the onscreen instructions. John
Apr 09, 2012 | Toshiba Satellite L305-S5907 Laptop
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
I have a HP Pavilion tx 2000 tablet pc. When i turn it on the power button it shows that its on. The hard drive light does not flash and the caps lock and the number lock button keeps on blinking. My...
Hi
Boss you need to mention here in what sequence do the lights blink.
Anyways you can take help from this
DO RATE MY SOLUTION
Jul 04, 2011 | Compaq Presario Notebook
My laptop when I power on, shows a blank black screen and the caps and num lock lights are blinking and the fan is running.
Your hard drive has probably gone bad and it does not have a bootable device to use on start-up.
Mar 15, 2011 | HP Pavilion dv7-1245dx Notebook
What do the activity lights on the keyboard of the Dell Laptop C640 represent?
To the right of the power button and below the Dell AccessDirect button are three lights. These have a lock synbol below them. The first one from left to right is signified by a number 9, this light is turned on when the numberical keypad is enables. The center light is signified by a letter A, it is on when the uppercase letter function (Caps Lock) is enabled. the third one, far right, signified by a down arrow, is on when the scroll lock function is enabled.
The device status lights on the far right side near the front of the laptop case. The top light is the power status light, the middle light is the Hard drive activity light, the bottom light is the status light for power management, battery, AC etc.
Oct 17, 2009 | Dell Latitude C640 Notebook
Acer laptop. it won't start up, when i press the start button, it shows nothing but black screen, and i dont know what to do .... I have the same problem i have an ACER ASPIRE 5920, when i turn my laptop...
hi
in both the computers unplug the power cord and any external device attached to the system.
Press the power while the power cord if unplugged for 1 min exact, plug the power cord and see if this works. As there is extra power on the mother board which needs to be drained out
Jan 08, 2009 | Computers & Internet
Won't boot
was there any changes done to your system like upgrading anything
All your power seems to be on right
Dec 13, 2008 | Dell Inspiron 1525 Laptop Jet Black
Start up
yr problem should be from the screen to really confirm if yr laptop is truly on cos u dont just gudge by seing the power led on. to check if yr system is on press the caps lock key or press the fn+num lock key if the indicator led comes on then yr system os on now troubleshoot yr screen by checking the module,connector n fuses. if the caps lock led doesnt come on then yr system just powered on because it saw a power source in that case try to replace the memory(ram) next the processor.
guess this helps
thanks for using fixya
May 26, 2008 | Toshiba Satellite A135-S4427 Notebook
Cap locks
I do no exactly you can try this. First check your computer with safe mode. Check it in that safe mode again its shows the same problem means check your display device or card
Feb 19, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Sony VAIO VGN-SZ330P/B Notebook Logo
106 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
