Question about Microwave Ovens
Microwave oven is heating cold.. instead of hot. the clock still works though
  • Thxs4thehelp Dec 15, 2008
    I have the same problem. The lights come on and the turntable turns. Right before this started it was making a loud noise and then blew the circuit breaker in my electrical box.
    Now it turns on but does not heat.
    Model No. JVM2070SH001
    Manufactured September 2003
    Any assistance would be most appreciated.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    Do you have the model number?
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • 108 Answers
It sounds like a problem with the transformer/Magnetron section of your unit. If the unit is in warranty call the manufacturers customer care. If not, replace the oven as service is more expensive than a new unit. Ther are many great features on the new ovens and the prices are very reasonable.
Ray
Posted on Dec 17, 2008
My GE Profile Jvm1870sk03 microwave built oven does not work. There is power, the clock, timer works. If I press the button to heat the clock shows it's going on but there is no heating process go
Most likely door switches. Companies these days use switches with small 3/16 terminals and they tend to get hot and make the switch go bad. When I replace them I put in a 20 amp rated switch with 1/4 inch terminals, and a short section of better wire to the switch. If you make better connections it stops the wires from getting hot and the switch will last a long time.
Aug 24, 2017 | GE Microwave Ovens
Stop cooking. The clock works it doesn't heat though
The magnetron is the likely cause, "heats food" the other possibilities are the high voltage capacitor and diode, chances are repairs will approach or exceed the cost of a new microwave oven.
Mar 28, 2011 | LG LMV1630ST Microwave Oven
Our emerson microwave will not make anything hot.put in time for something to cook it runs fine but it will not make the food hot HELP!!!!! the sides and top and bottom of microwave are warm but food is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 14, 2010 | Emerson Microwave Ovens
Not heating up anything
Tat would be a magnetron problem. The magnetron is what provides the heat
Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Heating the cup more than coffee
make sure the stirrer motor located under the outer cover that distributes the microwaves is turning otherwise you will get hot and cold spots in the oven cavity
Apr 30, 2010 | GE JVM1870 Microwave Oven
Keys to microwave do not work, it keeps beeping though.
It sounds as though the pc board behind the keys is faulty.
Oct 04, 2009 | Microwave Ovens
No heat
heating element stopped working
easiest thing is to get a new microwave
Dec 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
LG microwave no longer heats!
It sounds as though you may have run the microwave while empty, which can damage the magnetron.
Not that I'm optimistic, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise it likely needs a new magnetron.
Apr 06, 2008 | Microwave Ovens
MMV5000BAW maytag over-the-range microwave
Found this in the GE section instead of Maytag, but we're happy to answer it anyway.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
If not, you may have a shorted keypad or bad control panel, either of which we can repair economically.
Please write back with more details if you need further help.
Nov 25, 2007 | GE JVM1870 Microwave Oven
My Microwave does not heat up or cook...
the microwave oven has been working, but all of a sudden it does not heat up.
Nov 05, 2007 | Emerson MW8778 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
