Question about Toshiba Satellite A35-S1592 Notebook
Overheating How do I know if my laptop is overheating? What are the signs?
  • 1 more comment
  • Jennifer Norman
    Jennifer Norman Dec 15, 2008
    Is 'SpeedFan' the name of your suggested utility?
  • Jennifer Norman
    Thank you TJ. I downloaded "SpeedFan,"and hope it helps :)
  • Jennifer Norman
    I appreciate all the "help" you have provided, I truly do.....hence, you were "helpful." Why would I give the "FixYa!" rating before a "fixed" statis can be confirmed? Your response is unjustified and improper.
    Novelist:
  • 157 Answers
Its pretty easy to tell when your laptop is overheating. Youll have those tell-tale red marks on your legs from where the hot bottom of the laptop has been resting against your legs.
Fortunately, most laptops will automatically shut down if they are over heating to prevent any further damage to hardware like hard drives and motherboards.
If you would like to know the running temperature of your laptop, download this little utility.
Hope this helps,
TJ
Posted on Dec 15, 2008
  • Juli H.
    Juli H. Dec 15, 2008
    did you go to a site with far too much text and a bad layout? that would be it. thank god they have good programmers.
    here is a direct link to the application.
  • Juli H.
    Not a problem, but may I ask why I only got a "helpful"? I explained the systems you asked for and not only suggested, but pointed you directly to a free utility that will help you monitor the situation...
    I dont mind responding within a matter of minutes at 5am, I just dont understand....
Why does slotomania shut down my computer?
Does it shut down the computer completely or it just restarts it?
This might be caused by overheating. Are there any signs of overheating in the computer? or outdated video driver. Try updating your video driver. You can also install Radarsync to automate the computer's updating mechanism.
I hope this helps!
Carlo
Dec 20, 2012 | HP Pavilion dv6-1122us Notebook
Its keeps overheating i change radiator and head gasket and still overheating
Did you also replace your thermostat? If it's stuck closed, engine will overheat.
When you did the HG, did you have head checked for cracks or warpage? A cracked head will cause severe overheating.A warped head may or may not show signs of external coolant leakage. Either of these conditions can occur if overheating is severe enough.
Are your hoses in good shape? An old hose can collapse when it's hot, and restrict flow. Feel them (when cool) for any sign of sponginess.
New radiator cap? The cap provides a seal to pressurize the cooling system.
Finally, how about your water pump? Any sign at the weep-hole of leaking coolant? Your water pump inner seal is bad, remedy is a new water pump. Or maybe the pumps' fins have corroded and not pushing coolant sufficiently. If there is corrosion, get the whole system flushed and start anew.
Pull your spark plugs and look for any sign of coolant in the cylinders. I know it's a pain to keep going back and checking, but you gotta be thorough. Plugs may be blistered white from overheating, but if you get it fixed, they should be alright.
Now, finally, really: sometimes, Randy, just a small air pocket in coolant can cause overheating. So, make sure you bleed the system if it has a bleed screw, or fill, cap loose, run engine till t-stat opens, level in radiator drops, then re-fill, and add coolant to your overflow reservoir to around the full hot mark. Tighten cap, and you are done. Good luck.
Oct 20, 2011 | 2004 Jeep Grand Cherokee
My dell inspiron 1525 wont open. Im sure that the power cable is working. Before, everytime I use it, it is too hot as if the fan isnt working at all. I dont know if some capacitors are burned already.
This laptop is fairly easy to check for overheating causes.
Remove the large cover from the back of the laptop to reveal the CPU and heatsink fan. Clean the area around the fan and heatsink. Power the laptop on and see if the fan moves ( also see that the 3 pin connector that connects the fan to the motherboard is plugged in).
Check for blown capacitors, burning around the components and signs of overheating on the board area that you can see. You could try replacing the CPU chip in case it has burned out, however, I rather suspect that the overheating has damaged another component on the motherboard and a replacement motherboard is required
Jan 29, 2011 | Dell Inspiron 1525 Laptop
I have a Toshiba P15S420 laptop and after years of using it starts to shut down after some time powered on. It works pretty wel until it shuts down. Do you have any ideia what it could be...
overheating issue no doubt have it cleaned and inspected for signs of overheating possibly could be other failures but its a good place to start
Dec 21, 2010 | Toshiba Satellite P15-S420 Notebook
What are the signs of a gy6 engine chineese version overheating?
This product poses a risk of fire because there is a potential for battery overheating caused by a high resistance connection. Overheating may cause damage to the battery packs and possibly the scooter, which could result in a potential fire hazard.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 13, 2010 | Hartford VR 200X Motorcycles
Overheating and turning off
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Mar 30, 2010 | Acer Aspire 5315-2153 Notebook
My asus notebook m6b00 keeps overheating and tunring off why?
Laptop overheating has become a more common problem in recent years as both the CPU chips and the video chips in laptop computers have become more densely packed with transistors, all of which generate heat. With both CPUs and graphic systems generating more heat, laptops can overheat if they are not properly designed or if ventilation and cooling is interfered with. The problem is compounded when manufacturers put desktop components in mobile systems, or when laptop design does not properly provide for laptop cooling under foreseeable normal use of the systems.
Laptop overheating most commonly signals itself by sudden, otherwise unexplained shutdown of an operating computer. If your laptop computer suddenly shuts down for no known reason, there is a high likelihood that the fail safe software in the computer is shutting it down when the computer temperature gets too high. Other signs of overheating notebook computers include constant or excessive fan operation, unexplained memory or operation errors, and inexplicable “blue screens of death.”
The problem often arises when you are using your computer intensively in ways that keep the CPU operating at high capacity and the hard drive and video systems busy as well. Gaming often leads to laptop overheating. Virus scans, compiling software and similar intensive tasks can also bring on the problem. The problem also, not surprisingly, sometimes occurs when the temperatures are high in the setting where the laptop is being used.
The consequences of overheating laptops can be quite serious. Your computer can be damaged, and may end up requiring expensive replacement of major system components, such as motherboards or graphic cards. In addition, medical researchers have reported health issues ranging from sterility to burned genitalia related to use of overheated laptops by fully clothed users.
If you have an overheating laptop and your computer is still under warranty, you should promptly report the problem to the manufacturer and seek their help. Because many manufacturers seem to engage in denial rather than cures with regard to this particular problem, you should also read the information on laptop overheating on this and related sites so you can better understand the causes, the consequences and the possible cures for notebook computer overheating.
Here is the to see some tips on why your laptop is overheating.
www.yboyandrei.com/notips
Aug 08, 2009 | ASUS m6n Notebook
Hp dv6700 pavillion mother board bad if it has overheating issue?
it sounds more like the system is overheating to me, they are classic signs.
Have you tried to clean the system fan and the air vents with compressed air? if not try that and see if it stays on longer.
Post back please.
Good luck
Apr 22, 2009 | HP Pavilion dv6000z Notebook
Noisy fans laptop overheating?
Try using Compressed Air in a can by the vents. I would not recommend taking apart the laptop.
Dec 22, 2008 | Computers & Internet
Toshiba Satellite A35-S1592 Notebook Logo
262 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
