Question about HP Smart Buy Notebook
Problem connecting 4.1 speakers to my laptop.
  • Mike Fish
    Mike Fish May 11, 2010
    whats the problem? laptops only have 1 main channel out which is either 2.0 or 2.1 (2.1 is the same as 2.0 except it has a spatializer for the sub)
    but what exactly is the issue you are encountering?
    no audio? or audio coming from the wrong speakers? there is a dual headphone adapter you can buy to use whole set on your laptop
Built- in speakers crackling sound
1. This can happen if you have played something with a lot of bass and the speakers are now damaged. The speakers might need replacing.
2. It could be that the speakers aren't that good in the first place.
3. Try updating the drivers on your computer for the speakers
4. There could be a connection problem within the laptop where the wires are not properly inserted into the motherboard.
Hope this helps.
Aug 14, 2013 | Samsung R540 Laptop
Hello ,I have 4.1 stereo speakers and inspron has only one headphone or speaker jack and other one is for microphone jack , so I currently i am only able to play 2 speakers !! So what should be done to...
There is no real way to connect for true 4.1 stereo on a portable. You can get a Y adapter at Radio shack and then be able to make the other connection though.
Aug 20, 2011 | Dell Inspiron 1525 Laptop
Can I connect my Altec Lansing ADA745 4.1 speaker system to an Acer AS5745-7247 laptop?
Yes. Altec Lansing ADA745 4 Speakers can be connected to a laptop.
Make the connections as follows
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Altec Lansing ADA745 4 Speakers
Connecting a car stereo to an amplifier
you have to connect your 4 speakers to 4 speakers output direct to your car stereo no need of amplifier to 4 speaker but speakers should be small not like a woofer, and you have to connect your sub woofer by using amplifier don't connect direct. connect the output of your car stereo (using 2 RCA) to the 2 RCA inputs of amplifier. If u connect your 4 speakers to your amplifier then your car stereo does not support Left Right channel.
You can also connect your laptop or iPod direct to your amplifier.
Good Luck
enjoy music
Nov 24, 2009 | Kenwood Car Audio & Video
How do i connect to laptop? i can only hear 2 of 4!
If your laptop hasn't a 5.1 surround card you can't connect them in a true 5.1 surround system way. But if you have a stereo sound card and if you don't care about true multichannel and want just to hear sound from all the speakers you neet to connect the adapter that came along with your speaker set-just plug and match the colors from the speaker plugs with the adapter and buy a jack stereo to 2 rca cable and plug the rca connectors to the adapter and plug the stereo jack to you laptop.
Oct 17, 2009 | Logitech X-530 Computer Speakers
Problems with int 5.1-Channel Home Theater Speaker System
yes u will need to chandge input jack from mono to stero radio shack $4 part u need y headphone splitter this should fix ur problem
Aug 07, 2009 | JBL 5.1-Channel Home Theater Speaker...
Connecting SRS-BTM30 bluetooth speakers to my vista laptop
This has also been sending me around the bend. I resolved it by disabling the speakers on my laptop. To do this go into control panel, then hardware and sound, then change system sound. Select your speakers and disable them. This allowed me to play music through the speakers. You can also re-enable the laptop speakers after this.
Jan 17, 2009 | Sony SRS-BTM30 Computer Speakers
How to connect the speakers to my pc
here's the step to connect to yur PC my dear,, just read it 1 The hardwareUnpack the speakers and the cables (included with the speakers) out of the suitcase.
2 I use the speakers with a video 1. Plug the power supply in the speakers.
3. Connect the main speaker with the video.
3 I use the speakers with a computer 1. Plug the power supply in the speakers.
2. Connect the speakers to each other.
3. Connect the main speaker with the computer.
4. Press the 'ON/OFF' button.
4 The softwareIf you use a laptop make sure your volume settings are OK.
Go to Start > Control Panel > Sounds and Audio Devices.
Dec 06, 2008 | Acer 90.00012.30B Computer Speakers
Connecting creative 4.1 speakers with my HP Compaq 6720s laptop
Go 4 setting of audio device in ur laptop.
n check is there 4.1 speaker system is available r not.
Then u can fix ur 4.1 creative to ur laptop.
Aug 01, 2008 | HP Smart Buy Notebook
Speakers
hi frined
here is link 4 u
here is hp 24 hour online tecnision supports he will guide u how to sloves problem
http://welcome.hp.com/country/us/en/contact/chat_1.html
May 24, 2008 | Compaq Computers & Internet
HP Smart Buy Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
