Question about Kyocera Mita FS-1030D Laser Printer
Kyorcera FS1030D - error light sequence
I have a Kyocera FS1030D that won't print. The lights on the top are flashing Top + Bottom, then Top + Top Middle + Bottom.
Can anyone tell me what this means or where I can find out what this means?
Thanks,
Dave
  • darth-viking Dec 15, 2008
    Fixed it.
    Contacted Kyocera and told them what the symptoms are, and how many pages the printer has done. They are sending a new part in the post.
  • itsupport709 Apr 16, 2009
    same error as Dave the sequence was: 1st & last lite flashing, then, 1st, 2nd and last lite flashing then back again to 1st & last ....
Dave,
You need to empty the excess toner reservoir in the front of the process unit.
Front as in the other end to where you put in a new toner.
All you have to do is open the side panel and empty all the toner out.
That should fix your problem.
Sorry to give you all the instructions like this but people still open up the toner end and have a lot of fun putting it back together.
Enjoy
Posted on Apr 23, 2009
  • BobMcm Mar 08, 2012
    Worked like a charm. As a point of further clarification, the "side panel" is on the control unit, at the "front left" corner (if you're facing the machine with the indicator lights on your right). I dumped an enormous amount of "excess" toner out of there and the lights are gone.
Kyocera fs-1030d top two green light on constant. not printing,
You can try to reinstal the printer driver. PCL is a printer language.
Jun 15, 2018 | Kyocera Office Equipment & Supplies
Both lights flashing and won't print. Help!
hi,
please visit the site
I have printed both from the CLI and the GUI; no difference. I thought maybe the paper ... http://www.openprinting.org/printer/Kyocera/Kyocera-FS-920 .... Also it seems the CD supplied drivers won't solve your problem. .... And NO WD-40 on plastics, better take silicone spray in a very light dose. ...
forums.scotsnewsletter.com > ... > Main > Bruno's All Things Linux - Cache
May 30, 2011 | Kyocera FS-920 Laser Printer
Dear sir / madam many times when i print, the printer give white paper and this error pcl xl error subsystem : kernel error illegal tag operator ox8 position 30374 what i must do thanks
try a different driver
pc5
pcl 6
and kyocera own kpdl or kx
or even a mini driver
here is the link http://www.kyocerasupport.co.uk/index/download_center.false.driver.FS1030D._.EN.html
if all fails u might need to upgrade firmware on the printer
Nov 20, 2010 | Kyocera FS-1030D Laser Printer
Kyocera FS 1020D
You might be out of toner.
Jul 22, 2009 | Office Equipment & Supplies
Can you help me with kyocera fs-1030d
If a paper jam occurs while printing, the printer notifies it by the following combination of the four indicators. Remove the
jammed paper . After removal, open and close the top cover once to initialize the jam sensing
Dec 04, 2008 | Kyocera Mita FS-1030D Laser Printer
PAPER JAM IN VERY REAR OF PRINTER KYOCERA FS1030D
sounds like a fuser jam. remove top and side covers, then rear exit tray. remove fuser screws and connectors. should be able to remove paper with fuser out of machine.
Oct 08, 2008 | Kyocera Office Equipment & Supplies
How to print configuration page for a Kyocera FS1030D
Try press and hold the green button for about 10 seconds. HOPEFULLY this will cause the printer to produce a configuration page with the details. Good luck!!
Sep 25, 2008 | Kyocera Mita FS-1030D Laser Printer
Fs-1030
This is a Thermostate problem. You have to reset thermostate or replace the fuser unit your problem will resolve.
Jun 10, 2008 | Kyocera Mita FS-1030D Laser Printer
Kyorcera FS1030D - error light sequence what does it mean
If you mean that the sequence is: 2nd led and then 1st+2nd+3rd
the problem is in fuser unit. You have to call a technician to check the lamp, the thermistor and the thermostat inside the fuser unit
Mar 16, 2008 | Kyocera Mita FS-1030D Laser Printer
Top 3 lights blinking on printer
The flashing of the LEDs you describe indicates a error. If you call the Kyocera Help Desk they can tell you what the error is based on the order and color of the LEDs. They can be reached at 800-255-6482.
Aug 18, 2007 | Kyocera Mita FS-1030D Laser Printer
Kyocera Mita FS-1030D Laser Printer Logo
5,321 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
