Question about HP LaserJet 4000 Printer
HP4000 not printing LPT1
Printer turned off and unused for several years.
Printer prints Configuration page & PCL font list okay.
No warnings or error message displayed on printer display.
Have download HP4000 printer drivers and added printer using Printers & Faxes - Windows XP SP3
Printer status shows ready.
If I send a print job it shows up and clears when monitoring the printer job status window. If I turn the printer off and send the print job it stays in the print que (spooler) until printer is turned back on and ready to accept print job.
I have tried turning off CLEARABLE WARNINGS and AUTO CONTINUE
and resent print job and no warings or erros shoed up.
I have tried factory resets menu, reset I/O menu, reset memory menu to no avail.
I have tried connecting printer to another XP PC but got same result.
Does anyone know how to run HP maintenance test mode to check printer communications out? Or any thing else I can try.
I will get the printer cable checked out tomorrow but I feel it's not the printer cable?
Thanks for any ideas to try or any assistance.
  • Karl Becker Dec 16, 2008
    Problem cleared itself after removing anf refitting parallel printer cable the next day. I'm still not convinced its a cable problem though!
  • sam88kid May 11, 2010
    Hi Ballbearng,
    Did the printer go through the printing motion?
    Any blank paper spat out or just display that it is printing and nothing printed?
    President:
  • HP Master
  • 990 Answers
Dear sir;I believe you can try " cold reset", that's means going to clear all data from the printer memory and sets all the defaults back to the factory settings.performing a "cold reset" resets the jetDireect configuraion. to avoid making changes to yourconfiguration, remove the jetDirect card before performing a cold reset. if possible, print a configuration page prior to performing a cold reset. this will document current settings for later reference.
to perform a cold reset;
1, turn off the printer.
2, while pressing "go", turn the printer on. COLD RESET appears briefly on the display, then INITIALIZING appears.after a few seconds, RESTORING FACTORY SETTING appears on the display, followed by OFFLINE.the cold reset is complete.
3, press "go" to return the printer online "ready " appearson the display.
Little bit complicated but is easy ,hope can take care your problem, GOOD LUCK! Let me know the resolve please!
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 18, 2008
My printer HP LASER JET 5200 DTN shows "Ready" on the display but it doesn't print, how can I fix this?
First thing you need to do is establish whether the print engine itself is at fault, or not.
From the relevant printer front panel menu, invoke printing of one or more of the available reports (configuration, font list, etc.); do these print?
If the reports print OK, try to send some plain text to the device.
On a Windows system, you could do this by using the DOS copy command in conjunction with an appropruate net use command to redirect LPT1: to the (USB) port associated with the relevant Windows printer instance.
Jun 02, 2015 | HP Office Equipment & Supplies
Canon printer prints an extra page with a message ""@PJL INFO STATUS""
More information is required like are you using windows 7 or windows 8. Suspect you may have wrong PCL driver. PCL.
Press additional functions on printer keypad. Press report settings on LCD screen. Press Printer on lcd screen then press configuration and press yes to printing configuration page.
Look at the configuration printout to see if you can find the language the printer is using is it PCL3 ,PCL6, PCL5E, PS3 ..
This has to match the driver you are using !
All these drivers are available to download from Cannon but finding the matching driver can be done via trial and error but the configuration page is easier and less painful.
A mismatched driver to printer is possibly the cause of the extra page print.
Nov 09, 2013 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
HP L7680 Error
GOOGLE IS YOUR FRIEND IN SUCH CASES :) Excuse Caps. Your Drivers need updating, but you are seriously hampered because all support for XP ended ages ago. Why are you still running Windows XP leaving your computers open to security breaches? You should be on Windows 8 Pro at the least or Windows 10. What I would do is go to the HP Website and download and install the drivers and software again.
Search Results PCL XL Error. The PCL XL error is most commonly associated with HP LaserJet printers. The error occurs when several pages are sent from a document to the printer's print queue. ... HP has identified the problem printer drivers for most of their printers that display the PCL XL error.Mar 11, 2016
PCL XL Error - The Tech-FAQ
www.tech-faq.com/pcl-xl-error.html Feedback
About this result
How to Fix PCL XL Error ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-pcl-xl-error Mar 31, 2015 - When attempting to print certain documents on a Hewlett-Packard LaserJet all-in-one printer, you might sometimes end up with a piece of paper with a "PCL XL" error code printed on it. This is due to the printer's inability to process certain parts of the document, such as embedded fonts or images.
Solved: PCL XL Error and other weirdness - Customer Support Forum
forum.support.xerox.com/t5/Printing/PCL-XL-Error-and-other-weirdness/td.../164 Sep 17, 2010 - 10 posts
Hi all,. We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 ...
PCL XL error in printer - Microsoft Community
https://answers.microsoft.com/.../pcl-xl-error.../124223ac-bd82-4758-8d7f-7efe95a04... Nov 11, 2013 - I have a HP LaserJet 4250 PCL6. I was trying to print and all of a sudden I am getting an error message. ... c:\ windows\system32\spool\printer\X64\3 rename the file relating to your printer with the .gpd extension - call it anything you wish and then reboot your pc and it re-creates ... PCL XL error: IllegalOperatorSequence
3 Dec 2016
PCL XL error - Subsystem: IMAGE - Error: IllegalAttributeValue ...
13 Jul 2016
Getting PCL XL error when trying to print.
30 Dec 2012
When trying to print, get a page that has message PCL XL Error ...
28 Dec 2012
More results from answers.microsoft.com
Troubleshooting: PCL XL Error - Customer Support
https://stamps.custhelp.com/app/answers/detail/a.../troubleshooting%3A-pcl-xl-error Next, you will need to install the "PCL" or "PCL 5" version of your printer's driver. This driver should already be available on your computer or the CD that came with your printer. It can also be downloaded from the HP website.
www.tech-faq.com/pcl-xl-error.html Rating: 4 - ‎4 votes
Mar 11, 2016 - The PCL XL error is most commonly associated with HP LaserJet printers. The error occurs when several pages are sent from a document to ...
PCL XL error Google Search
Jul 25, 2017 | Office Equipment & Supplies
Pcl xl error error: insufficient memory operator: rectanglepth position : 751 How do i correct this problem
Solution
The possible reasons for this error message are as follows:
  • The document is containing both image and text.
  • The font is not supported.
  • Embedded fonts are used.
  • A special plug-in is used.
This issue can be fixed by enabling the following option in Printer Preferences .
To access Printer Preferences , follow these steps:
  1. Open the Control Panel .
  2. Open Printers and Faxes .
  3. Right-click HP Color LaserJet CM2320 MFP Series PCL 6 , and select Printing Preferences .
  4. Under the Advanced tab, change the Print Data Optimization from Auto to Optimize for Text and Vector .
  5. Now try printing the document.
  6. If the document did not print then try turning the printer off then back on. Try printing the document again.
Rameshkumar . R
cberamesh@gmail.com
Aug 24, 2011 | HP LaserJet P2015 Printer
How to print a usage page for HP color laserjet CP2025n
You can print usage page as follows via front control panel on the printer itself.
  1. Control-panel display: The display provides information about the product. Use the menus on the display to establish product settings.
  2. Back arrow ( ) button: Use this button for the following actions:
    • Exit the control-panel menus.
    • Scroll back to a previous menu in a submenu list.
    • Scroll back to a previous menu item in a submenu list (without saving changes to the menu item).
  3. Left arrow ( ) button: Use this button to navigate through the menus or to decrease a value that appears on the display.
  4. OK button: Press the OK button for the following actions:
    • Open the control-panel menus.
    • Open a submenu displayed on the control-panel display.
    • Select a menu item.
    • Clear some errors.
    • Begin a print job in response to a control-panel prompt (for example, when the message [OK] to print appears on the control-panel display).
  5. Right arrow ( ) button: Use this button to navigate through the menus or to increase a value that appears on the display.
  6. Cancel Job (X) button: Press this button to cancel a print job whenever the attention light is blinking or to exit the controlpanel
    menus.
Now follow these points to print th required page:
  1. Press OK to open the menus.
  2. Press the Left arrow ( ) or Right arrow ( ) button to navigate to Reports, and then press OK.
  3. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the reports, and then press
  4. OK to print a report.
  5. Press X to exit the menus.
The following information pages are available:
  • Demo page
  • Menu structure
  • Configuration page
  • Supplies status page
  • Network configuration page
  • Usage report
  • PCL font list
  • PS font list
  • PCL6 font list
  • Color usage report
  • Service report
  • Diagnostics report
SOURCE
Oct 25, 2010 | Computers & Internet
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
May 27, 2010 | HP Laserjet Cp2025n Printer
How do I print a confirmation page for this fax
1. First You need to press the additional functions button on the front.
2. Select Report Settings button
3. Select Printer button under the Print List menu
4. Press either PCL button or PS button to print the appropriate config page.
5. Press Configuration Page button
6. Select Yes button to confirm printing of config page.
Feb 19, 2010 | Canon LaserCLASS Fax 710 Printer
PCL XL error
Okay,
You printer driver is telling you that it received a font call at data position 317 that called for a Windings font, but the printer cannot find the indicated font.
More than likely you have not enabled soft fonts to be included in the datastream and the printer has no choice but to search its internal fonts to find the fonts.
If it cannot, the driver reports the failure.
If you can create a print file for me, and send it to me at don.farr@msn.com, I will be able to read the datastream and possibly fix the failure for you.
Don
Jan 29, 2010 | Dell 1700n Laser Printer
Dsc328 will not print using a Mac
If your copier / printer does not have postscript 3 option installed, it will not print from MAC. Print a configuration page: "User tools", "Printer features" "list print" (or similar), "configuration page". Check under the heading of "printer languages"......you'll see stuff like "PCL 5c", "PCL 6", "RPCS", etc. If no "postscript 3", it is not compatible with your MAC, and you don't want to know how much that option is for your machine! Ridiculous!
Feb 25, 2009 | Gestetner DSc328 Copier
HP LaserJet 4000 Printer Logo
477 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
