Question about PfaFF Hobby 4260
Twin needle Is there a twin needle attachment available for the Hobby please thanks Marg
    New Friend:
  • 186 Answers
Any universal twin needle should work, there is no attachment. Just don't set your stitch width too big if you are in zig-zag!
I hope this helps and good luck.
Posted on Feb 05, 2009
Do I need to use a specific "foot" with twin needles? The one needle hits the foot I have
You need to use something like a zig-zag foot that has a wide opening for the needle. If the needle is still hitting the presser foot, then your machine may need adjustment or you can try a twin needle where the needles are closer together (twin needles are available with varying distances between needles).
Jul 11, 2017 | Sewing Machines
Where can i find needles for a singer 306k machine ?
What type of material are you going to be sewing? Sew-Classic has 10 needle packages of the size 12 and size 14 needles for the Singer 306 for light (not fine) and medium weight material. (It's a 206x13 needle for the single needle. The twin needle is a 306x3.) See . has some notes on alternative needles. The site has boxes of 100 size 14 and size 12 needles. (The size 14 needles are out of stock due to delays on the manufacturer's side.) (size 14) needles in stock.
Unfortunately, I do not see any twin needles available for the 306K. I hope this helps.
Feb 20, 2015 | Singer Sewing Machines
How do I attach a twin needle post to my Bernina 950
Hello Erina
Sounds like you purchased and wish to use a twin needle which comes as two needles on a single needle shaft, correct? That is terrific and you have a wonderful machine.
Remove the needle in the machine just the same as you have been over the past 2 years. Unscrew the needle clamp screw, pull down on the needle or part of the needle in the machine and insert the new twin needle shaft into the needle bar. Tighten the needle clamp screw and thread the needles using two sources of thread on the top.
If the existing needle post is not coming out of the needle clamp easily, use a pair of pliers to grip and pull down. Cover the sewing surface to ensure that it will not be damaged as the pliers free the needle. If the needle is firmly embeded, you may need to give the pliers a gentle tap with a small hammer.
If using a zig zag stitch make sure that the width does not exceed the twin needle limit; otherwise as the needles swing from side to side they can hit the stitch plate and brake.
Happy Stitching
Oct 23, 2014 | Sewing Machines
How do I insert another needle to have twin needles in my 7436 Singer.
You don't. You need to purchase a twin needle; it has one shaft, and two needles attached.
Jul 09, 2014 | Singer 7436 - INGENUITY
This machine is supposed to be able to have twin needles. Where do I insert the second needle.
Twin needle assemblies have to be purchased! When you buy one, you will see that it has ONE needle shaft that goes into the needle clamp, and two needles attached to that. Take a look at the drawing that is next to the top button over the needle shaft area, and it has a rough picture of a twin needle. In other words, it's a TYPE of needle, like a ball point needle, leather needle, jeans needle, etc.
How to thread twin needle on singer
Look in your attachments for the secondary spool pin. Then you'll thread both upper threads as normal.
Jul 30, 2012 | Singer Sewing Machines
Code E8 on brother Model Ns40
Yes the manual for Brother sewing machines are available from their support site: . I believe the NS40 is the Brother Innov-is 40. The direct link to the manual is . An E8 error means that a stitch was selected after the twin-needle setting has been selected. Cancel the twin-needle setting and then select a stitch. Then if you are using a twin-needle setting, adjust the machine for the twin-needle setting.
I hope this helps.
Jan 26, 2012 | Brother Sewing Machines
What twin needles do I get for my overlocker ,It is a Janome Mylock 134D Are the needles universal or do I have to get a special one for this machine
I think Janome Mylock 134 has 2 separate needles. They are #11 or #14 for sergers and secured by 2 independent setscrews. I saw on ebay the instruction book with the owner's handbook for Janome Mylock 134D.
Jun 23, 2010 | Janome MyLock 644D
I've just got janome 634d serger, how can i make the bottom of a T-shirt ? Thank you so much
If you want the bottom of the T to look like RTW with the double row of stitching, you cannot do this on a serger.
You can achieve the effect by using a twin needle, two spools of thread, bobbin and a straight stitch.
Make sure the double/twin needle will pass through the presser foot and opening in the needle plate below the presser foot.
Practice on a double layer of a scrap of the T shirt material as the tension may need to be slightly looser than the normal setting.
Apr 05, 2010 | Janome MyLock 634D Mechanical Sewing...
Pfaff Select 1540
Search for:
sewing machine timing
Lots of web sites and videos available.
Jun 28, 2017 | PfaFF Hobby 4260
Sewing Machines Logo
153 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
