Question about Refrigerators
On the Whirlpool side by side fridge/freezer all the display is flashing and there is a lot of ice in the top of the freezer compartment.
    President:
  • 1,952 Answers
Try correct setting in cold,cooler
Posted on Dec 15, 2008
My frost free fridge freezer is working but flashing de on the front. I'd like to know what it means
Error codes are brand (and often model) specific. "de" likely indicates something in the defrost process, especially on G.E. Check for ice build-up in the freezer cooling coil. The control board would be suspect, but must be checked to confirm the precise fault.
Oct 20, 2014 | Refrigerators
Whirlpool 6ED2FHKXRL side-by-side fridge/freezer not cooling properly
Is there a lot of ice in the bottom of the freezer, at the back? If so, you will need to get the ice out as it is probably blocking the door passage from the freezer to the fridge.
Dec 04, 2013 | Refrigerators
Side by side thermostat set low seems like it runs a lot more than it use to freezer and fridge are boyh cold
Check your coils underneath the fridge to be sure they are clean.
Check your condensor fan (bottom rear of fridge) to make sure it is blowing air freely.
Make sure you have a good supply in the freezer, All of your cooling comes from the freezer section and a mostly empty freezer will result in more frequent running as ther is not enough stock to help maintian and hold freezing temperatures.
Check your freezer section to make sure there is no visible frost on the back wall of the freezer (down low on the panels behind and slightly above the lowest freezer basket. If you see frost starting to develop it means you have a defrost issue starting and will want to adress it rather quickly. Either a problem with the defrost control board (inside fridge/freezer control compartment) or the defrost thermostat (behind the freezer back panel on top of the evaporator coils).
Hopefully this helps!
Jun 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The things in the freezer are not frozen and there is ice in the milk in the refrigerator. It a 6 year old Whirlpool side by side.
You possibly have a 2 part problem. Do a 12 defrost and make sure the product in the fridge is not near the auger (cold inlet vent into the fridge). Fridge gets its frost from the freezer compartment.
Nov 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Apr 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Freezer ice making compartment stays in lock mode
the thermostat in the ice machine is not working. its most likely tha the icemaker is a FSP whirlpool it's a lot surer to just replace the hole head and be done with it unless you'd like keep dealing with it.
Mar 18, 2009 | Freezers
Ice maker quit working
check the teperature of the freezer compartment . the ice harvest actuates on teperature. and refill with water at the end of harvest cycle.. a lot of times the condensor under your fridge can become plugged with dust and the freezer teperature never achives low enough to harvest ice..good luck
Oct 06, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ref in door ice not making ice
Sep 20, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool gold, freezer on top, single door
hi thanks for the question the drain system is clogged the drain hose from the freezer to the drain tray undre neath the fridge by the compressor is clogged you may have to shut down the unit to let the ice melt that has caused this problem get a small plastic hose from a hardware store and shove it up the drain dose and blow air up the hose till its clear that's why you have to shut the fridge off for 24 hrs to allow the ice to melt then blow the air thanks the appliance doc
Sep 02, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
