Question about Mitsubishi VS-50607 50" Rear Projection Television
Blown fuse the 5 amp fuse next to the power cord plug blows instantly as soon as I plug it in.
  • 944 Answers
Sounds like a problem in the transformer (a short) possibly visible as surface burn marks on the transformer coils. This can sometimes be fixed, but is not usually worth it for a small transformer, but easily replaced. Also check that there is not a short where the power cord connects to the workings of the tv, maybe a loose connection or some debris. Hope this helps :)
Posted on Mar 18, 2007
NUMARK DIMENSION 4 1900W blowing power cord fuse
This could be a faulty power cord, ie: two of the wires touching perhaps not visible to the eye. Or a short in the transformer or power supply. Check also internal fuse(s) if they have blown, suspect a faulty device in the power amp stage (on the heat sink) if they have gone too!
Feb 23, 2014 | Audio Players & Recorders
Suddenly blows fuse as soon as plugged in why?
Usually a fuse blowing immediately means there is a short in the amp somewhere.
Jan 04, 2013 | Koss KS2503 System
My kenwood reciever kr-a4070 keeps blowing a fuse
have you tried a different outlet? something my be wrong internally
Jul 31, 2012 | Kenwood Audio Players & Recorders
How many amps is the fuse that is located on the back of the TV near the power cord. It says T5AL/125 or 250 v. f800
Something else is going on to cause the fuse to keep blowing. Sounds like you have an issue on your power supply in the unit. Also check the outlet that your plugging it in to. Good luck!
Jun 28, 2012 | Zenith E44W46LCD 44" Rear Projection...
Cant get the fuse out
The fuse is in a "boat" right next to where the power cord plugs. Pry outward on the tab of plastic where the power cord plugs in. The tabe is about 1/4 inch wide.
IF THE FUSE HAS BLOWN, better find out why as replacing it MAY cause further damage to internal components. If you do replace it and it blows again, take amp in for servicing.
Mar 06, 2011 | Ibanez Tbx150h Tone Blaster Xtreme Guitar...
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
No power to tv
The power management and protection circuits have taken over. There is something taking too much current and the protection system has shut the system OFF to prevent further damage ...............if you are familiar with tv service you can check the main fuse that should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as soon as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply.......Check horizontal output transistor.............
Feb 04, 2009 | RCA HD52W59 HDTV Projection Television
Keeps Blowing The 5 Amp Fuses
There is a short in either or both the main power supply or one of the scan amplifier sections and or the high voltage section.
You will not bel able to service this yourself. This type of repair can be fairly involved and complicated to troubleshoot.
An expericed TV tech should be able to service this for you.
Jerry G.
Jul 07, 2008 | GE 35GT695 TV
Instantly blows the 5 amp fuse next to the power cord plug.
You have a short in the power supply. Look at the regulator and or rectifier diodes. These are all on th primary side of the SMPS (switched mode power supply) the secondary side if shorted shouldn't cause a blown fuse at all.
Mar 18, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Unit blows fuses
its a short in the power supply but ist realy care?, whats the price of this unit?...good luck
Aug 11, 2006 | Emerson EWC0903 9 in. TV/VCR Combo
Mitsubishi VS-50607 50" Rear Projection Television Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
