Question about Kyocera Finecam S4 Digital Camera
I have c1 error
Problem c1 error
    Novelist:
  • 157 Answers
C1 error is caused by Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Posted on Dec 15, 2008
What is error code C1-14
C1 14 MAIN CHARGER TROUBLE (COLOR)
You might be able to clean the charge wire.
https://www.sosnfl.com/sharp-mx-c312-error-codes/
May 07, 2016 | Sharp MX-C312 Multifunction Printer
I keep getting an error message and it stops, Error message C1 and there is nothing with the bobbitn
Try hitting the F8 key after the Laptop starts booting, and when the list of options comes up, select boot in safe mode. If you are unable to get to the options screen, then search on the C1 error code on Google, and look at the tips on resolving the problem.
You will need to make note of the full error code, ie C1xxxxxxx.
Sep 04, 2015 | Computers & Internet
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
Asus p5n73-am mother board power on and suddenly off
This is Ram related
C1
= Detect memory, Auto-detection of DRAM size, Detect Ram type.
Replace Ram with new one and try again
May 25, 2014 | ASUS P5N73-AM Motherboard
My samsung inverter condition does not switch off error C1
Try:
Switch the unit off with the remote (power button) - "C1" appears on unit
Push "Auto Clean" button on remote
Unit should switch off
Nov 16, 2012 | Heating & Cooling
What is error code C1? Also what causes the
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.
http://media.fotki.com/1_p,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
From the service manual....
"C1 = Average current limit Or Instantaneous current limit.
If a status signal comes back from the motor controller that a current
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or Cl for
instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current
draw greater than 5.55 amps
at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps
instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or
motor controller. Over-loading the unit may cause this problem."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Canon ImagePress C1 error E000747-8000
E747 from what I remember is the connection cable from either the scanner to the print device, or scanner to the copier. Make sure that none are loose and they are in the correct slots.
Mismatching the cables may result in the error.
Dec 10, 2009 | Office Equipment & Supplies
Error code c1 of ca
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jun 03, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error code c1
Error code C1 indicates a problem with drive motor-thermal protector or the motor controller
may be due to overloading
Press( stop/cancel) to clear the display.
Hope this helps
Dec 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Getting error code c1
Hi
Error code C1 indicates problem with drive motor-thermal protector-or motor controller
Overloading may also cause the problem.
Hope this helps
Nov 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kyocera Finecam S4 Digital Camera Logo
314 people viewed this question
Top Kyocera Cameras Experts
Iqbal Husain
Iqbal Husain
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
