Question about SanDisk Sansa e260 MP3 Player
San disc sansa E260
After deleting an audiobook it still appears on the screen and when clicked on I receive a Bad Files message. (This is the same problem another poster had)
  • 8,596 Answers
You probably will need to reformat the player, but it will result in ALL files being erased, so you will later have to reload the good songs:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
I need a factory reset
Using Dell PC Restore by Symantec
NOTICE: Using Dell PC Restore permanently deletes all data on the hard drive and removes any applications or
drivers installed after you received your computer. If possible, back up the data before using PC Restore. Use PC
Restore only if System Restore did not resolve your operating system problem.
NOTE: Dell PC Restore by Symantec is not available in all countries or on all computers.
Use Dell PC Restore by Symantec only as the last method to restore your operating system.
PC Restore restores your hard drive to the operating state it was in when you purchased the computer.
Any programs or files added since you received your computer-including data files-are permanently
deleted from the hard drive. Data files include documents, spreadsheets, e-mail messages, digital photos,
music files, and so on. If possible, back up all data before using PC Restore.
To use PC Restore:
1 Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
2 Immediately upon seeing the blue bar, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish starting, and then restart the
computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
3 On the next screen that appears, click Restore.
4 On the next screen, click Confirm.
The restore process takes approximately 6-10 minutes to complete.
56 Troubleshooting Tools
5 When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
6 When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the screens that
appear, such as the End User License Agreement, are the same ones that appeared the first time the
computer was turned on.
7 Click Next.
The System Restore screen appears and the computer restarts.
8 After the computer restarts, click OK.
Feb 03, 2014 | Dell Dimension E521 PC Desktop
NEED TO KNOW HOW I CAN PREVENT BACKUP FILES FROM GOING INTO MY RECOVERY(D), AND FILLING IT UP. I AM RECEIVING MESSAGE THAT I HAVE LOW DISK SPACE IN RECOVERY DISK. HOW DO I FREE UP THIS SPACE, AND HOW
Are you sure the files are going in there? Many times the manufacturers only allocate the size that they need partitioned on that drive. I have seen many cases where that drive is full from factory and people always get that message.
  1. Click Start c01508537.gif and right-click Computer .
  2. Select Properties .
  3. Click System Protection from the left side of the Window.
  4. In the section "Automatic restore points", remove the selection next to the D: drive, and then click OK . If the D: drive was not selected, close this window. Figure 3: System Protection tab with D: drive unselected
  5. Right-click Start Explore All Users .
  6. Before you can remove the backup files and folders, you need to be able to view hidden system files as follows:
    1. From the explorer window press the Alt key on the keyboard to make the menu bar appear in the window.
    2. From the file menu, click Tools , and then select Folder Options .
    3. Select the View tab.
    4. Select Show hidden files and folders , remove the selection from Hide protected operating system files and then click OK .
  7. From the Folder Options window in explorer, double-click Recovery (D:) .
  8. If a Window opens stating "You don't currently have permission to access this folder" opens. Click Continue .
  9. If you previously copied or created any files into Recovery (D:) and you want to keep them, copy them to another drive - such as the C: drive.
  10. Find and delete any files that you previously copied onto the Recovery (D:) drive.
    CAUTION:Do not delete any files that are associated to recovery! Do not delete the items RECOVERY, $RECYCLE.BIN, boot, hp, PC-Doctor, pcdr, or PRELOAD! Doing so can prevent a future system recovery from the hard drive. If you are not sure, do not delete the file.
    Press Shift + Delete to permanently remove the files.
    To delete files created from MS Backup (MS Backup files are not recovery files), find and delete the folder with the same name as the computer name in the Recovery (D:) partition. For example if the computer name is BOB-PC, the folder containing the backup files would be named BOB-PC and would be deleted.
  11. Several confirmation windows open. Click Continue , and Yes until the folder is deleted.
  12. To set Windows Folder Options back to their original setting as follows:
    1. From the explorer window press Alt to view the file menu.
    2. Click Tools , and then select Folder Options .
    3. Select do not show hidden files and folders and select Hide protected operating system files .
    4. Click OK .
  13. Close explorer. The Out of Disk Space errors should no longer appear. If you would like to use the Microsoft Backup Tool again, open it and select a different external backup device to store the backup files on.
Aug 17, 2012 | HEWLETT-PACKARD Computers & Internet
I need to reset a dell dimension 8400 to factory setting what f key do I use
Welcome to FixYa!
Use Dell PC Restore by Symantec only as the last method to restore your operating system. PC
permanently deleted from the hard drive. Data files include documents, spreadsheets, e-mail
messages, digital photos, music files, and so on. If possible, back up all data before using PC
Restore.
NOTICE: Using PC Restore permanently deletes all data on the hard drive and removes any applications
or drivers installed after you received your computer. If possible, back up the data before using PC
Restore.
To use PC Restore:
2 Immediately upon seeing the blue bar, press .
If you do not press in time, let the computer finish restarting, and then
restart the computer again.
screens that appear, such as the End User License Agreement, are the same ones that
appeared the first time the computer was turned on.
7 Click Next.
Good Luck
Nov 11, 2010 | Dell Dimension 8400 PC Desktop
I received the following message after downloading an audio book using Overdrive Media Console. Error message: "Please obtain license by transferring this title to device using audiobook...
Hi.
I report a solution from Portable player FAQ, let me know if it works:
1. Delete the title in the Overdrive Media Console program.
2. Then log into the Audiobook site at http://e.hbpl.org and click on My Account, My eItems Checked Out, and click the Download button the website to re-download the book.
3. Transfer the newly downloaded parts to your player.
Oct 27, 2009 | SanDisk Sansa Fuze MP3 Player
I have a Philips GOgear SA5285 and I can load the audible audiobooks and they go to the audiobook file but when I load my library books from Netlibrary.com they load as songs and do not have book marks, so...
If you are a newbie, and you primarily want the mp3 player for audiobooks, then go ahead and take this player back to the store - I'll tell you why:
The deal between Audible and Philips fell through before the latest series of GoGear's was released. Therefore, even though the player has an Audible folder, it will not properly play Audible audiobook files. Sad, but true.
Your post reminds me that I need to write a Consumer Watch article on mp3 players that claim to play audiobooks - 90% of them will not easily allow you to play audiobooks - you will have to jump through hoops.
If you still want to try, here is what you want to do:
1. Delete any audiobooks off the GoGear, but make sure that you have a copy of the audibooks on your computer itself.
2. Open Windows Media Player. Find your audiobook files in your library. If they don't show up, then you will have to move your mouse over the Library tab - a small black arrow should appear underneath the word "Library" - click the black arrow and select "Add to Library". Click "Add" and find the folder in which your Audible files are stored. It may take several minutes, but Windows Media Player will add these files to Windows Media Player.
3. Right-click an Audiobook file starting with Chapter 1 of whatever book, and select "Advanced Tag Editor". One-by-one, manually assign an a track number to each audiobook chapter - Track 1 for Chapter 1, Track 2 for Chpater 2, etc.
4. Now, re-add the audiobook files to your GoGear.
5. You might additionally have to go into the Settings menu of your GoGear, and turn Shuffle mode off - your user's manual can show you how to do this.
Sound like a lot of work? You betcherbottom dollar it's a lot of work. This particular mp3 player is not the best for audiobooks.
-Tha Mp3 Doctor
Mar 11, 2009 | Philips GoGear SA5285/37 Digital Media...
I cant organize my downloads, and I listen to audio books and would like to see if there is a way to bookmark or save the place in my book where I left off. I have to sit there and hold to fwd button...
-Tha Mp3 Doctor
Mar 07, 2009 | Philips GoGear SA5285/37 Digital Media...
How to delete Audiobook clips that came with the device?
try to serch on the hiden files.
please rated my solution...
Feb 07, 2009 | Creative Labs Creative Technology Zen MP3...
Sansa dioesn't recognize audiobooks
Maybe the new firmware will fix this.
"OGG placed in Audiobook or podcast folder shows up in Music directory." (see below)
(http://www.anythingbutipod.com/forum/showthread.php?t=30954)
01.01.30
Enhancements:
  • FLAC decoder support
  • Allow Podcasts to skip episodes using FF / REW
  • New startup and shutoff images
  • Improved the time to rebuild the metadata
  • Improved M3U playlist support
  • Enhancements for sorting Podcast contents which do not have their track number ID3 tag information
  • Separate missing license error message for Audible and generic Audiobooks. Message changed to instruct the customer in how to resolve the problem
Bugs Fixed:
  • OGG placed in Audiobook or podcast folder shows up in Music directory
  • Delete song from a long playlist causes the device to hang
  • Selecting “Back to Music List” while playing FM/Voice recordings will display double “Play All” on screen & will cause device to hang upon selecting “Play All”
  • Certain tag information for mp3 files will cause the device to hang or freeze
  • Made OGG file Tags not case sensitive
  • Noise problem on voice recording
  • Device in MTP mode will jump back to AutoSelect mode after UI format
  • Device behaves erratically when file extension got changed (i.e. .txt to .mp3, .jpg to .wma)
  • All Audiobooks should show 1/1 if Chapter Mode is OFF
  • Certain Rhapsody tracks show clicking noises
  • Deactivation message “Synchronize to listen to your Audiobooks” for Audible is uninformative and irrelevant
Oct 07, 2008 | SanDisk Sansa Clip MP3 Player
My nokia 6288 won't receive messages
Its ur SIM Cards message memory which is full.
Go to ur phones messages settings and set ur message memory to phone or memory card.
Regards
Sandeep
Nov 03, 2007 | Nokia 6288 Cellular Phone
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
