Question about RCA P52960 52" Rear Projection Television
Rca d52w23 convergence problem error code 84
What does error code 84 mean
  • 1 more comment
  • greatdane325 Dec 15, 2008
    no i dont have convergence at setup and yes i have the bowing screen thanks for the help
  • Willie Howell May 11, 2010
    First question how did you get error code 84?...This problem is listed as a convergence problem... Describe you picture is it bowed. if the error code is correct. This means you lost complete convergence. In convergence problems at the shop. There is steps I use to narrow the problem down. First question i alway ask it describe the picture if you got a picture then go to setup do you have the convergence option under the setup option. if not then you have the fl231 problem. if you have bowing in picture then you have a convergence power supply problem. if you dont have bowing picture then you might have a convergence amplifer problem, and then finally it might be a convergence processor problem which then you need a tech. SO( boy that was long winded) That might give you some ideas just let me know and i will see if i can talk you through
  • ladywinn
    ladywinn May 11, 2010
    Error codes are set at different values if they are changed or change by someone not knowing what the value really is can shut set down,You did not say what is your problem?
  • RCA Master
  • 5,138 Answers
OK you can get into sevice menu by turning set off then press and hold vol- and ch- together at same time when set turns itself back on release buttons then menu should appear .
Posted on Dec 16, 2008
    Genius:
  • 1,030 Answers
Consult the fl231 problem in tips and tricks section
Posted on Dec 15, 2008
My RCA D52W23 has 3 colors split.
Thats a convergence failure. You can get a repair kit called " The ITC222 and ITC222A convergence option missing repair kit" From www.tvrepairworld.com which should solve the issue. The kit also contains the CD with instructions.
Apr 02, 2010 | RCA D52W23 52" HDTV CRT TV
My RCA 52 inch projection tv looks 3d. I can't find the setting to fix the screen. The mod number is d52w23
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 27, 2010 | RCA D52W23 52" HDTV CRT TV
I have an RCA D52W23 TV convergence problem
bd pt no is 264103 check your local rca dist and servicers
Oct 23, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D52W23 52in HDTV red and green ghost and bowing lines
Ur convergence it dead,need convergence kit,use what in that kit,U know to solder? Tries websites Tv Repair World.com,Ebay.com
Oct 06, 2009 | RCA D52W23 52" HDTV CRT TV
Convergence problem
Did you replace the convergence power supply board, or the Convergence board?
Sep 23, 2009 | RCA D52W23 52" HDTV CRT TV
No Convergence adjustment option in my RCA Projection TV
please check out the fl231 fuse poblem in the tips and trics under willtab profile you may have this simple repair
Jun 17, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D52W23 convergence problem
If you cannot adjust it with customer menu u need professional. May need service adjustments.
Apr 08, 2009 | RCA D52W23 52" HDTV CRT TV
Go to menu then setup does it have convergence on menu if not then you have a open fuse FL231 it will be the middle fuse there will be 3 of them on right side of FBT flyback transfomer.let me know!
Feb 16, 2009 | RCA Televison & Video
RCA Rear projection had a 3-d like picture. one red one blue and
Go to menu then setup if you do not see convergence on menu then FL231 is open replace it then do auto convergence.
Jan 02, 2009 | RCA D52W23 52" HDTV CRT TV
Convergence problem on rca model d52w23
Replace convergence board or repair it. Try this with TV off Press and hold vol-and ch- at same time hold untill set comes on Now you should be in service menu Go to convergence Adjust the 16x9 mode.
Dec 21, 2008 | RCA D52W23 52" HDTV CRT TV
RCA P52960 52" Rear Projection Television Logo
578 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
