Question about Dell OptiPlex GX260 PC Desktop
I have a system of Dell PC Desktop Optiplex GX260 which doesn't display nor boot rather than 6 beeps and the back light signals are: A - Green B - Green C - Yellow or Light Orange D - Yellow or Light Orange
  • khalidsec Dec 16, 2008
    Thanks for your valued suggestion but I have already tried three times changes of DDR RAM which are running correctly on other computers but the problem in my computer is still same.
  • khalidsec Dec 20, 2008
    Thanx alot for your favor and suggestion, I got my motherboard repaired from a hardware shop and now it is showing display and running successful. He changed a chip in motherboard. Thanx again.
HEY MAN THE PROBLEMM IS YOUR MEMORY RAM JUST BUY A NEW ONE DO YOU NEED A PC2700
Posted on Dec 21, 2008
  • 104 Answers
That is a memory failure 1 or more sticks of memory are malfunctioning, here is a link with all the information about the diagnostic lights as well as a beep code list
http://www.austincc.edu/cloud/manuals/Dell/GX260/solvprob.htm#1167139
Posted on Dec 15, 2008
  • Mike Fish
    Mike Fish Dec 16, 2008
    then your memory controller is bad and your motherboard needs replaced
3 Suggested Answers
zonkpc
  • 68 Answers
SOURCE: Dell PC Desktop Optiplex GX260 Doesn't boot
Open up the case and remove any add in cards and memory modules. Try to start up by adding these back one at a time until the unit stops booting normally. The light combination is not one recognised in the user manual so I am guessing you have a non-descript fault with one of your components. Be careful when you open the case as to not disturb the ribbon to the motherboard which controls the power, I have had a very long experience trying to get one of these reconnected!
Posted on Dec 16, 2008
i wana khow
about krst
Posted on Sep 16, 2013
The back light signal is yellow instead of green but the fan works it boots alright but does not display anything on the monitor
hi
you should probably check to see that the rams are ok, this is mostly the cause of issues like this. most times swapping the ram if you have two solves this issue, or changing the current position of the ram
hope this works
Oct 13, 2011 | Dell OptiPlex GX260 PC Desktop
No display and can not boot but gives 6 beeps when switched onthe first four are continuous and then two
1.power supply
2.memory cards
at last mother board need changing !
hope it will help
May 20, 2010 | Dell OptiPlex GX260 PC Desktop
Dec 15, 2008 | Dell OptiPlex GX260 PC Desktop
Dell optiplex gx260
Reference the Power LED States
Dell OptiPlex and Dimension computers and Dell Precision workstations have incorporated the use of the multi-state power button LED as a hardware status indicator. The power button LED illuminates in two different colors and can also blink, which allows for indication of five different system operation states. (Table 1)
LED State
System State
Steady Yellow The power supply is functioning, but the system is not processing data. This may indicate an issue with the system board or CPU. Blinking Yellow The power supply is receiving power from the source but is unable to properly distribute it to the components. This may indicate a power supply problem. Steady Green This generally indicates that the system is functioning normally. However, if problems are detected with installed components, the system may initiate a beep code. Blinking Green The system is in a Standby ACPI state. Off The system power is off.
Feb 24, 2008 | Dell OptiPlex GX260 PC Desktop
DELL GX260 bootup problem
To start with I would run FDSIK from a DOS boot disk and delete the partitions on the hard drive. Then reload the operating system. There is no telling what has been loaded on the system. After the reload the DELL should boot normally.
BPCS
Nov 15, 2007 | Dell OptiPlex GX260 PC Desktop
Dell gx 150
Chuck,
The 6 beeps are an error code. You should note a pattern such as 3 beeps, short pause, 1 beep, short pause, 2 beeps. Also, you may have a set of 4 error indicators on the back of the unit that will show a pattern of green and yellow lights. In any case, you will want to try to run the Dell diagnostics. Let us know the beep pattern and the light pattern and we should be able to give you some more specific information.
R-
Nov 05, 2007 | Dell OptiPlex GX260 PC Desktop
Optiplex GX260 won't boot
I had the same issue and accidentally discovered a temporary solution. Unplug the power from the back of the machine, open the case and unplug the ATX power connection from the motherboard. With the ATX cable unplugged, plug the power cord back in. When you try to turn the computer back on the power light should turn orange and fans should be spinning, with it powered on plug the ATX connector back in. That should turn the computer off. Turn it back on and it should boot fine. You can even shutdown and restart, but when the power is unplugged you will have to go thru the same process to get it back up. This sounds crazy but it worked on mine. Good Luck!
Nov 01, 2007 | Dell OptiPlex GX260 PC Desktop
GX260 DOESNT BOOT
Potential Problems : 1. RAM loose in the slot. Take it out, clean the contacts and reinstall 2. CMOS Battery ( Most probably Battery number is CR 2032 ), just replace it by a new one. 3. Faulty SMPS : Change / get it repaired. Good Luck, Rajesh
Aug 18, 2007 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
556 people viewed this question
Alun Cox
