Question about RCA D56W20 56" Rear Projection Television
Great pic but bad sound
If the sound setting is set to automatic or stereo, all of the lower chanels have a loud buzzing noise and the higher chanels have it off and on. the right speakers have the buzzing noise no matter what setting. Called a repair place and they said something about an amp? If I knew what part is bad and what it looks like I can remove and replace it. Help
    President:
  • 3,130 Answers
Your problem could be the main amp board, the signal panel or the audio processor board. You will need to get a service manual for this set to diagnoise these problems. Good Luck
Posted on Apr 01, 2007
Hello why do I have a loud buzzing noise coming from my umc combination 21 inch television so bad you cannot here program dialogue ?
You need to send your TV Model first, but in general any strange sounds in a TV come from the followings:
1- High ripple in the power supply of the sound card.
2- Bad polarized capacitors in the sound card
3- High noise in the main power supply (SMPS)
4- For CRT tv, weak insulation of the Line Transformer
5- An external source near your TV set which is picked by your TV and amplified.
Jun 09, 2014 | Televison & Video
Motor making loud buzzing noise
The grinding noise could be asking for lube. If that is possible, do it.
Dec 13, 2013 | Precor C956i Treadmills with HR /...
If I strum harder on my guitar a buzzing noise comes out of the amp. Also every sound I try on the amp sounds very twangy and painful to the ears. I use an overdrive pedal with it, but every setting is...
If you don't want distortion, get rid of the overdrive pedal... Twangy USUALLY comes from the GUITAR and NOT the amp... test it on a different amp to decide... Buzzing CAN be caused by "fret buzz" which is due to IMPROPER guitar setup such as neck bend and string height.
Start using ONLY clean channel on the amp and NO reverb. If you verify that the guitar sounds bad on a different amp, take it in to have it setup properly.
Feb 10, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
ALPINE XL15
Hi jackkikay,
A faint buzzing sound is normal - - that's the high-voltage plasma discharge simulating lightning in a thunderstorm. If the room is dark you should be able to see a faint bluish-purple glow of the metal grid on the plate(s) inside. This should somewhat louder as you increase the setting.
It should not really be so loud that is stands out in the background of normal noises (refrigerator running for example). If the buzz is loud - - like something is shorting-out internally (loud crackling sound), that would signal a different problem - - I'd need more details about what you're observing. Approximate purchase day, specific model, number of plates, general condition of the interior would all be helpful if you deem the buzz to be too loud for normal operation.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Oct 29, 2008 | Air Purifiers
I have a Dyson vacuum cleaner ...upright....all of a sudden my vacuum started making this awful sound...like a loud buzz...but only when I have it on carpet....when I have it on "floor" mode it's...
it may just be, that on carbet the brushes make noise that you dont hear on woodfloors.
If there is a hights adjustment, set it higher for shaggy carpet and lower for berber.
Mar 16, 2008 | Vacuums
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Nov 06, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
RCA D56W20 56" Rear Projection Television Logo
42 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
