Question about Belling XOU270 / XOU271 Electric Single Oven
Replace Bottom Element in Belling XOU270
How do you physically remove the bottom element in a Belling XOU270? It looks like you have to completely dismantle the box. Surely not! Many thanks indeed.
  • wilbyforce Dec 16, 2008
    It is a fan oven and there is both a fan and a bottom element. I have removed the connectors from the bottom element but see no way of removing the element itself without dismantling the box.
  • Belling Master
  • 3,463 Answers
If this is a fan assisted oven, then there is no bottom element, only the fan element..
Remove the panel at the rear of the oven, there you will see the element, remove any screws that you can see and pull element towards you, disconnect the leads, don't loose them, and replace element.
If no screwws are visible then you will have to remove the oven from housing and do it all from the rear of the oven. Make sure power is off before you do anything.
Good luck.
Plz rate my solution.
Thanks.
Posted on Dec 16, 2008
  • Barry Coates
    Barry Coates Dec 16, 2008
    I stand corrected, it is very unusual to have a bottom element in addition to a fan element, however, you are correct you will have to remove the side and possibly the rear panels to access the element, you will find it is probably covered with insulation, and may held in place with a bracket, you will have to slide or pull the element out.If you can see the terminals then you know where it is located.
    Plz let me know how you get on.
    Thanks.
No heat from oven although fan and light are both working
hello gavin..... Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
This is an inexpensive part and relatively easy to replace. Call your local appliance store to obtain the part and the instructions on how to install it. Joe
Thanks for choosing Fixya!
Jan 05, 2011 | Belling XOU270 / XOU271 Electric Single...
Tip
How to diagnose, fit and change a Belling fan oven element.
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ.
on Aug 25, 2010 | Belling XOU270 / XOU271 Electric Single...
WHY CANT I TAKE ELEMENT OUT
If you cannot remove screws from inside oven compartment, then, yes, it will be neccescery for you to remove the oven from it's housing to gain access to the screws from the rear.
May 04, 2010 | Belling XOU270 / XOU271 Electric Single...
How do I change the oven element on a belling format 800 oven
1, If your Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
Jan 03, 2010 | Belling XOU492 Electric Double Oven
Belling oven xou592 bottom fan oven not heating up fully. Fan works and orange thermostat light on but does not heat up. Before this happened it tripped mcb in consumer unit.
You need to fit a new oven element.
This is located at the rear of the oven behind a removeable cover, where the fan is
It is a fairly straightforward job to replace.
Hope trhis helps with your problem.
Dec 15, 2009 | Belling XOU592 / XOU593 Electric Double...
The fan assisted oven has stopped heating up how can i fix this
If the fan is working o/k, then you needs to replace the oven element located at rear of oven compartment.
Please rate my solution.
Thanks.
Oct 29, 2009 | Belling XOU270 / XOU271 Electric Single...
Belling Synergie
NEED NEW FAN OVEN ELEMENT THAT CAN BE FOUND HERE
You need Element code AB20 on link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
element is located on back wall of oven you need to pull oven oven to remove the element element is held by two nuts from back and i screw from front
Dec 22, 2006 | Belling XOU270 / XOU271 Electric Single...
Belling XOU270 / XOU271 Electric Single Oven Logo
379 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
