Question about Hotpoint TDC32 Electric Dryer
Heater cuts out after a few seconds
Replaced the Heater element, appears to be continuity on the two thermostats above the element, but when switch on , the elements heat up but switch off in a couple of seconds. The drum continues as normal.
  • Hotpoint Master
  • 3,463 Answers
It is advisable to replace stats after fitting new element, make sure there is no build off lint round the stats.. Hope this helps
Posted on Dec 15, 2008
Timer ticking and heating element activating when dryer is off
One thing to check is if the heater is shorted to frame.Remove the wires and do the checking. If that is fine then the only way the heat can come on at all is IF the motor is running. So check between terminals one and 2 for continuity with the motor NOT running. If you get a reading then your motors cent switch is stuck. You can sometimes oil the springloaded sliding switch but most times the springs have broke on it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 21, 2012 | Dryers
My maytag dryer wont heat up model#sde3606ayw just had the heateaten element replaced 2months ago could it be the fuse
HI. There are a few areas i would advise to check to resolve this issue.
The dryer uses multiple thermostats to regulate the temperature. When the temperature is higher than the preset limit of a particular thermostat, the thermostat breaks the circuit and the heater goes off. When the temperature cools enough, the thermostat closes the circuit again and the heat can come on.
Most dryers have a choice of temperature settings, therefore a separate thermostat is used for each setting. The selector switch or timer control then routes the circuit through the appropriate thermostat.
If a thermostat fails, it may prevent the heat from coming on, This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.
A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, This is called a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again. The most common cause of overheating will be a clogged ventilation assembly. Be sure to inspect the entire ventilation assembly for build up. This will cause issues, if obstructions exists.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
NOTE(If the Thermostats and fuse check out ok, replace the element. Element failure is uncommon but, it may fail in certain cases))
Apr 15, 2011 | Maytag PYE2300AY Electric Dryer
Dryer drum works but does not heat. Everything else works. I have checked the fuse and I have made sure it is not on air dry.
THERMAL FUSES MAY BE THE CAUSE OF THIS In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element. Follow the diagram below to see how to check the continuity of the switch, and look closely at the switch to see a fairly close idea of what you are looking for, ok
OR it could be a thermostat.
Cycle and safety thermostats-read them with an ohm meter. Should show continuity .
or lastly, it might be
the Heat elements-Test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ).
IF you do not have an OHM-METER, then you can check these issues by following the directions below:
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.
To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
Do not forget to rate this answer!!
Jan 24, 2011 | Frigidaire Electric Dryer
Reset button needs to be hit then water gets extremely hot and reset button needs to be hit again.
The reset button or ECO (emergency cut-off) is a safety device.
The ECO trips and cuts off power to entire water heater when it detects temperatures over 150 degrees.
This prevents overheating and eventual explosion of water heater.
You have 1 of 3 problems:
a) Factory-installed insulation and cover have been removed and thermostat is receiving cool air and not reading correct temperature
b) Bad thermostat. Thermostat is sticking in ON position -or- thermostat is misreading temperature.
c) Element is shorted to ground near center of element and not tripping breaker, and the element is heating off 120 circuit that is flowing through ground wire.
Steps you can take:
1) Inspect water heater and see if factory insulation is present behind each cover.
2) Turn off power.
Disconnect ground wire for a couple days and see if problem persists.
If problem stops, then test elements and replace bad one. See below for how to test element.
Caution: Do not touch this water heater with ground wire disconnected unless power is OFF
3) Replace thermostats and see if problem persists.
For around $25, you can buy generic upper-and-lower thermostats at Lowes or hardware store > then replace the thermostat(s) and see if problem persists.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Problem should be resolved.
4) If problem continues after steps above
You will need to test water heater parts to track down the exact problem: for example a shorted wire.
You need a inexpensive multimeter from Radio Shack, and the steps are simple, and afterward you will know nearly everything about electric water heater.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
How to test element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Turn off power.
Remove both wires from lower element.
Test across both screws with a continuity tester.
The continuity tester has a battery and when light comes on, it says the circuit is complete.
Test1) Test across both screws on lower element with continuity tester.
If the light comes on then the element is good so far, but element has to pass one more test.
Test2) Test each screw on element to any bare metal part of water heater.
If the light does NOT come on with the second test, then element is good.
Light ON first test. Light OFF second test. Then element is probably good.
This is not 100% fail-proof test without a meter but it is a good indicator.
If you are still having a problem, answer back and we'll give you more details.
Oct 25, 2010 | Reliance & 50gal Electric Water Heater
Reset button seems to be stuck down and run out of hot water to soon
If I understand correctly, you have an electric water heater.
The water heater is dual element and has 2 access panels on water heater.
You run out of hot water quickly.
And the reset is stuck down.
First of all, if the reset button is tripped, the water heater will produce NO hot water.
The reset, or ECO (electricity cut off), is designed to cut off all power to water heater.
So if you have some hot water, then ECO reset is fine.
The thermostat may be bad, but the ECO is fine
Next in line:
If your upper element is burned out, then the water heater will not make any hot water.
So if you have some hot water, that tells us the upper element is working.
The three remaining suspects are upper thermostat, lower thermostat, lower element
Let's test the lower element.
Turn off the power.
Element has to pass both tests. Light ON first test. Light OFF second test. Then element is probably good. This is not a fail-proof test but it is a good indicator.
I'm betting the lower element is burned out and you need to replace lower element. And you may need to vacuum out the sediment.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
Now if lower element is good, then the easiest thing is to do is replace both thermostats. After replacing both thermostats, the water heater will probably work. If there is still a problem, then the lower element was not as good as the test showed, and it should be replaced also.
Oct 23, 2010 | Reliance & Electric Water Heaters
How do you replace the heat element on a whirlpool LER8648 dryer?
Before replacing the heating element, check first the continuity of the thermal cut-off and the high-limit thermostat located on the heater box, the resistance of the heating element, and the continuity cycling thermostat located on the blower housing. Replace the heating element only when it reads open. Replace both the thermal cut-off and the high-limit thermostat should any one of them is found open. The cycling thermostat must have continuity between its thicker terminals; otherwise, replace it.
All of the above components are accessible through the rear of the dryer. Remove the rear panel by removing the screws securing i to the dryer cabinet. Replace the heating element by removing the screws attaching its housing to the heater box then securing the new heating element housing in place.
May 28, 2010 | Whirlpool Dryers
No heat whirlpool electric dryer imperial 70 1986 vintage
replace cut off switch fuse at the top of heater box
May 02, 2010 | Whirlpool GGQ8831L Gas Dryer
Dryer want heat. Element not broken. Where do I check now
A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, This is called a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again. The most common cause of overheating will be a clogged ventilation assembly. Be sure to inspect the entire ventilation assembly for build up. This will cause issues, if obstructions exist.
Nov 23, 2009 | Kenmore 63942 Dryer
Heater stopped but dryer still working
Nov 02, 2009 | Zanussi TC7102W Electric Dryer
I have no heat
Oct 18, 2009 | Estate TEDX640JQ Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
88 people viewed this question
Top Hotpoint Dryers Experts
shaun taylor
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
