I have checked the pad where the print head sits and moved the printhead to the side. The pad where the printhead sits is covered with ink. should it be and how am i to clean this? does anyone know where I can find a photo of the inside of the epson 9600? I have done nozzle checks too but still no ink. thank you
SOURCE: Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
SOURCE: Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
SOURCE: epson stylus photo 2200 print head removal
Replace the cartridges.
Otherwise, it's unorthodox, but some users have found that this works in your situation. Remove the cartridge, cover the nozzle with a paper towel and use the pointed attachment of a vacuum to clean the dry ink from the cartridge. Be careful not to get ink all over. Then reseat the cartridge and print...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: Epson 9600 Magenta problems...
sounds like a problem with the damper/cleaning unit.
You need to clean the "pads" under where the print head parks.
Turn off power. open front cover. push it cutter (blue) and slide printhead to the left.
You will see a pad in there. this is the cleaning area. Remove and clean. Also next to this is a wiper. it is vertical and needs to be washed with some rubbing alcohol.
try these and get back to me.
