Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
No audio when pluggin my computer
I can get video with an rgb cable but I can't get any audio. I tried an 1/8" to 2 RCA cable and even tried using a mono adapter on it but I still don't get an audio.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Is your PC desktop or laptop?
    connect 1/8" to 2 RCA cable in audio out terminal of PC and 2 RCA to TV PC audio input.
    Problem Solver:
  • 10 Answers
Many sound cards require you to tell it what kind of sound you are trying to reproduce and how many speakers you are using.
Not knowing what sound card you have...you might have to go into Sounds of Control Panel if you are using Windows and see if there are parameters that you must specify. By doing this, the sound card will activate the output jack on the PC accordingly.
Posted on Jan 30, 2009
Vizio M550SV no sound. Is there an audio card or does the main board have to be replaced?
See page 8 here:
http://cdn.vizio.com/documents/downloads/hdtv/M550SV/991UG_M420-470-550SV.pdf
From the top
- HDMI - both Audio and Video come from device via one cable.
- RF Coaxial (aka CATV) - both Audio and Video come from device via one cable.
- 15 Pin Dsub (they are calling it RGB), Video comes from this cable and Audio is from a dual 1/4" plug (looks like a headphone wire at both ends).
- Component (this is true RGB) uses RCA type cables - two sets of cables, cable one has 3 RCA at each end and they are color coded, as follows Red/Green/Blue, cable two has two RCA color coded as follows White/Red. Cable one is Video, and cable two is audio, total of 5 connections at source and 5 connections at tv.
- Composite AV - one cable set, coded as follows - Red/White/Yellow, Red/White are audio and Yellow is video.
Hope this helps.
Nov 25, 2014 | Vizio Televison & Video
How do I hook up my Apple TV to onyko 8050 receiver?
Hi Barry
AppleTV has 2 Outputs on the back. One is Optical for Audio Only and requires a Toslink fibre optic cable to get the good quality audio into the 8050 receiver via the Game 1 Port.
The second connector is HDMI which is a compact low profile cable which transfers both HD1080 Video and Left & Right Audio to another device.
The built in WiFi should be picking up your Router WiFi in the house and transferring iTunes music to these Ports. Just play a song on iTunes on your computer & click the icon to select AirPlay on your ATV.
There are a heap of HD TV's and Amp's etc using HDMI these days.
It's the simplest way to get connected & its the best quality.
Unfortunately the Onyko 8050 uses a proprietary port which is not directly compatible.
I noticed all the Video Ports on the back of the Onyko are the old fashioned Yellow RCA connectors. (Called Composite Video.)
There are converter boxes & cables of various sorts that you could use on eBay, Amazon etc.
See: www.amazon.com/HDMI-RCA-VGA-Cable-1-8m/dp/B002ZUI68G
Further Help:
https://discussions.apple.com/message/16046694
http://www.miniinthebox.com/hdmi-to-5rca-cable_p399811.html?currency=AUD&litb_from=paid_adwords_shopping
NOTES:
Many modern Amplifiers also become the main SwitchBox to transfer Video & Audio from one device to another. eg. My Pioneer VSX-922 has 5 HDMI input ports and 1 HDMI output port along with an assortment of RGB & Toslink Inputs & Outputs.
This way (via remote control) I can choose the Apple TV to Connect to the Plasma HD TV or The DVD Player to play Video or Audio to the Speakers. HDMI Makes the cabling so much easier.
For Future reference, when checking out new HiFi gear, always check the ports on the back of the unit.
Your Ports/Cables go by age.
1: Yellow-Composite Video RCA Plug (oldest)
2: Red & White RCA Plug (Audio Left & Right)
3: S-Video-Mini Din Connector (Video Only)
4: RGB- Component Video (Red,Green,Blue-Video Only)
5: DVI- Digital Video Interface (HiDef Video Only)
6: Toslink- Fiber Optic (Audio Only)
7. HDMI-High Definition Media Interface (HD Video & Audio)
I Hope this Explanation Helps Many Others with Similar Problems.
We don't get paid for Assisting People ... So!
If you find this helpful....
PLEASE Click the Button to Acknowledge!
Jun 29, 2014 | Onkyo TX8050 Network Audio ONLY Receiver
I have a toshiba satellite p755, it use to be able to hook up to my HD TV with the HDMI chord but now its not connecting..whats the problem?
Make sure all connections Power ,HDMI and any other connecting leads have secure dust free connections also check each lead for any kinks / bends .
Connecting a Toshiba Satellite Laptop to a TV is an ideal way to enjoy videos, photos and other media on the laptop on a much larger screen.
Satellite Laptops can be connected to TVs using VGA, S-Video and even HDMI, though the TV has to have compatible inputs as well.
Connect the RGB cable or S-video cable to an open input on the TV.
Depending on the type of TV, it may or may not have a RGB input.
S-video may have to be used instead.
Connect the 1/4 inch to RCA Y-cable into the TV using the same input as the VGA or S-video cable.
Connect the other end of the VGA or S-video cable and the audio cable into the laptop.
The video ports are on the sides of the laptop.
The audio cable should go into the headphone jack of the laptop.
http://www.svideo.com/compaq1700.html
Aug 09, 2013 | Computers & Internet
I want to connect my computer to sony wega triniton kvxr29m80 from the hdmi or vga port to the tv's component or 3rc ports. is it possible..i have tried the hdmi to component cable and it does not...
An HDMI to component video cable will not work. These are meant for projectors that work with computers and have only component in jacks.
You will need is a VGA to Composite video converter, VGA to component video converter or HDMI to component video converter. These translate the computer output to the input the TV will understand. Here are some VGA to component video converters: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html . (The exception is if your computer has a TV-out port. In this case, you need an adapter that looks like an S-video plug that will then have composite or component video jacks.) If you want to use the TV speakers, you will also need a 3.5 mm to 2 RCA audio adapter (either M and F/F for an RCA cable to the TV or F to M/M for a 3.5 mm audio patch cable) or cable (3.5 mm M and M/M RCA).
I hope this helps.
(A computer gives RGB output on the VGA cable; the TV reads PbPrY on the component video. Thus you need for the converter rather than a simple adapter. Similar communication differences apply on the HDMI signal.)
May 11, 2012 | Sony Televison & Video
I've tried connecting a Sony DVD player to my TV using Pb Pr V cables. I get a picture, but no sound.
The cable u are using it is the S-video cable?Yes,this cable dosen't support audio.Must used a RCA component cable like R,W cable connected between the tv and the DVD player to get sound.
Mar 14, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I plugged in the normal 3 Video inputs and it still doesn't work.
More info is needed, please. When you say 3 video inputs, what are you referring to? I believe the Sanyo has the HDMI, RGB/YPbPr component video, S-video component, RCA composite video and Coaxial connections, though I'm not sure how many of each. So lets start with the best quality to least.
HDMI: This is one cable that provides both audio & video and produces the best picture quality. It comes in different lengths and is a wide, flat connection. A must for 1080p resolution signals.
Component video, RGB or YPbPr analog component cables: 5 separate RCA cables, 3 of which are video that separate the video signal & 2 audio cables. The 3 video cables are generally red, green and blue (RGB) or marked individually with the letters Y, Pb/Cb & Pr/Cr . The audio cables are red & white. You may see these on the back of DVD players often. They will carry a signal up to 1080i but not 1080p.
S-video component: One cable for video, it is a round connection with several pins in it and will only plug in one way. You must use 2 RCA cables for audio with this cable, red & white again.
Composite video: 3 separate cables; Red, White & Yellow. Red & White are audio, left and right while yellow is video.
And finally there is coaxial which it the cable that is identical to the cable from the pole/ cable box or your dish. It is the poorest quality.
What can happen is you are using 3 standard RCA cables and have them plugged into the component input & they will not carry the signal, or one end in component input and the other end in the composite output or vice versa. Another is that you have the wrong input selected on the menu. Check all your cables and connections, plus the input you have selected on the TV itself.
Dec 09, 2010 | Sanyo 42 in. LCD TV
How can i connect my pc to sony bravia kdl-40ex403
Things You'll Need:
  • 15 pin RGB cable
  • Audio cable
Step 1
Connect the RGB cable to the Video Out jack on your computer.
  • Step 2 Plug the other end of the RGB cable into the RGB jack under PC In on the back of the television.
  • Step 3 Hook up one end of the audio cord to the Audio Out jack on the computer and plug the other end into the Audio jack under PC In on the back of the television.
  • Step 4 Turn on the television and press the "Input" button on the television or the television remote control. A list of input options will appear on the screen.
  • Step 5 Highlight "PC" using the up and down arrow buttons and press the "+" button to choose the computer input. The television will display whatever is on your computer.
  • May 01, 2010 | Lenovo 3000 N500 Notebook
    Need audio cable to go with 7 pin s video to 3 rca cable
    If there is a BCOM computer outlet near you, you can just go pick one up from them. They're about 100 dollars. If there isn't, go to bcom.ab.ca and order a cable from them.
    Aug 19, 2009 | HP Compaq 8510p Notebook
    Xbox 360
    What cables are you using to connect to tv?
    There's
    1) Yellow and Red+White
    2) Red+Blue+Green and Red+White
    3) HDMI and Red+White
    Cable Couplers
    1) 3002 and two 685 rca rgb coupler f/f + rca coupler f/f
    2) 3002 and two 685 rca rgb coupler f/f + rca coupler f/f
    3)3663 15feet hdmi cable
    above numbers can be searched at monoprice.com
    Jan 24, 2009 | Microsoft Xbox 360 Console
    Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
    26 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
