Question about Denon ADV-M71 Virtual Surround Sound DVD A/V Receiver System
I have a denon DVD player. the open close button on the player seems not to actually open the DVD tray is this a common problem with denon products What can I do?
    Champion:
  • 287 Answers
Denon makes so many model . I will need the model number to help you.
Larry
Posted on Jul 10, 2009
Eject button is stuck
Get in touch with the manufacturer's product support and ask them.
May 07, 2015 | Televison & Video
I nudged the loading tray with my foot when changing a disc. As a result the tray is not opening or closing, presumably because it is no longer aligned properly. Is this likely to be something I might fix...
Mechanical timing and alignment is the problem of your dvd player.
This comes when you accidentally force the disc tray to close.
You need to open the cover of the dvd player..take out the dvd mechanical loading system try to eject it manually by turning the gear with your hand.
Make sure that the cd loader reaches the limit switch before it closes. This will return back the right timing and alignment.
Feb 04, 2011 | Denon DVD-1930CI DVD Player
Hi, the dvd on my recorder stayes ejected? It will close but then will eject straight away? What can I do? Cheers.
The fault is not from the disc, it is from the player.
The disc tray is actually malfunctioning. Which is as a result of a fault on the mechanism that is controlling the opening and closing of the disc tray.
Another fault might be that the button that controls the disc tray might be stuck.
test if it is the button.
  1. Unplug the player from the power source,
  2. plug it back,
  3. turn it on,
if it opens without you pressing the open button, then the fault is from the button.
check it for any irregularity.
  1. get the appropriate screwdriver,
  2. open the cover of the player,
  3. carefully force the front control panel open from the sides,
  4. then check for any damages,
  5. change the open button and it will be okay again.
test if it is the disc tray
press the open button, if it opens closes continuously.
then there is a problem with the mechanism that controls the open and close of the disc tray.
to fix this,
  1. Get the appropriate screwdriver,
  2. open the back cover of the player,
  3. look to the left side of the player and you will see a mechanism that controls the tray,
  4. change the mechanism with a new one.
after doing that, the player will be in good condition again.
take care
Jun 18, 2010 | LG RH1777 DVD Recorder
My xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Denon CD door jammed
If you are comfortable taking the cover off, you can try removing the cover and then try to help the tray out the same time you are hitting OPEN/Close.
IF you are not comfortable removing the cover then, you can try to take a credit card (Actually, if you have any of those JUNK credit cards that the CC companies send out as trial offers, those work the best, and who cares if you bend those, they get tossed anyway) and bend an edge at a 90 degree.. (about 1/8" of the edge) so it makes like a small ledge. try to fit it inbetween the top of the door, and then see if you can open it up. Some players have a seperate door, and some trays are attached to the door. You might be able to help it out or unjam the tray this way.
And in the Future, with any other CD/DVD Players, use your remote control or the open and close button to open and close the tray, and NEVER Push on the tray itself. If I had a dollar for every dvd player tray that Ive fixed because of this, I would be buying bill gates dinner. (not really, but you get my point)
Good luck.
Feb 03, 2008 | Audio Players & Recorders
Locked dvd tray.
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears.   The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
Apr 07, 2006 | Panasonic DVD-A110 DVD Player
Need help! DVD tray won't open
soundsa as though there is a draw drive problem and that could be a motor or as simple as a belt?? are you sure tjhat the eject button works properly as I found out on these denons that the eject switch or push button wont make contact with the switch behind it because the Printed cuircut board shifted??
Apr 02, 2006 | Denon DVM-1800 DVD Player
302 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
